Removing broken shaft from ARB - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 07-14-2015, 07:08 PM Thread Starter
i dont currently have a broken shaft but i've like to be prepared incase
so whats the best way to remove a broken shaft from an ARB locker? assuming i dont have a welder or a magnet on a stick. Does the arm off any room at all to stick something through the crosspin to knock the broken shaft out? is there a way to do this without removing the whole diff?
MISHIMOTO IS JUNK
chknkatsu is offline
post #2 of 7 Old 07-14-2015, 09:29 PM
bluewave's Avatar
Nooe, I have used a Matco magnet twice to do this on a d44
Texas Complete Truck Center
5670 S Interstate 35
New Braunfels, Texas
(210) 412-6379
bluewave is offline
post #3 of 7 Old 07-15-2015, 04:53 AM Thread Starter
interesting. ive heard mixed reveiws about using magnets. guess ill keep one in the jeep
post #4 of 7 Old 07-15-2015, 08:42 AM
elusive's Avatar
I had to cut the short side of the locker in half once. Alloy shaft was broke off and would not move. I cut it right behind the bearing to get the carrier out. ARB has fantastic customer service. They sent me the short side case half for $110.
elusive is offline
post #5 of 7 Old 07-15-2015, 10:50 AM
ledzep_06's Avatar
Depending on where the shaft breaks and how clean of a break it was has a great impact on the success rate of removing the broken shaft with a magnet. Its still worth it to carry a magnet with you, but its not a guaranteed way to get it out. You could try pulling the opposite axle and pushing the broken piece out with a small piece of rod.
ledzep_06 is offline
post #6 of 7 Old 07-15-2015, 01:21 PM
Research, bro!
RRauzer's Avatar
Did this with an ARB a couple of years ago. Used the stock antenna with the ball tip cut off.
"Are you gonna bark all day, little doggy, or are you gonna bite?" - Mr. Blonde
A proud part of the Cutts!
RRauzer is offline
post #7 of 7 Old 07-15-2015, 02:30 PM Thread Starter
i pray i dont ever have to do that
MISHIMOTO IS JUNK
