Any tips on swapping out a 6spd on a 07 JKU? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 07-26-2015, 05:27 PM Thread Starter
upalms's Avatar
Well it finally blew, so I'm going to pull it this weekend, seems pretty straight forward, but any insight would be appreciated. it has a Long arm in it so the cross member is from the suspension kit. Do I need to pull the TC or can I slide it back, I haven't really looked yet.
Todd
2007 Unlimited
Cree Light Bar
7.5 Long Arm Lift
Synergy Front Suspension
Artec Front JK Armor
5:13's
Tom Woods Drive Shafts
Hi-Lift & Much More
2000 TJ
6" lift
37 TOYO MT's on Worx Rims
$hitty Built bumpers
Air Raid
Corbeau Baja RS seats
upalms is offline
post #2 of 5 Old 07-27-2015, 06:51 AM
BeerMonkeY's Avatar
just changed the auto in my jeep, it was pretty easy using a lift, we did pull t-case, hardest part was removing the river raider skids since the bolt heads were all smashed to hell. can imagine not much different on a stick,just less wires.we took exhaust off to, we cut it where its straight along driver side and un bolted from manifolds, then i used a coupler and band clamps DONT use the shitty u bolt style clamps or it will never come off again and it will leak. the band clamps are more money but can come off and wont leak. i dont think we ran into any problems other than skid plate bolts.
'92 YJ
'13 WK2
BeerMonkeY is offline
post #3 of 5 Old 07-27-2015, 07:25 AM Thread Starter
upalms's Avatar
Thanks, I'm also hearing about the clutch and reservoir, anyone have any insight on that?
Todd
2007 Unlimited
Cree Light Bar
7.5 Long Arm Lift
5:13's
Hi-Lift & Much More
2000 TJ
6" lift
Air Raid
upalms is offline
post #4 of 5 Old 07-27-2015, 10:44 AM
SGT. Jackalope's Avatar
the slave is connected with two nuts and can be removed and moved out of the way. You wont have to mess with the res, the clutch system shares the brake res
2007 rubicon unlimited
SGT. Jackalope is offline
post #5 of 5 Old 07-28-2015, 07:18 AM Thread Starter
upalms's Avatar
Thanks Sarge!
Todd
2007 Unlimited
Cree Light Bar
7.5 Long Arm Lift
5:13's
Hi-Lift & Much More
2000 TJ
6" lift
Air Raid
upalms is offline
