Should I do a Drag Link flip - 3.5" lift - JKowners.com : Jeep Wrangler JK Forum
post #1 of 24 Old 05-27-2015, 10:35 PM Thread Starter
I have the parts, I just can't weld, so this will cost me a bit - welding of the artec track bar bracket.
I have 3.5" metalcloak coils. The handling is fine, touch of bump steer but its a solid axle.
I'm going back and forth over just leaving it - I don't want to get bigger bumps and lose any uptravel. I've read a ton about this and go back and forth - anybody have any thoughts? Any "it wasn't noticeable" people?
lkjk is offline
post #2 of 24 Old 05-28-2015, 04:31 AM
Since doing the flip my handling has improved not necessarily with less bump steer but damn it corners like a sports car. It's tighter steering with the higher roll enter for sure. The only reason I did the flip was because I needed the big beefy artec bracket for hydro assist. I hear you about losing uptravel I'm running 3" up front and it's killing me. The fix for that is a frame notch which I'll be doing writhin the next couple weeks
CrazyLarry is offline
post #3 of 24 Old 05-28-2015, 04:37 AM
Pics
post #4 of 24 Old 05-28-2015, 06:47 AM
man, am I glad I have held-off on flipping my DL on a 3" Synergy coil stage II lift by using the trackbar bracket tthat came w/ it after reading about you lack of upswing; sorry for your issue but you helped some others who are "on the fence" about flipping their DL.TY and good luck...
post #5 of 24 Old 05-28-2015, 06:50 AM
It won't be an issue much longer once the frame is notched
post #6 of 24 Old 05-28-2015, 10:46 AM
I just installed mine along with my Synergy tie rod and Pro Rock 44...I notched the frame and welded in a piece of 3" diameter- 1/4 wall pipe sliced in half. I am using a 1 inch bump stop.
petethekiller is offline
post #7 of 24 Old 05-28-2015, 09:58 PM Thread Starter
ok, so it sounds like big bumps or notch the frame....and no "night and day" difference...
lkjk is offline
post #8 of 24 Old 05-28-2015, 10:21 PM
Ogie's Avatar
I only have a 2.5" lift, and I did the flip. I just installed ram assist and at flex, the DL was hitting the ram.
But even with just a 2.5" lift, I experienced moderate bump steer. After the flip, none. It now steers and handles better now than it ever has. I have yet to address the bumps, and I'm not too crazy about notching a frame, especially in the front; so, I might just have to live with less up travel.
My set up:
Vidi, vici, veni
2008 Jeep JK Wrangler Rubicon Unlimited
Ogie is offline
post #9 of 24 Old 05-29-2015, 07:42 AM
IF you are properly set up a drag link flip will make a big difference in the steering in feel and tracking on the road, off road you will have less side to side shift in the axle/body due to articulation.
IF you are running 3.5" of lift and run 3" extended bump stops you should still have over 5" of up travel in the suspension which should be plenty for most people.
post #10 of 24 Old 05-29-2015, 07:56 AM
jkupbu's Avatar
My set up:
This is the first I've seen of a 2.5 lift with a DL flip. My DL is starting to go. I was looking at a DL flip and thinking I would need to modify to a 3.5 lift. Very interested in what you did, do you have a build thread or more information?
2013 PBU JKU-S, 37x12.50R17 KO2s, Fuel D552, RE: 3.5progressive+hydrbumps+disconnects TF:TB-DL-TR+Long arms+LCAskids+FoxResi+tailgate, grade 9 bolts, 10th hood, NemInd fenders, RSE Al rear, TNT stubby + sliders, ORH top, KCGravityPros, JWS taillight, Riddle cover 4.56 eaton elocker, sleeves + chromolys, DT BJs, Mopar + DT brakes
jkupbu is offline
post #11 of 24 Old 05-29-2015, 08:00 AM
Remember most lifts are not as advertised and many 2.5" lifts will give you 3"+ unless the jeep is heavy. The key is keeping the drag link and track bars as parallel to the ground as possible to reduce the axle shift caused by articulation.
post #12 of 24 Old 05-29-2015, 07:21 PM
Ogie's Avatar
It's nothing special, just TF 2.5" spring lift with .5" spacers in the front to make up for the winch/steel bumper.
