3.8 replace doublecheck - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 06-24-2015, 04:09 PM Thread Starter
snaggy's Avatar
When swapping an 08 3.8 engine from a manual trans JK INTO an 09 with an auto trans, other than installing flexplate in place of the flywheel and removing bushing in end of crankshaft, any other roadblock I am missing?
Will the 09 auto ECU cooperate?
Thanks just need a sanity doublecheck!
LoD front Ace Engineering rear Xenon fenders Rockhard skids EVO Rockstars Mickey Thompson Classic Beadlocks Goodyear Fierce Attitudes Spending as fast I can!
snaggy is offline
post #2 of 2 Old 06-26-2015, 08:19 AM
JKUWarthog's Avatar
Not sure about the ecu might need to be flashed. Check the main harness plug. you might have to swap it over from the old motor to the new one so that they match up. I went auto to manual no problem though so I dont think the ECU should be an issue. The motor doesn't care what its hooked up to just as long as something is telling it what to do.
"Nothing in this world can take the place of persistence.
Talent will not; nothing is more common than unsuccessful men with talent.
Genius will not; unrewarded genius is almost a proverb.
Education will not; the world is full of educated derelicts.
Persistence and determination alone are omnipotent.
The slogan "press on" has solved and always will solve the problems of the human race” -Calvin Coolidge
JKUWarthog is offline
