Looking for an upgraded Tie rod that will fit behind 15" wheel - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 07-07-2015, 07:32 AM Thread Starter
All of them i've found say you need a minimum of a 17" wheel to clear. Anyone have a suggestion?n My wheels have 3.5" of backspacing.
Red04Cobra is offline
post #2 of 6 Old 07-07-2015, 08:02 AM
kjeeper10's Avatar
That's tough. Synergy will fit some 15's. The older RK tie rod did.
kjeeper10 is offline
post #3 of 6 Old 07-07-2015, 08:22 AM Thread Starter
That's pretty much where I got to as well. I'm worried that the Synergy won't fit either.
post #4 of 6 Old 07-07-2015, 09:19 AM Thread Starter
I do wonder if you could use an aftermarket tie rod and the use stock or smaller tie rod ends?
post #5 of 6 Old 07-07-2015, 11:02 AM
JKO Dickhead
Asmmns's Avatar
Look for the original Rock Krawler aluminum HD tie rod. Contact them if need be. Jeremy and the entire squad over there are very helpful
after the stock one looked like spaghetti went this route and never looked back.. Has taken a severe beating and clears fine !
__________________
CURE SMA !
Asmmns is offline
post #6 of 6 Old 07-07-2015, 12:03 PM
FuLcRuM's Avatar
yeah RK HD tie rod that uses the factory drag link ends.
That's what I ran with 3.5" bs 15" rims, close but clears fine.
Jeepless
FuLcRuM is offline