Vidi, vici, veni
Ogie is offline
post #13 of 24 Old 05-29-2015, 07:47 PM
3" bump stop or notch the frame to make up for less bump stop.
You could run 3" bump stops on a 2.5" lift. Typically you don't want to bump stop more than you lift, but considering most 2.5" coils will put you close to if not a little more than 3" of lift you would be fine. Even if you only have an actual 2.5" of lift that extra .5" of bump is not going to be a huge deal.
I'll notch the frame and maintain 1.5"-2" bump stop.
-SLADE- is offline
post #14 of 24 Old 05-29-2015, 09:23 PM
kjeeper10's Avatar
Keep in mind, with raising the front roll center (track bar bracket), The rear needs to be raised as well. Roll center heights should match or set higher in the rear.
kjeeper10 is offline
post #15 of 24 Old 05-29-2015, 09:33 PM Thread Starter
Good call. I have the rear artec bracket with like 4 holes, so not an issue for me. I think I'll stick with stock drag link location, I looked and would either need to sacrifice up-travel or notch the frame, neither of which I really feel like doing, especially since my handling seems fine.
lkjk is offline
post #16 of 24 Old 05-29-2015, 10:54 PM
I just don't see the point for a true 2.5" lift. With the up travel you lose I can't see the gain being worth it.
On my old 4 door with 3.5" I did and it improved cornering and steering noticeably. I also ran the trackbar and sector shaft brace.
Rmiller31 is offline
post #17 of 24 Old 05-30-2015, 09:52 AM
Ogie's Avatar
I didn't have much choice in my situation, but I will say it did make a huge improvement in my steering and handling. I don't regret doing it, but the loss of up travel will be disappointing, especially since I don't intend to notch the frame.
Maybe someday I'll move the ram to be mounted from the diff to knuckle, and I'll be able to move my TB and DL back to OEM locations. But for now, I'm OK with my set-up.
Oh, and as for matching the rear TB, I haven't done that. So far, I haven't seen the need to do it even though it may be technically correct to do so.
Vidi, vici, veni
Ogie is offline
post #18 of 24 Old 05-31-2015, 11:57 PM
im running 3.5" MC coils, 37" tires, 3" bump stops, and no drag link flip. Works and handles just fine.
Its not a fashion show
Fueler is offline
post #19 of 24 Old 06-01-2015, 03:24 AM
With 2.75" front bumpstops my 37's lightly rub the metal support for my fenders at full stuff. Running 3" front bump stops is a good thing if you have 37's in your build plan, IMO.
Biginboca is offline
post #20 of 24 Old 06-01-2015, 03:30 AM
2Door's Avatar
I think a DL flip is in my future. A friend of mine used the EVO flip kit with his last year (2.5" bumps on the pad and Prothane replacement upper bumps) and he praises the hell out of it. Says that it's one of the most significant, beneficial things that he's done to improve the driveability of his Jeep. His frame to DL clearance is super tight, but it works, too. Interested to know what people prefer for a kit; I'm looking at the Synergy DL... any issues running it?
2011 Sahara Tan 2dr Rubicon
2Door is offline
post #21 of 24 Old 06-01-2015, 05:03 AM
kjeeper10's Avatar
Nope ^^ best out there for the price.
post #22 of 24 Old 06-01-2015, 06:14 AM
Ringer's Avatar
Makes a huge difference. Notching the frame is relatively simple. I ran if for a while with RK 2.5" springs and 1.5" bumpstops/ 1.5" frame notch. Those that say they have 3"+ of lift with no flip and say it handles fine have most likely not driven one with a flip to see what good handling is like. Here is a pic of the frame notch. Any weld shop could do it very easy for you if you can't weld.
Ringer is offline
post #23 of 24 Old 06-01-2015, 07:36 AM
SoK66's Avatar
In my experience anything over 2.5" lift benefits from the flip an a track bar raise. As stated, you have to experince the improvement in steering & handling to understand.
SoK66 is offline
post #24 of 24 Old 06-01-2015, 08:07 AM
The key is having the links as parallel to the ground as possible. The flatter they are the less movement you will get in the axles during articulation. The higher you mount the links will improve the roll center and you will experience less lean in cornering
