2 codes jeep wont run - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 06-19-2015, 04:44 AM Thread Starter
Canadian-Jku's Avatar
Guys last night after finishing up programming with my new super chips and installing my new stereo I started the jeep up to go fill it up with gas which is about half a mile from my house.
got to the station put $40 worth in the tank which gave me 3/4 tank full
I start the jeep up and go to leave and the traction control light start blinking I then loose my speedo all together traction control kicking in full tilt transmission start shifting gears really hard motor is cutting out power like it does for traction control, I make it the half mile home turn jeep off start it back up I lost speedo and gas guage gas light it on then the jeep dies and will no run at all anymore.
I have two codes and it wont let me remove them with my scanner there permanent freeze frame codes need dealer to remove them and they are
P0465 Generic Fuel level sensor A circuit high input
P1457 Chrysler Fuel tank pressure sensor circuit high
So what I am curious about is how this system correlates with the ecu and speedo and such?
I bought the sueprchips two days ago, changed my gear ratio and tire size and pressure drove it two days ago for about an hour then last night I reset the jeep to factory removing the superchips flashcal.
I then switched my stereo from 130 to the 730N got it working and then programmed the jeep again and went to get gas.
does the stereo have something to do with it? is it a fluke? could the tipm have randomly shit the bed at the same time I changed the program?
tried pulling battery terminals to clear the codes no go tried using sueprchips no go tried with my scanner no go jeep is stuck at end of the driveway now dead wont even sputter there no fuel pressure and gas guage reads zero.
seems like its some sort of safety thing? not sure its weird that it drove fine two days ago when I put a 1/4 tank in it and went for a cruise and now I put more gas in it and it shits the bed
got any ideas on either where to look or how the system actually communicates?
cheers
2012 JKU, shaved 14/SD60hp locked/spooled, 4 link Front 3 link rear, ORis all around, D3 all over, 42" SX2 tires, 20" Trail ready HD double beadlocks, PSC Full hydro
Canadian-Jku is offline
post #2 of 9 Old 06-19-2015, 05:31 AM
bluewave's Avatar
Did you have a battery charger on the jeep while programming? You may have bricked the computer
Texas Complete Truck Center
5670 S Interstate 35
New Braunfels, Texas
(210) 412-6379
bluewave is offline
post #3 of 9 Old 06-19-2015, 06:06 AM Thread Starter
no charger during the programming...
post #4 of 9 Old 06-19-2015, 07:22 AM
warcop's Avatar
Send a message via Yahoo to warcop
Did you install an interface with your radio or wire the radio directly into the factory wires? If it is the latter that could be your problem. Some radios require an interface to keep it from interfering with your CANBUS some suggested models are on this post: https://www.jkowners.com/forum/showthread.php?t=86848
Warcop
2012 JKU Sport, Rock Krawler 2.5 Flex, Smittybilt SRC Side Armor, Mesh Grille MOD, Sony Double DIN AV Receiver, Back up Camera, Kicker Speaker Upgrade, ARB Twin Compressor, Dominion Off Road High Lift Mount, Homemade Paracord Grab Handles, Nitto Trail Grapplers, Paramount Rear Bumper with Tire Carrier, KC Hilites Daylighters, under seat lock box, Metal Cloak Front Bumper, BARTACT Seat Covers, BARTACT Sun Shade, x20 Comp Winch, sPOD, ARB Air lockers, 4.10 Gears.
warcop is offline
post #5 of 9 Old 06-19-2015, 08:11 AM Thread Starter
I had the radio with satellite and hands free and everything in it already not the base base model and now installed the 730N
some people have said I need to flash the stereo and teach it my vin for it to fully communicate with the canbus system... weird that I lost fuel pump though
post #6 of 9 Old 06-19-2015, 10:11 AM
jims68's Avatar
I would put the old radio back in and see if you can get everything working again. The radio is an integral part of the CanBus system now and can cause some weird problems since it seems every year is a new software version. One problem with the after market tuners and canned tunes is they sometime mess with the checksum calcs that complete at the end of a program cycle. If they have bugs where the programs will not complete they massage the program to get them to work. Only problem is when you revert back to the original tune these bugs are still there and can cause problems especially when using EFI Live. This most likely isn't your problem here but should be considered when using canned tunes by whom ever. I changed my TCM tune and could not download the tune back into the transmission because of this. EFI Live had to correct the check sum bug before it would work and told me this is a common problem. Now this is a LS so your tune would be completely different and if this occurred would be much harder to correct. Most likely you would not see this unless you used a different programmer and made changes but from what I was told other weird things do happen. If the radio does nothing I would next try to reload the stock original program and get it all back to original, then start to find out what your error codes are. Get it to a state where you are sure what it is telling you is not corrupted. If you did happen to brick the ECM you should have little to none success accessing the ECM any more. Maybe it is a coincidence the codes you are seeing now did occur but the timing is terrible with the other changes you made. They have no close relation to each other. From re reading your first post it sounds like you can not even access the CanBus any more with FLashscan? If so not good! You may need to have a Chrysler scanner to see if the CanBus is even there anymore. I would still put the other radio back in and see what happens. Let us know what you find and any other details you may recall.
2008 Sahara 2011 LS5.3 6spd. auto 30/44, 35" NITTO's, 4.10 gears with TrueTracs front and rear, 3.5" Metalcloak game-changer ARB, front track bar drop and drag link flip steering box cross brace to passenger frame rail, PSC pump and reservoir. EFI Live tune on motor.
jims68 is offline
post #7 of 9 Old 06-19-2015, 10:39 AM Thread Starter
Not sure I fully follow you here or not haha
currently I can still plug in my flashcal and my lonova obd2 scanner and read codes and change axle ratio and such but these 2 codes im seeing are active live freeze frames so my reader isn't powerful enough to remove those you need Witech from the dealer
a lot of people I have called today including dealers, superchips, BNG Chrysler specialists are all saying start by removing my flashcal setting back to stock then swap stereos then clear the two codes then try and program it and see if the jeep will start again... oh and check fuses haha
post #8 of 9 Old 06-20-2015, 04:21 AM
warcop's Avatar
I installed the Scosche interface with my new radio install. If it turns out the radio is your issue I do not recommend the Scosche interface. Every time the battery is disconnected the interface needs to be re-matched with the system. Based on where it is installed this requires me to remove the dash.
Warcop
warcop is offline
post #9 of 9 Old 06-21-2015, 09:10 PM
jims68's Avatar
Just a lot of random thoughts like I was trouble shooting my own jeep. I jump around a lot haha! You answered the ECM question that it is not bricked or dead. If you can access it yet you are most likely in the clear there. Get it back to where it was before all of this started then just make one change at a time. Good Luck!
jims68 is offline
