Vented hoods - JKowners.com : Jeep Wrangler JK Forum
post #1 of 105 Old 07-14-2015, 12:02 AM Thread Starter
Vented hoods
I have a 2013 Sahara unlimited. Do you think it's worth the money for the vented hood? I know it looks nice but is there any other perks?
Cameronritz is offline
post #2 of 105 Old 07-14-2015, 04:45 AM
i'll just leave this here. Heat soak is the biggest worry on the JK/JKU as it can result in plastics and hoses decomposing or dry-cracking earlier than they should. I found great benefit in my '11 JKUr by installing these (easy) great,light,good-looking &functional louvers on it's hood th first month I owned it. In the South, black JK and summer then add slow crawling for 6-8 hours at a time? I couldn't touch the hood after doing so. I installed these & can literally see the heat being evacuated. do it & if you're in an auto install an aux tranny cooler aside from the factory's as both are no brainers.
post #3 of 105 Old 07-14-2015, 04:48 AM
Bumpstick's Avatar
I know it helps here in Florida with temps. Due to the mud it's best to keep the inner fender liners in. I know guys out west pull there's out to help with under hood temps.
It gives that hot air that has passed through the radiator somewhere to go. When off-road the slow speed doesn't push that air out and it just sits, trapped under the hood.
Bumpstick is offline
post #4 of 105 Old 07-14-2015, 06:28 AM
JKO Dickhead
Asmmns's Avatar
Yes.
Same here... after a half day of crawling in the heat I almost torched my hand by placing it on the hood.
Never had an issues with water and the heat is visible leaving the hood.
My plan was additional fan to help with pulling the heat out, but never installed it as the venting works pretty damn good.
__________________
CURE SMA !
Asmmns is offline
post #5 of 105 Old 07-14-2015, 06:33 AM
bluewave's Avatar
http://i300.photobucket.com/albums/n...psf7318dc1.jpg
Totl hoods from Alan seem to be pretty sweet! Not that I got one or anything
Texas Complete Truck Center
5670 S Interstate 35
New Braunfels, Texas
(210) 412-6379
bluewave is offline
post #6 of 105 Old 07-14-2015, 07:03 AM
absolutely correct.
post #7 of 105 Old 07-14-2015, 07:13 AM
Bumpstick's Avatar
I run the Rugged Ridge hood louvers right now. But will be installing a pair of Run Cool (hood louvers.com) louvers installed above the battery and master cylinder with small electric fans pushing air out of them.
The only water issue I have had was a deep water crossing where the water went over the hood and a little water got into my transmission via the breather tube. Since then all my breather tubes have been relocated inside my Jeep. But that most likely would have happen with out the louvers too.
post #8 of 105 Old 07-14-2015, 10:02 AM
JeepnPokey's Avatar
All the above info is spot on!
I'm running the Synergy louver, and its great. Like stated above you can see the heat coming through the louver. I know here in AZ it gets toasty specially on a trail, moving at super sonic speed (Balls SLOW) it does great. Never have had any over heating problems. They are well worth it, my .02.
OIF
JeepnPokey is offline
post #9 of 105 Old 07-14-2015, 10:47 AM
Z-OR's Avatar
what happened to the Synergy louvers?
check the site and they appear to be.... gone.
2016 JKU Sport
- 37" BFG MTs on 17x8.5 -6
Z-OR is offline
post #10 of 105 Old 07-14-2015, 11:48 AM
JeepnPokey's Avatar
We must summon Synergy, or Poly to find out why
That is a little weird yet... Wonder if they are coming out with a new(er) style or something!?
OIF
post #11 of 105 Old 07-14-2015, 01:32 PM
poison spyder makes a nice one pretty affordable too. Only down side is that you have to cut he hell out of the hood pretty tedious install.
dave22 is offline
post #12 of 105 Old 07-14-2015, 01:54 PM
bigworm36's Avatar
This is next on my mod list being out here in az probably should have done it sooner
bigworm36 is offline
post #13 of 105 Old 07-14-2015, 08:57 PM
getting the psc louver mounted this week. Now that my commute sucks and in stop and go traffic the heat is nuts.
lkjk is offline
post #14 of 105 Old 07-14-2015, 09:17 PM
Ringer's Avatar
Vented hoods
Custom louvered my factory hood. It does well and is different. I like that it is subtle.
Ringer is offline
post #15 of 105 Old 07-14-2015, 09:47 PM
gt1guy's Avatar
Wow. That did come out looking great. Looks factory.
Kevin
gt1guy is offline
post #16 of 105 Old 07-15-2015, 05:51 AM
JKO Dickhead
Asmmns's Avatar
Originally Posted by Asmmns View Post
Yes.
This was for the synergy louver, the poison spyder is similar. They each offer a few cut options. I went all out and removed the most material and a majority of the crossmember under it. The louver adds back some of the rigidity lost by the removal of the crossmember
__________________
CURE SMA !
Asmmns is offline
post #17 of 105 Old 07-15-2015, 08:11 AM
sixstring's Avatar
That looks great, I wish I could do something like that without it looking like crap
sixstring is offline
post #18 of 105 Old 07-15-2015, 09:03 AM
bigworm36's Avatar
How do people like the poison spyder hood vents thinking about ordering one
post #19 of 105 Old 07-15-2015, 01:17 PM
Descent's Avatar
Love the PSC
Installed with dual Spal pushers
Dumps a ton of hot air out vs. passive venting alone.
Descent is offline
post #20 of 105 Old 07-15-2015, 02:44 PM
bigworm36's Avatar
Originally Posted by Descent View Post
Love the PSC
I love that, did you wire those in on a separate switch.
post #21 of 105 Old 07-15-2015, 02:47 PM
Love the PSC
that's awesome. great idea
MISHIMOTO IS JUNK
chknkatsu is offline
post #22 of 105 Old 07-15-2015, 03:56 PM
Descent's Avatar
Just run them through the SPOD.
Descent is offline
post #23 of 105 Old 07-16-2015, 05:33 AM
DaK
Will soon be going with an AEV hood for all the above listed reasons.
DaK is offline
post #24 of 105 Old 07-16-2015, 06:02 AM
One of the best mods I have done to my JKU. Like previously stated, you can see the heat just rolling out when you come to a stop.
makeos is offline
post #25 of 105 Old 07-16-2015, 10:28 AM Thread Starter
What hood is on this jku?
