What U-Joints for SuperDuty D60? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 08-02-2015, 10:21 AM Thread Starter
SuperDuty D60 (99-04) Question
Hey guys, for the few of you that have done the SD dana 60 swap (99-04 not the giant one released in later years)
What did you go with when it came to ujoints?
Thanks for any help
Danthephotoman is offline
post #2 of 10 Old 08-02-2015, 07:47 PM
Fueler is offline
post #3 of 10 Old 08-03-2015, 09:27 PM
I used the same SPL55-3X from Amazon.
2012 JKUR - Straight out of the junkyard
Stan McMurrey is offline
post #4 of 10 Old 08-03-2015, 09:49 PM Thread Starter
Thanks for the help guys!
post #5 of 10 Old 09-01-2015, 10:08 PM Thread Starter
Figure i would bump this instead of throwing up a new thread.
What have you guys with SD Swaps done for drag link/ track bar and bracket?
Have to get new frame side bracket? Custom track bar? Thanks for any help
post #6 of 10 Old 09-02-2015, 07:06 AM
I sent the knuckles off to be machined for high steer, everything is custom from there, but it's pretty simple actually. Just make a straight tie rod with 7/8" rod ends, do the same with the drag link. The track bar bracket, on the axle end, is part of the artec truss.
Fsociety is offline
post #7 of 10 Old 09-02-2015, 07:09 AM
Just make sure that the drag link and track bar are at the same angle and attempt to make them as close to equal length as possible. I say "as close to" because it's impossible to package it if you make the equal length. You just don't have the space to do it.
Fsociety is offline
post #8 of 10 Old 09-03-2015, 08:34 PM Thread Starter
I won't be using the artec kit. Looking for recommendations on a front trackbar bracket for sd d60
post #9 of 10 Old 09-03-2015, 11:07 PM
VKS Fab
JK Vick's Avatar
We have some parts that'll work. Shoot me an email and we can set you up.
Handmade One At A Time
GIVE US A CALL 559-392-3145
JK Vick is offline
post #10 of 10 Old 11-06-2015, 06:55 PM Thread Starter
Alright guys, I need some more wisdom from you guys.
I have the Currie f450 unit bearings. They use a 35 spline stub shaft.
So I ordered some nitro 35 spline stub shafts. Just one problem, they don't have the cut on the splines for the snap ring to fit.
Is there a different way to put them in?
Also, anyone know of a superduty rotor in 8x6.5?!
Thanks for any help.
