Trailing Arms w/ Coil Overs & Bypass Shocks - JKowners.com : Jeep Wrangler JK Forum
post #1 of 31 Old 07-14-2015, 04:53 PM Thread Starter
For those of you that don't follow Rock Krawler on facebook...
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.” - Jeremy Clarkson
wranglerblackout08 is offline
post #2 of 31 Old 07-14-2015, 05:36 PM
Ok so this might seem outa left field but...What tires are those!?!?
Biginboca is offline
post #3 of 31 Old 07-14-2015, 05:48 PM
BF Goodrich Baja T/A KR2 I believe
raf2379 is offline
post #4 of 31 Old 07-14-2015, 05:49 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Baja T/A KR2, aka, Hayzeus Christo How Much?
http://www.bfgoodrichracing.com/dese...h-baja-ta-kr2/
JKCTAZ is offline
post #5 of 31 Old 07-15-2015, 10:00 AM
wow thats purdy!
-Marc
Coming up:
14 Bolt rear ARB w/ 5.38
EVO Long Arm
40/42” MTR's
17" Spyderlock Beadlocks
post #6 of 31 Old 07-15-2015, 10:42 AM
gt1guy's Avatar
Is that still a prototype or production?
Kevin
gt1guy is offline
post #7 of 31 Old 07-15-2015, 11:27 PM
I'm no engineer, but isn't that going to put a ridiculous amount of pressure on the crossmember? More because there are two mounting points on the axle side, exerting more leverage than a standard 3 link? Again, no engineer. I'm assuming you can't run a 3 link without a track bar in this case since they are trailing arms?
lkjk is offline
post #8 of 31 Old 07-16-2015, 12:39 AM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Take a wee closer look at the center link, they have it connected to not one, but two crossmembers. If you tear that off, you drive like shit, or you are fucked anyways because you're rolling down the side of a mountain.
Last edited by JKCTAZ; 07-16-2015 at 01:20 PM. Reason: Crossmbers is not the same as crossmembers. Future reference. :D
JKCTAZ is offline
post #9 of 31 Old 07-16-2015, 09:12 AM
Originally Posted by JKCTAZ View Post
Take a wee closer look at the center link, they have it connected to not one, but two crossmbers. If you tear that off, you drive like shit, or you are fucked anyways because you're rolling down the side of a mountain.
Well, that sums it up. We would not be able to use those words exactly, but that is good...
Yes, there is no track bar in this system at all in the rear and the rear pinion cycle is correct.... There are a lot of wishbone or triangulated kits out there coming from the back that yield pinion changes that are not desired...
RK
post #10 of 31 Old 07-16-2015, 09:13 AM
The system is very close. We are still playing with the (2) rear coils to get the transitions right. Other than that, it is a go. We have broken a lot of stuff in testing this kit to ensure when you get it, it will not happen to you!
RK
post #11 of 31 Old 07-16-2015, 01:15 PM
RK
Is the crossmember mount the same as in your standard 3-link kits?
Brian
12 JKU Rubicon
Poison Spyder Armor
40" Nitto M/T's on TrailReady Beadlocks
RJ60vxr/RJ70 axles / King Coil-overs front / King Shocks & Plushride Springs rear / Genright Cage/ PS Armor
baileyjb74 is offline
post #12 of 31 Old 07-16-2015, 01:55 PM
Yes....
post #13 of 31 Old 07-16-2015, 02:18 PM
gt1guy's Avatar
Is that a mono-ball or a bushing at the frame end of the trailing arm?
Kevin
gt1guy is offline
post #14 of 31 Old 07-19-2015, 06:04 PM
gt1guy's Avatar
Any chance of a pic of that 4 door from the rear?
Kevin
gt1guy is offline
post #15 of 31 Old 07-20-2015, 06:34 AM
It is a Pro Series Krawler Joint at the Frame connection and a welded tube version at the axle end..
I can see if the owner can get us an image of it from the rear. It looks nasty!
RK
post #16 of 31 Old 07-20-2015, 06:46 AM
kjeeper10's Avatar
Awesome build !!!!!
kjeeper10 is offline
post #17 of 31 Old 07-20-2015, 10:26 AM
MattPM0000's Avatar
Kevin
Too much to list but never enough.
MattPM0000 is offline
post #18 of 31 Old 07-20-2015, 10:29 AM
MattPM0000's Avatar
I'll upload more after work when I can resize the images.
post #19 of 31 Old 07-20-2015, 10:55 AM
MattPM0000's Avatar
post #20 of 31 Old 07-20-2015, 10:57 AM
MattPM0000's Avatar
post #21 of 31 Old 07-20-2015, 10:58 AM
MattPM0000's Avatar
post #22 of 31 Old 07-20-2015, 11:27 AM
gt1guy's Avatar
Thanks for the pics. Is this your Jeep?
Kevin
gt1guy is offline
post #23 of 31 Old 07-20-2015, 11:52 AM
manuel's Avatar
Nice looking rig man are those custom ps corners?
Mine :Build 2008 Rubicon unlimited black on black
Wife's :2014 All white Rubicon unlimited (mall crawler)
manuel is offline
post #24 of 31 Old 07-20-2015, 12:07 PM
MattPM0000's Avatar
Yeah, it's mine.
Yes, they are a custom 3 inch stretch corner from Poisons Spyder.
post #25 of 31 Old 07-20-2015, 03:46 PM
gt1guy's Avatar
Looks like your the best person to ask how it works then. Obviously the design leans more to the go-fast side of things, but how does it work in the slow stuff where articulation comes into play? Anything you wish it did better?
Kevin
gt1guy is offline
