Long road trips and flat tire - JKowners.com : Jeep Wrangler JK Forum
post #1 of 24 Old 07-30-2015, 11:14 AM Thread Starter
2014 Unlimited Miami's Avatar
What do you all do when you have large tires and stock Jack will not work and get flat tire out on the road?
RK 3.5 X-factor, Fox shocks, 18x9 XD, Nitto G2 285/75/18.
2014 Unlimited Miami is offline
post #2 of 24 Old 07-30-2015, 11:30 AM
StubEXrube's Avatar
Honestly... I generally make sure that any equipment or tools that I'm carrying are the correct ones for the job. Making sure that you have the right kind/ size jack before going on a road-trip is just common sense in the Jeep world.
So... after the fact... dunno. Work with what you have or rely upon someone to bail you out. Neither of which are very solid game-plans.
I would think that the stock piece of shit scissor-jack that you have, could at least be put up under your axle and opened up enough ( possibly with the addition of a block of wood) to be able to at least get it high enough to swap out the wheels.
StubEXrube is offline
post #3 of 24 Old 07-30-2015, 12:32 PM
I don't carry a spare. I care a very nice plug and repair kit.
Jeepylit is offline
post #4 of 24 Old 07-30-2015, 01:35 PM
White13JKUR's Avatar
well....
First and best option in my case....
Onboard ARB twin for air up after trail runs and tire repair. That and the odd soccer ball for the kids.
The ARB tire plug kit is awesome. Get this or one of the well made knock-offs (heavy duty metal tool - not the cheap plastic junk from slime.)
If I actually had to muscle off one of these 37" (heavy) nittos on beadlocks (also heavy), I would use the axle housing as the jacking point. For this I use the stock scissor jack and the AEV plastic block that came with my lift. Anything strong that is at least as high as the difference in tire/wheel radius should work. It would be the increase in tire radius that you are working against versus the lift or tub/frame height.
edit: what is cool about the aev block is that it is lightweight and is molded to and fits in the rear tool area under the rear cargo mat.
White13JKUR is offline
post #5 of 24 Old 07-30-2015, 01:35 PM
Victim Of Pain's Avatar
Stock jack is just fine for 35's and a 2.5 lift. That being said, my storage compartment was filled with 4 inches of rusty water and my jack is rusted to shit. So now it's hi-lift time until I replace the stocker.
Victim Of Pain is offline
post #6 of 24 Old 07-30-2015, 01:48 PM
why not a bottle jack or something? Unless the hi-lift is in plan anyway, not sure you'll get a tire off the ground with the typical (4') hi-lift.
post #7 of 24 Old 07-30-2015, 02:23 PM
Correct. I had a 2.5" lift and 37s and a 48" hi-lift under the rear bumper didn't get it. But the shocks were pretty long travel. Plus, the lack of stability for changing a tire makes it less than ideal.
Invest2m4 is offline
post #8 of 24 Old 07-30-2015, 03:36 PM
Just strap/chain the axle to the frame before lifting and it's cake
Scissor jack with a nut welded onto it works really fast in conjunction with an impact or drill as well.
Or this - http://www.amazon.com/Camco-57363-Le.../dp/B001V8U12M
aus-jeep is offline
post #9 of 24 Old 07-30-2015, 03:49 PM
I carry a chunk of 6x6 and a bottle jack. you could have a 12" lift and it wont have any bearing on getting a tire off the ground as I lift at the tire end of the axle I am lifting. I suppose if I was running something like 44" tires I might need to rethink but 35-37's no problem. A scissor jack will also work just not as nice as a bottle jack for me.
Jadmt is offline
post #10 of 24 Old 07-30-2015, 04:08 PM
Already own the hi-lift, I would only use at home with jack stands, no way am I trusting the hi-lift with no tire on...
post #11 of 24 Old 07-30-2015, 04:56 PM
maybe a taller bottle jack can do a good job. i dont own any bottle jacks but im sure they make ones that can reach the axle and dont take up too much real estate.
http://www.northerntool.com/shop/too...1777_200641777
17.75" max lift, 25lbs. i should actually pick this up for road use..
