Backspacing Measurement - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 06-01-2015, 11:59 AM Thread Starter
warriorwrangler's Avatar
Going to run some beat up 36's for the summer and am trying to figure out if I will need spacers. Attached below is a link to the wheel I am mounting on the 36" super swampers. Trying to avoid rubbing (fenders are already trimmed, pinch seam will also be) I have no lift in. Do you think that these will need to be accompanied by some spacers?
http://www.amazon.com/ULTRA-6x5-5-Of...x5+17%22+black
2007 4DR
warriorwrangler is offline
post #2 of 6 Old 06-01-2015, 12:31 PM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
-12 = 4.5" of back spacing on a 9" wheel.
You need 5 on 5 bolt pattern if it is a JK with stock axles.
Without any lift you'll probably still need wheel spacers, but try it and see.
Marcus
RiverCityOffroad is offline
post #3 of 6 Old 06-01-2015, 03:17 PM Thread Starter
Was hoping nobody would notice the bolt pattern because I couldn't find the 5x5 on amazon but I got the 5x5 pattern thank you, nothing gets past RCO eh? Thank you for the input I'll start spacer shopping, what is the smallest you would recommend? Trying to make sure I don't put too much stress on whatever starts breaking when you put on big tires and move them out wider
2007 4DR
post #4 of 6 Old 06-01-2015, 03:20 PM
Ha ha! Just wanted to make sure you knew.
I'd do a 1.5" spacer from Spidertrax. They are the most common and have the best track record.
Marcus
post #5 of 6 Old 06-01-2015, 06:33 PM
UnlimiDozer's Avatar
Marcus
X2. Any thinner and you'll have issues with the factory lug studs sticking through the spacer. Then you'll have to trim the pilot off the studs if you want the wheels to mount up. (Ask me how I know.)
My Build Thread:
I'm the NRA
JOIN HERE:
UnlimiDozer is offline
post #6 of 6 Old 06-01-2015, 06:56 PM Thread Starter
Thank you again, I'll pick a set up
Marcus
Not sure I understand, the lug nuts can't be to long with spacers installed? I plan on running these until I get the spacers, shouldn't be an issue besides some rubbing on tight turns right.
2007 4DR
