Junkyard axle tech help - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 07-01-2015, 07:39 AM Thread Starter
Question Junkyard axle tech help
OK so yesterday I started looking at what the heck I am going to be doing on the D60 front. It is a 1985/86 Ford Dana 60 Kingpin front. I only have the inner c's so need to do from the kingpin out. I want to go with the Reid knuckles, or other high steers if someone recommends another. I have hit a wall and need assistance from the people who have done this. I have the ford knuckle with the Ford spindle, but for the life of me cannot find a Ford wheel hub to work with them. Is everyone else having this issue? I didn’t think I would. My second option is to run GM/Dodge knuckles and out. I have the gm/dodge spindle, gm/dodge wheel hub. Please help and advise what you did. Pictures links... I have been searching for a solid day and am stumped.
P.S. I am learning as I go and thought I would be ok with unit bearings but immediately corrected my mistake.
-Marc
Coming up:
14 Bolt rear ARB w/ 5.38
EVO Long Arm
40/42” MTR's
17" Spyderlock Beadlocks
post #2 of 13 Old 07-01-2015, 07:48 AM
notajerryskid's Avatar
Throw a pic up of what you have. The spindles are easy to find. Go on Pirate 4x4 there are usually some for sale.
You do not need new knuckles to run a high steer kit. However. If you do run a true High steer you will be notching out the frame on the passenger side.
There are lots of us on here that have done this swap. However it is not as easy as it looks and plan on it taking a while to finish.
Solid also make knuckles.
notajerryskid is offline
post #3 of 13 Old 07-01-2015, 07:54 AM Thread Starter
Time is what I have! I pick the axle up this weekend so I have nothing as of yet. I can get the Solid Knuckles instead of the Reid and save a few pennies, and the spindles I was going to go with either G2 or Yukon. I just dont understand why i cannot find Ford wheel hubs. even when you search for them you STILL come up with the GM/Dodge ones.
-Marc
Coming up:
EVO Long Arm
40/42” MTR's
post #4 of 13 Old 07-01-2015, 08:17 AM
Dutchboy101's Avatar
Here is my list for my 1990 Kingpin. Don't let my wife see the prices.
$240 #2 Summit * 2x Axle Bearing and Seal kit for Dana 60
$100 #2 Amazon * 2x Dana 60 inner front spindle bearing & seal kit.
$206 #2 Amazon * 2x Replacement king-pin kits for Dana 60 (pin, bushing, seals, bearings, spring, cap).
$300 #1 Ebay * Yukon Master Overhaul kit for Dana 60 and 61 front differential
$355 #1 Amazon * Yukon Hardcore Locking Hub set for Dana 60, 35 spline. '78-'97 Ford
$570 #1 Amazon * Yukon Chrome-Moly Superjoint Dana 60 kit
$85 #1 Amazon * Yukon 4340 Chrome-Moly replacement inner axle for Dana 60
$250 #1 Amazon * Yukon 4340 Chrome-Moly replacement inner axle for '88'-98 Ford Dana 60
$630 #1 Summit * Yukon Grizzly Locker for Dana 60, 35 spline
$150 #1 Amazon * Yukon 4340 Chrome-Moly 35-spline replacement outer stubs for Dana 60, '77 and newer Ford
$191 #1 Amazon * USA Standard replacement Ring & Pinion "thick" gear set for Dana 60 Reverse rotation in a 5.13 ratio
$350 #1 JK6013 *Artec Truss / Brackets (JK 1 TON-3LINK)
$56 #2 HS6080, *Artec >>D60 Knuckle Bolt Kit
$159 #1 RR-D60200K *Artec >>D60 Bronze Upper KP Bushings (set)
$285 #1 SK1401 *Artec Tie rod/Drag link kit
$319 #1 HSA-601 *Ballistic High Steer Kit
$336 #1 GLDB99 *www.Lugnut4x4.com Calipers/rotors FRONT
$111 #1 MC391385 *Rockauto.com Raybestos Master Cylinder
$137 #1 B4WK1008 Barnes 4WD Diff Cover
Dutchboy101 is offline
post #5 of 13 Old 07-01-2015, 08:21 AM
Hope that helps, BTW. I am reusing the stock knuckles.
