?What tires for my new lift? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 06-07-2015, 07:55 PM Thread Starter
Just got a 3' rancho lift kit for my jku and am looking to buy a new set of tires. I want to go with 35's but I dont really want to spend hundreds of more $$ for a tuner,regearing and all that stuff. If i went with 33's would I have to regear or adjust the speedometer? Im just trying to find a good cost effective way to get some bigger tires.
jkpenneys is offline
post #2 of 8 Old 06-07-2015, 07:57 PM
Will Scarlet's Avatar
I bet if you search you'll find the answer to your question.
2011 Sahara Tan Rubicon 6 Speed
TR HD17 Beadlocks, BFGoodrich A/T KO2 34x10.50R17, Teraflex HD Tire Carrier, Clayton 2.5" Overland Plus Lift, and more to come...
Will Scarlet is offline
post #3 of 8 Old 06-07-2015, 08:04 PM
WTF did you waste money on a 3" lift if you just want to run 33's?
BTW tuner, gears, ect will cost thousands not hundreds.
post #4 of 8 Old 06-07-2015, 09:49 PM
bigworm36's Avatar
Probably don't need gears but you will need a aev procal or flashcal to recalibrate everything. Searching around the forum will help as well
bigworm36 is offline
post #5 of 8 Old 06-08-2015, 05:33 PM
If you have 3.73, just run 35s. You don't need all that fancy stuff, it'll just be a little sluggish out of the hole. Try it, and you can always regear later on.
Jonas. is offline
post #6 of 8 Old 06-08-2015, 06:23 PM
Modlfrek's Avatar
I have a 2013 JK with a 4" lift running 35's. I purchased a Bullydog GT and recalibrated for the tires. I have 3:21 gears and it will not maintain speed in 5th or 6th gear using cruise control. I am switching to 4:56 gears to restore acceleration and maintain speed in 5th & 6th gears while keeping my rpm's in the 2600 range.
Rubitrux.com has some good info on tire size/gear ratio = rpm's.
Modlfrek is offline
post #7 of 8 Old 06-09-2015, 04:47 PM
bass5money's Avatar
I ran 35" tires on 3.5 lift and stock 3:73 gears for a year. 6 speed manual. have to downshift to 5th on hwy alot but not too awefull. regeared to 4:88 great power through gears and off roading rocks and hills way better.
2014 jk oscar mike edition. Manual. 3.5" Rubicon super flex suspension lift. 35" AT tires 17" method rims. Body armor doors. Smitty built MOD front bumper. Smittybilt 9500 lb winch, ARB twin compressor, Spod with gauge, D2 LED's.
bass5money is offline
post #8 of 8 Old 06-10-2015, 05:46 AM
GRIZZLY47's Avatar
Feedback: 13 reviews
For what you have going on stick to the 35s, and get a AEV Procal or Superchips FlashCal. Both are programmers, not tuners, that allow you to set tire size, gear ratio etc.
If your looking for tire recommendations, I'm a Toyo fan over here
2010 4-DOOR MOUNTAIN
GRIZZLY47 is offline