MISHIMOTO IS JUNK
chknkatsu is offline
post #12 of 24 Old 07-30-2015, 06:32 PM
nice jack.
looks like you would still need a block of wood for a 37" tire, which probably has a radius of ~18.5" with no weight on it.
post #13 of 24 Old 07-31-2015, 12:05 AM
it's a good idea to keep all your crap in at all times. I always have my hi-lift on the hood, but I never use it since I have a bottle jack and 4 2x4 scraps....the bottle jack is a harbor freight one for like $15 and I've been using it frequently for 5 years now when I'm too lazy to get out the big floor jack in my garage.
Scissor jacks are junk, no point in buying some overpriced AEV crap to use a garbage jack. I have a couple of them that are starting to collapse sideways with only a few uses within their limits. That said, mine (unused) is still in the jeep, but that's for after my bottle jack and hi lift stop working (right...)
lkjk is offline
post #14 of 24 Old 07-31-2015, 12:27 AM
Scissor jacks are fine if you don't overload them. Agree that I would not shell out cash just for the AEV block - it is well made and does serve a purpose. Mine came with their lift kit. If it wasn't for that, I would just use a block of wood.
good idea on the chain. still feel safer with the scissor jack for a tire change.
naaa.... don't need to weld no nuts... just hack up an old craftsman tool. back in the 1980's my mechanic buddies and I would just modify our old sets of craftsman tools (working set was of course snappy or mac). you gotta remove the spare tire under the hood to get at anything on an old Subaru so I came up with this in short order and it works great on scissor jacks too. it even doubled as a cigarette holder - smoked ciggies way back then.
post #15 of 24 Old 07-31-2015, 06:06 AM
TCdawg's Avatar
you strap the axle to the frame when using a hi-lift.
jack with the hi-lift, pull the old tire off and put it under the axle. Put new tire on. Done and fairly safe.
TC
TCdawg is offline
post #16 of 24 Old 07-31-2015, 06:09 AM
TCdawg's Avatar
I carry a hi-lift....and AAA
TC
TCdawg is offline
post #17 of 24 Old 07-31-2015, 02:31 PM
nice jack.
but you wouldnt be lifting at the exact radius of the tire. youd be lifting from the axle which would give you an extra 2 inches or so. this is probably your best bet.
MISHIMOTO IS JUNK
post #18 of 24 Old 08-01-2015, 07:31 AM
SoK66's Avatar
Get the AEV jack block, leave it in the rear cubby bin. Works fine with the cheesy stock jack, even with 37s. I'm not a fan of hi lift jacks, bulky, rattly & dangerous to use. Take along a bottle hack if you don't like that stock scissor
SoK66 is offline
post #19 of 24 Old 08-01-2015, 07:50 AM
Z-OR's Avatar
As with most good / useful / fun things... Dangerous, but not unsafe. ;-)
2016 JKU Sport
- 37" BFG MTs on 17x8.5 -6
Z-OR is offline
post #20 of 24 Old 08-01-2015, 01:17 PM
hi-lifts shouldnt be used to change a tire unless you really need to. I honestly hope i never need to use my hi-lift
MISHIMOTO IS JUNK
post #21 of 24 Old 08-01-2015, 08:15 PM
Why are so many of you guys spooked of hi-lifts
i use to chain my axle to my frame, jack up with hi-lift and disassemble my entire front end to change broken axle shafts and or birfields almost every weekend on my old toyota.
Its not a fashion show
Fueler is offline
post #22 of 24 Old 08-03-2015, 07:57 AM Thread Starter
I picked up a bottle jack and I will have a 6x4 block of wood. Thanks all for the suggestions!
post #23 of 24 Old 08-03-2015, 08:05 AM
TCdawg's Avatar
why would you use a hi lift if you didn't "really need to"?
They are also a damn nice tool if you have to break a bead on a wheel. Something as simple a fixing a torn off valve stem can be a bitch if you don't have a way to break the bead.
TC
TCdawg is offline
post #24 of 24 Old 08-03-2015, 10:12 AM
I'm the same way with the locker button.
If you use the scissor jack to lift the axle, that frees up the hi-lift for breaking the bead. Then again, someone else in your group might be able to just drive over the tire with their rig and less fuss.
I read about the high lift method and tried it out in the garage about the time I ordered beadlocks because I was wondering what it would be like busting a back side bead on the trail because I was contemplating the idea of carrying just the tire vs a full on rim with tire. It was a pain in the neck on a flat garage floor with the foot of the jack slipping on the tire and never getting a good enough "bite" to push the bead down off of the rim. I did not put a ton of effort into this and just gave up before self inflicting any unneeded injuries.