Project should be done next week.
post #6 of 13 Old 07-01-2015, 08:37 AM Thread Starter
thank you! that helps a lot!!! what about spindles and wheel hubs attached to the stock knuckles? Also how do you feel about the grizzly up front? I am still debating on that. what are the benefits/draw backs of it?
-Marc
Coming up:
EVO Long Arm
40/42” MTR's
post #7 of 13 Old 07-01-2015, 11:56 AM
you can reinforce the knuckles using several different kits. I gave it a go and for 75.00 I will continue to use the stocks. I did not want to pay the 500 for knuckles if I don't have to. So far they have held up great!!
post #8 of 13 Old 07-01-2015, 12:01 PM Thread Starter
awesome and i will look in to it. did you buy your front with complete outers? I am still having an issue with getting hubs for the spindle. I really have no idea why i cant find them and it is bothering me! haha
-Marc
Coming up:
EVO Long Arm
40/42” MTR's
post #9 of 13 Old 07-01-2015, 03:53 PM
Mine was a complete axle.
post #10 of 13 Old 07-02-2015, 06:31 AM Thread Starter
I might have to do that and get a complete axle. I held off on buying the d60 i was going to just because i am having so many issues piecing together the knuckles, spindles and hubs for the ford d60 kingpin....
-Marc
Coming up:
EVO Long Arm
40/42” MTR's
post #11 of 13 Old 07-07-2015, 09:01 AM Thread Starter
A couple questions for you! I will probably have more! The master cylinder that you posted. this is stock? did you have to replace it because yours was bad? why change to this one.
Ballistic highsteer kit. Which package did you get? I am not running hydro as of yet so i dont need both high steer arms.
calipers and rotors for the front, did you convert to the 3/4 brakes? I would think having the larger stock brakes would be better, but see that shedding a few pounds will help.
-Marc
Coming up:
EVO Long Arm
40/42” MTR's
post #12 of 13 Old 07-07-2015, 01:55 PM Thread Starter
Also... here are the shopping lists for the two axles. Please tell me what you would change or replace, also if you have a build sheet post it up so i can compare!
D60 Front
Front Axle -- $400-600
Artec Dana 60 Swap Kit -- $465
G2 5.38 Gears -- $226
Dana 60 Master Install Kit -- $163
Kingpin rebuild kit -- $180
Warn Manual Locking Hubs 35 Spline -- $240
ARB Locker 35 spline -- $1200
Drag Link and tie rod -- $290
Knuckle Bolt Kit -- $28
Chromoly Axle Kit w/ U-Joints -- $750
Bronze Upper Kingpin Bushings -- $160
Dana 60 Spindle Seal Kit -- $37 x2
Wheel Bearing and Seal Kit -- $130
Differential Cover -- $65
Diff Cover Gasket -- $22
Ballistic High Steer Ends
Dana 60 Options
Reid Racing Knuckles Kingpin -- $660
Spindle Studs -- $12
14 Bolt Rear
Rear Axle – $400-500
Artec 14 bolt swap kit -- $350
Pinion Guard -- $66
Wheel Studs-- $64 (16 studs at $4 each)
G2 5.38 gears -- $256
14 bolt Master Install Kit -- $162
Rear wheel bearing kit -- $48
Differential Cover -- $94
Differential Cover Gasket -- $22
ARB Locker 30 spline -- $1200
Differential Pinion Yoke -- $120
14 bolt Brake options (most likely going with a rear that has factory disc brakes)
Rear Disc Brake conversion Kit (brackets, calipers, rotors, etc.) -- $535
Rear ABS kit -- $75
Or
Rear disc brake and ABS conversion -- $210
Right Caliper -- $34
Left Caliper -- $34
Brake Pads -- $43
Rotors -- $76
-Marc
Coming up:
EVO Long Arm
40/42” MTR's
post #13 of 13 Old 07-07-2015, 02:12 PM Thread Starter
Also just came across this for the steering with knuckles! don't know if this is worth a shot as the guy said it would work.
http://www.ebay.com/itm/CHEVY-FORD-J.../261635461318?
-Marc
Coming up:
EVO Long Arm
40/42” MTR's
