Stand alone tranny cooler and temp ? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 20 Old 07-09-2015, 07:35 AM Thread Starter
BeerMonkeY's Avatar
Whats everyones tranny run at temp wise? wondering if mine is running warmer than it should be. i only have a aftermarket cooler in front of a/c condenser, no oem cooler. and can anyone suggest a better cooler i can run?
'92 YJ
'13 WK2
BeerMonkeY is offline
post #2 of 20 Old 07-09-2015, 08:51 AM
TCdawg's Avatar
The aftermarket like a Hayden or B&M that sits right there in front of your radiator should work just fine. I know a ton of JK guys that run one brand or another in that position.
Shoot, Mine is actually between my SC intercooler and the radiator and I have no trans heat problems.
I can't remember exactly what temp is but 165 to 175 comes to mind for mine. I have not had my Diablosport hooked up in quite a while to read the gauge...I should, just to check it.
TC
TCdawg is offline
post #3 of 20 Old 07-09-2015, 08:54 AM
On my '07 I used a Ford SD std cooler...worked great and was free except for the AN fittings.
CT Performance, Inc is offline
post #4 of 20 Old 07-09-2015, 03:28 PM Thread Starter
BeerMonkeY's Avatar
ok mine runs around 170-180 , 200 pulling a large hill with camper in tow. we have a bunch of those ford coolers as my boss likes to collect super dutys, maybe ill add one to my b&m 70268 cooler just to be on the safe side
'92 YJ
'13 WK2
post #5 of 20 Old 07-09-2015, 03:49 PM
ronjenx's Avatar
170-180 , 200 pulling a large hill with camper in tow isn't bad at all. However, the cooler you can keep it, the longer the transmission and fluid will last.
I have done a few things to mine, and it stays in the 90F to 130F range under almost all conditions.
You do have an OEM cooler, btw. Pre-2012 JKs have a small one at the bottom of the A/C condenser. It's too small, and is blocked by the bumper. 2012+ JKs have a larger cooler mounted in the direct airflow through the grill. It's more like an aftermarket cooler.
ronjenx is online now
post #6 of 20 Old 07-09-2015, 03:52 PM
Mine runs 130 - 145, I don't tow anything. But that is normal temps just running around town. Rock crawling or climbing hills it gets around 180 - 195.
post #7 of 20 Old 07-09-2015, 03:58 PM Thread Starter
BeerMonkeY's Avatar
what have you done?
i have a oem cooler but its not hooked up, i wrecked it a few years ago and i lost a oring that goes on a/c condensor/tranny lines and according to 3 dealers you cant buy them so i bypassed the whole thing.
'92 YJ
'13 WK2
post #8 of 20 Old 07-09-2015, 03:59 PM Thread Starter
BeerMonkeY's Avatar
im just worried as i put in a new to me tranny yesterday sincemy orginal one (with 90k) broke.
'92 YJ
'13 WK2
post #9 of 20 Old 07-09-2015, 04:25 PM
ronjenx's Avatar
what have you done?
OK. I see what you meant about not having an OEM cooler.
Go to this thread to see what I have done to cool all the stuff under the hood; engine, transmission, electronics, intake air, etc..
OEM Mechanical Fan Retrofit
post #10 of 20 Old 07-09-2015, 04:59 PM Thread Starter
BeerMonkeY's Avatar
i remeber that thread now, my only concern would be water crossings.
'92 YJ
'13 WK2
post #11 of 20 Old 07-09-2015, 08:15 PM
bigworm36's Avatar
I was just looking at mine thus weekend using the torque app and it was right around 160 f with a tranny cooler
bigworm36 is offline
post #12 of 20 Old 07-11-2015, 03:36 PM
wranglerx5169's Avatar
Transmission Over Temperature Code P0218
I just started getting a transmission code coming on P0218 stating that the Transmission Over Temperature Condition...which I have never received before.
My jeep has a 6in Longarm kit on and I am running 40in Tires. Never had this issue as I have had my 40's on since Sept of 2014...I recently drove the jeep, honestly 5 miles after it sitting for 4 hrs, and the engine light came on. Curious what would be causing it as its not under load.
AFE cold air intake, MBRP exhaust and aftermarket headers...but why is my transmission overheating...I dont get it.
I am looking into a Mishimoto Transmission Cooler right now as we speak...just want to get some ideas.
Let me know what you guys have experienced!!!
Thanks,
Nathan
Nathan Grizzoffi
(THE ZOMBICON JK)
wranglerx5169 is offline
post #13 of 20 Old 07-11-2015, 09:28 PM
bigworm36's Avatar
I over heated my tranny oil but that was with 37s going up some steep inclines with 410s but put in a tranny cooler and never had a problem since
post #14 of 20 Old 08-15-2015, 04:18 PM
07unlimitedx's Avatar
Has anyone put a tranny cooler on the 2012-2015's? I was wondering about this. I'd rather have one and no over heating issues than have some.
07unlimitedx is offline
post #15 of 20 Old 08-15-2015, 04:24 PM
mud2moab's Avatar
after a few complaints to my jeep dealer about the trans. overheating, they added a cooler at no charge. they said that they new it was a problem, but didn't want to issue a recall.
mud2moab is offline
post #16 of 20 Old 08-15-2015, 04:30 PM
mud2moab's Avatar
I installed an ORW cooler on my 2010 solved all of my problems.
I just put an LS3 and 6l80 in my 10 model and don't need the cooler.
I would gladly part wit it for 200.00 plus shipping.
mud2moab is offline
post #17 of 20 Old 08-15-2015, 04:42 PM
Mines a 2014 and I've just been watching the temp guage... just would like a little bit lower. I'm going to Moab next month so just being proactive.
post #18 of 20 Old 08-15-2015, 06:08 PM
ronjenx's Avatar
As mentioned a few posts above, the 2012+ JKs already have an aftermarket-type cooler on them.
post #19 of 20 Old 08-15-2015, 08:39 PM
re: Stand alone tranny cooler and temp ?
I have a B&M for 8800lb GVW vehicals w/ the plates instead of fins on my `11 . It was one of the firs things i added and per the superchips diagnostics, my temps range from 135 to 185 depending upon what season & how long she`s been idling in the sun ( black JKU) or if this is mid-Winter night and she`s just started to get heated-up. Generally , my opinion is `if it`s an automatic; cooler + aux and if need-be add a spahl puller .....`
this is one of my Jeeps of the two I have & five I`ve owned. My other present Jeep is an XJ that is at 380k original miles & will see 500k. Just to show I am kinda into Jeeps I will attest to heat being the one true killer of everything if you let it be. hope you get my drift & it helps
post #20 of 20 Old 08-15-2015, 10:16 PM
White13JKUR's Avatar
don't have any answers here but I saw some nice Jeep logoed gauges recently on the autmometer web site. Here's the trans temp gauge in case it is of interest.
http://www.autometer.com/2-1-16-tran...like-2552.html
White13JKUR is offline
