Damaged Synergy TRE - Ok to use? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 05-29-2015, 09:50 AM Thread Starter
Do you think these are still ok to use? I think the dust boot and spring will still grab, but not sure if grease will oooz out. Worse case, I will have to overnight new Synergy TRE's today. The photos are from my Synergy draglink. thanks
jk12blk is offline
post #2 of 8 Old 05-29-2015, 10:50 AM
A JKO DICK
ASSFROW's Avatar
I would file the "points" smooth so they don't wear through the boots and run them as long and there is nothing wrong with the joint itself.
ASSFROW is offline
post #3 of 8 Old 05-29-2015, 11:49 AM
what he said^^^^^^
2007 JKU AKA CHEEP HEEP. 2.5 rk tripple rates, bilstein long travels, Currie arms,antirock, 35 mtr's, artec truss, redneck ram, ruff stuff tie rod, poly drag link, ten factory front/rear shafts, aussie locker, savvy front bumper, bfh rear
Rubicon_35 is offline
post #4 of 8 Old 05-29-2015, 11:52 AM
kjeeper10's Avatar
Or dremel the notch smooth. The boot is more to keep dust out, not keep grease in.
kjeeper10 is offline
post #5 of 8 Old 05-29-2015, 11:52 AM Thread Starter
right on. thanks!
jk12blk is offline
post #6 of 8 Old 05-29-2015, 11:59 AM
gt1guy's Avatar
Did you do that while removing it?
Kevin
gt1guy is offline
post #7 of 8 Old 05-29-2015, 01:45 PM Thread Starter
Kevin
Correct. I got a little silly with a pickel fork and f'ed them up. I need bigger hammers so I can break them loose in the future. Another item on my list. I do have a spare TRE, but not two. I'll try the file or dremel route to clean up the edges and give it a go.
jk12blk is offline
post #8 of 8 Old 05-29-2015, 05:48 PM
gt1guy's Avatar
Generally, I just give the knuckle a good whack with a hammer right where the TRE stud goes through, inline with the arm. Rarely need a pickle fork. Short handled 3-4lb maul works great.
Kevin
gt1guy is offline
