Issue wiring Rigid Dually D2's to factory fog light switch... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 07-28-2015, 09:16 PM Thread Starter
I utilized the provided rigid harness which includes a relay. I wired the blue wire from the harness that would normally go to their switch and spliced it to the white with orange stripe wire from the factory fog light wiring. I then spliced both black ground wires and didn't use the red wire that would normally illuminate the switch. Splices were soldered and heat shrink tubed. Mounted the relay near the battery and connected the rigid harness to the positive and negative terminals on the battery. They turn on however when driving they cut on and off. I double checked that everything was tight and secure and the problem cannot be duplicated by wiggling the wires anywhere along the harness etc.
I called Rigid and they advised I purchase and install "warning cancellers" which appear to be anti flicker modules just before each light. Has anyone else had to do this when running the led lights through a relay? If I have to use the warning cancellers could I just ditch the rigid harness all together and power the d2's right from the factory wiring? Any suggestions are welcome.
Sean...
2014 Billet Silver JKUR
sjd78 is offline
post #2 of 6 Old 07-29-2015, 06:49 AM
bluewave's Avatar
That's because the factory lights use a pulsed can bus signal to turn on. This will burn the lights out real fast, you need to use a real switch. Rigids are not meant to be run on the street anyways
Texas Complete Truck Center
5670 S Interstate 35
New Braunfels, Texas
(210) 412-6379
bluewave is offline
post #3 of 6 Old 07-29-2015, 07:24 AM
People usually use the stock wiring to power the relay that then gets its power directly from the battery instead of running through the canbus system.
post #4 of 6 Old 07-29-2015, 08:29 AM Thread Starter
This is exactly what I'm doing. The stock wiring is being used to trigger the relay in the Rigid harness which gets power directly from the battery. However the lights still cut on and off.
sjd78 is offline
post #5 of 6 Old 07-29-2015, 08:31 AM Thread Starter
I'm using the factory wiring to trigger a relay that is powered by the battery. The factory can-bus isn't directly powering the lights. Also I don't plan on using the rigid's on the street. I just want to use the factory switch to trigger them.
sjd78 is offline
post #6 of 6 Old 09-29-2015, 02:07 PM
led fogs
has nothing to do with can bus
factory sends a pulse current even after jeep is shut down, maybe 20 extra seconds, you need a 6400u capacitator in the circuit to stop flicker
timb7734 is offline
