Sleeves - Internal vs external - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 08-01-2015, 11:44 PM Thread Starter
Rubichronic's Avatar
So I'm planning to sleeve, gusset and truss my front axle. I was gonna go with the Artic kit, but someone mentioned using an external sleeve would allow me to upgrade my axle shafts. What are the differences or advantages of one over the other?
I have only found one manufacturer for external sleeves, I think it was Rock Hard or someone like that. Are there any others? Does anyone's me an external sleeve and truss kitt that works together, or are there any external sleeve kits that will work with the Arctic Truss?
2011 JKU Rubi
2.5" RK Max Travel
35/12.5/17 Pro Comp MT
35/12.5 /17 Duratracs
Poison Spyder Evap Skid
Paramount front and rear bumpers
VKS Rocksliders
Fox 2.0 shocks
Recon 10,000lb Winch
Vision X Rock lights
Cobra 75
Rubichronic is offline
post #2 of 12 Old 08-02-2015, 12:17 AM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
Skip the sleeves altogether and do the Artec truss and gussets.
RiverCityOffroad is offline
post #3 of 12 Old 08-02-2015, 08:13 AM
Robbs2008JK's Avatar
Truss it no need to sleeve it
My build
Robbs2008JK is offline
post #4 of 12 Old 08-02-2015, 08:13 AM
Mtn Derp's Avatar
I would honestly skip the sleeves. You're not going to get anything out of sleeves, internal or external, that you're not already getting with the truss. Plus internal sleeves will limit your axle options, as they take up space inside the tubes.
I've got the Artec JK Truss & armor kit (full truss, upper/lower C-gussets, welded LCA skids) and some beefy diff covers, and I beat the piss out of it on the rocks no sweat.
Wanna make a little money?
Start with a lot of money, buy a Jeep.
Mtn Derp is offline
post #5 of 12 Old 08-02-2015, 10:50 AM Thread Starter
If I skip the sleeves and just truss it, can I add the sleeves later? I was thinking about the Nitro sleeves which I think allow for upgraded axle options.
2011 JKU Rubi
2.5" RK Max Travel
VKS Rocksliders
Fox 2.0 shocks
Cobra 75
post #6 of 12 Old 08-02-2015, 12:15 PM
There is no need for sleeves if you truss it.
IndyJLH is offline
post #7 of 12 Old 08-02-2015, 11:16 PM
Mtn Derp's Avatar
^Bingo
Mtn Derp is offline
post #8 of 12 Old 08-03-2015, 07:33 AM
TCdawg's Avatar
no need for the sleeves if you truss it but to answer your question, Yes, you can add sleeves after a truss...it would just be waste of time, money and effort.
If you truss you do whatever axle shafts you want
TC
TCdawg is offline
post #9 of 12 Old 08-03-2015, 10:03 AM
Jeepineer
JKred07's Avatar
I'll add to the trend. External sleeves are a big gain over internal sleeves. They add diameter and wall thickness. Internals only add wall thickness which doesn't do a whole lot except improve impact strength (dent resistance). But for the same or less work, truss adds more overall strength than external sleeves.
-Mike
JKred07 is offline
post #10 of 12 Old 08-03-2015, 12:31 PM
GRIZZLY47's Avatar
Feedback: 13 reviews
I did Nitro's internal sleeve, since their the only one that accommodate 35 spline axle shafts, and burned them in using Synergys instructions. I also did Artecs front truss kit for the added rigidity. Possibly a little overkill, but hey that's fine with me
2010 4-DOOR MOUNTAIN
GRIZZLY47 is offline
post #11 of 12 Old 08-03-2015, 02:36 PM
JK Timmay's Avatar
This! I am one of those who sleeved my axle thinking it was going to be bullet proof and it's still bent and broke.
Timmay
JK Timmay is offline
post #12 of 12 Old 08-03-2015, 03:20 PM
You don't want to use the hammer in sleeves after welding on the axle - they will never go in. It is already an intolerance fit. I don't even recommend gussets until after those sleeves go in.
Invest2m4 is offline
