Front end bounce - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 06-02-2015, 01:13 PM Thread Starter
FlatlanderWB's Avatar
Front end bounce
I have a 2 door 2014 JK with 2.5" Rock Krawler lift and their recommended Bilstein shocks. I'm running 37" BFG Krawlers at about 5psi on the trails. The setup works great around town (at closer to 30 psi) and highway and fine on the trails except in one situation. If I'm on a steep slope and have to use momentum to get up it and hit a small ledge the front end comes up off the ground. I've experienced this same problem with other 4X4s and other lifts. What if anything can I do to mitigate this problem? I'm not trying to do it on a budget I would even go to coil overs if that would help. I'm getting ready to go to a 4.5" lift so would like to address this problem at the same time.
Thanks,
Wayne
FlatlanderWB is offline
post #2 of 12 Old 06-02-2015, 02:00 PM
JKUWarthog's Avatar
Longer wheel base
"Nothing in this world can take the place of persistence.
Talent will not; nothing is more common than unsuccessful men with talent.
Genius will not; unrewarded genius is almost a proverb.
Education will not; the world is full of educated derelicts.
Persistence and determination alone are omnipotent.
The slogan "press on" has solved and always will solve the problems of the human race” -Calvin Coolidge
JKUWarthog is offline
post #3 of 12 Old 06-02-2015, 02:24 PM
If you have a lot of weight on the back try lightening the load. Full size spare with bead lock, tire carrier, heavy bumper, extra fuel, high lift, etc. If you have all of those then your front end will come up very easily. If you have none of those, then more wheelbase as has been posted.
Btw I would think more lift will make it worse not better...
Biginboca is offline
post #4 of 12 Old 06-02-2015, 03:22 PM
elusive's Avatar
its from the short arm suspension.
hard to fix cheaply.
elusive is offline
post #5 of 12 Old 06-02-2015, 03:55 PM Thread Starter
I'm looking at the 4.5" Rock Krawler X Factor Long Arm System. Are there any front shocks or coil over systems that might help?
post #6 of 12 Old 06-02-2015, 05:37 PM
Suck down winch?
GreenJK is offline
post #7 of 12 Old 06-02-2015, 06:49 PM
Comfortably Numb
RubiCajun's Avatar
RubiCajun is offline
post #8 of 12 Old 06-02-2015, 07:23 PM
or stretch that wheelba$e....
post #9 of 12 Old 06-03-2015, 03:16 PM
Monster Jk's Avatar
Feedback: 23 reviews
I have the RK 2-5/8" coilovers and they took all the roll out for me. I even have an antirock kit in the front. Sorry for the large pic
Monster Jk is offline
post #10 of 12 Old 06-04-2015, 05:53 AM
It is just weight transfer plus a bit of twist from rear axle torque. A 4 door will be slightly less prone to lifting the front end but basically even with long arms or a longer vehicle this will still happen if you give it enough berries when going uphill.
I found firmer rear coils (and i guess a firmer rear swaybar) can help slightly but the reality is that the Jeep wants to lift its front left wheel under acceleration even on flat ground, so the best way to handle the issue is to drive while knowing it will lift from that corner first.
ex: RHD JK 2dr CRD auto
CRDTom is offline
post #11 of 12 Old 06-04-2015, 06:20 AM
I may be off on my term, but sounds like your suspension is unloading or having "push off". I know I read about this a while ago when researching ORI struts that supposedly DONT do this.
rjacobs is offline
post #12 of 12 Old 06-04-2015, 06:27 AM
Send a message via Skype™ to jlagross
when you go to the x factor, you will have all 4 control arms and be able to extend the wheel base a bit even with short arms (not much but alittle). This will help.
what other "armor" do you have? do you have a winch?
From personal experience, i have a 2.5 inch max travel, and heavy rear with tools and bumper/spare , but with the weight of my flares , bumper , and winch up front, i park on a hill nightly and dont have any issues.
jlagross is offline
