5x5 to 8x6.5 conversion problems - JKowners.com : Jeep Wrangler JK Forum
post #1 of 16 Old 06-02-2015, 11:51 AM Thread Starter
mistasparkl's Avatar
I can't find any wheel adapter that goes from the 5x5 to 8x6.5 outside of some sketchy ebay 2 piece adapters. Anyone have any experience w/ these, or if they're safe to run. I was also looking for a custom unit bearing for the front 44, but wasn't able to come up with anything.
I'm currently running a PR44 front, and am in the market for a D60 rear. Since the Dana ultimate full float 60's came out, it doesn't make sense to spend money on a rear SF axle, so I need a solution for running w/ the ultimate d60's 8x6.5 bolt pattern. Ideally, I'd just swap the front axle too (err...again), but thats just a lot of cash to drop at once (front axle, rear axle, new wheels).
2012 JKU - 37" MTRs, RIPP Supercharger, ProRock44, 4.88s, ARB lockers F/R, RCVs, Reid knuckles, Poly'd steering, armor/skids, bunch of other stuff.
mistasparkl is offline
post #2 of 16 Old 06-02-2015, 11:54 AM
Talk to BORA (link below). If you see an adapter in the hardcore offroad world, it is likely made by BORA. Call them and they will make what you need and should be for the same cost as an off the shelf.
http://www.motorsport-tech.com/special/truck/jeep_s
Invest2m4 is offline
post #3 of 16 Old 06-02-2015, 11:57 AM
ALASHA's Avatar
I dont think you can neck down a full float to the 5x5 bolt pattern because of the size of the hub i.e. even with an adapter there isnt enough room to safely bore out the wheel to fit the hub. I could be wrong.
Teraflex is supposed to release an 8 lug conversion for the rubi 44. That may be something you might want to look into
ALASHA is offline
post #4 of 16 Old 06-02-2015, 12:23 PM
Hmm... Good point. I was reading it as 5x5 to an 8x6.5. And now that I think about it, what is the logic to running an 8x6.5 wheel on a 5x5 axle?
post #5 of 16 Old 06-02-2015, 12:26 PM
ALASHA's Avatar
Maybe I confused myself as well and he does want 5x5 to 8x6.5 for the front. Just made it sound like he was trying to spend the least amount which would mean keeping the same wheels. Sorry
ALASHA is offline
post #6 of 16 Old 06-02-2015, 12:29 PM Thread Starter
I don't mean to neck down the rear FF to 5x5. I will get the Ultimate rear d60 in 8 lug because thats my only option, with the wheels to match. I just need a solution for my pr44 up front to run the 8 lug wheels for a while, because spending another 7k on a front axle as well is a bit much.
Another option is to go with a PR60 FF rear instead of the Ultimate 60 which I can get in 5x5.5 and run adapters to 5x5, but the PR60 FF is a lot more expensive.
post #7 of 16 Old 06-02-2015, 12:40 PM
What about the hybrid 60 hubs that Dynatrac makes? No need to drop $7k and you don't need adapters. Although, it is probably still a $2k expense...
post #8 of 16 Old 06-03-2015, 11:09 AM
I have a sad. When ol' Sparkls posted this, I was banking on you guys coming through with a cost effective solution for him, or else convincing him to just get a pair of Mopar crates, so I could cop his Pro Rock on the cheap, with a payment plan and only have to regear it. Alas, no luck.
Wangmuf is offline
post #9 of 16 Old 06-03-2015, 11:21 AM Thread Starter
Heh, All signs point to a PR60 rear FF in 5x5.5 being the best solution for me.
post #10 of 16 Old 06-03-2015, 12:38 PM
Have you tried calling spidertrax? Maybe they can make you an 8 x 6.5 bolt pattern from one of their spacers. A little off topic but have you decided what wheels your getting yet? Gotta say those method beadlockls make me drool
CrazyLarry is offline
post #11 of 16 Old 06-03-2015, 02:51 PM Thread Starter
There is some overlap with going from 5x5 to 8x6.5, which is why the ones that are available are two pieces----and I'm looking to get the Hutchinson rock monsters
post #12 of 16 Old 06-03-2015, 08:03 PM
TCdawg's Avatar
So you called Bora and they can't make one?
TC
TCdawg is offline
post #13 of 16 Old 06-03-2015, 08:05 PM
TCdawg's Avatar
How much more is that though, at least $2k right?
TC
TCdawg is offline
post #14 of 16 Old 06-03-2015, 08:21 PM
membrain's Avatar
BORA quoted mine at a decent price, so they should be able to do you a set too.
2010 Red Unlimited Rubicon 6 speed - Traded!
2014 Red Unlimited Rubicon X 6 speed - starting over!
membrain is offline
post #15 of 16 Old 06-06-2015, 10:33 AM
Thumbs up
Motorsport tech (bora) is the way to go. I bought adapters for my superduty years ago. They are beautifully built. Hi quality materials. Everything is deburred, and fit perfectly. I can't say enough good things about them. No issues, after many miles, and towing a triple axle trailer. The warranty is beyond excellent.
bigbootysuperduty is offline
post #16 of 16 Old 06-06-2015, 09:37 PM
+1 Here! I have the adapters for my H1 wheels and have run my Jeep pretty hard with no issues from the adapters. Probably 25,000 miles on them with an honest 10-15% offroad all over SoCal and the south east. That includes bending 2 stock control arms, the rear drive shaft, both shocks, and breaking the rear track bar mount loose out on the Hammers.
Mike
lamar95x4 is offline
