Alternate TRE for Synergy Tie-Rod & Drag-Link? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 05-26-2015, 05:51 AM Thread Starter
Hi,
I'm looking to find an alternate Tie Rod End to replace the Synergy 4131-L Tie Rod End that fits into the Synergy Tie-Rod and Drag-Link?
I keep seeing people talk about Moog EX2234L but it seems to be unavailable and the replacement is Moog 2010L. Has anyone confirmed that either of these fit the Synergy Bars?
I have 17" wheels, 4.5" BS and no rubbing with the 4131-L TRE.
GlennH is offline
post #2 of 10 Old 05-26-2015, 06:51 AM
Why would you want to replace those ends? If you have the right size wheels and backspacing with no rubbing I cant see what issues your having
CrazyLarry is offline
post #3 of 10 Old 05-26-2015, 12:11 PM
i know the joints that ruff stuff sells should fit. the 1 ton gm ones
2007 JKU AKA CHEEP HEEP. 2.5 rk tripple rates, bilstein long travels, Currie arms,antirock, 35 mtr's, artec truss, redneck ram, ruff stuff tie rod, poly drag link, ten factory front/rear shafts, aussie locker, savvy front bumper, bfh rear
Rubicon_35 is offline
post #4 of 10 Old 05-26-2015, 12:15 PM
offset http://www.ruffstuffspecialties.com/catalog/TREOFF.html
standard http://www.ruffstuffspecialties.com/.../TRESTAND.html
they are 7/8-18 UNF LH or RH Thread same as the poly/synergy
post #5 of 10 Old 05-26-2015, 06:48 PM Thread Starter
The fact that they arent lasting long and spending $170-200cdn of TRE's every year is no good.
Thanks for the help Rubicon_35.
Over at JK Forum another guy mentioned Parts Mike has the EX2234L.
So should I got with the EX2234L or the Ruff Stuff?
http://www.partsmike.com/index.php?c...on=show_detail
GlennH is offline
post #6 of 10 Old 05-26-2015, 07:59 PM
kjeeper10's Avatar
Dont last long ? I dont recall hearing any complaints on their durability.
Did you try contacting Synergy?
kjeeper10 is offline
post #7 of 10 Old 05-26-2015, 10:16 PM
TRAUMAhead's Avatar
lkjk is running Moog joints on his in this thread: https://www.jkowners.com/forum/showthread.php?t=267578
Could ask him for a part #.
TRAUMAhead is offline
post #8 of 10 Old 05-27-2015, 05:45 AM Thread Starter
Im in contact with Synergy now...
GlennH is offline
post #9 of 10 Old 05-27-2015, 09:17 AM
I would be wanting to figure out WHY you are going through Synergy rod ends every year.
They are pretty beefy, even more so than GM 1 ton ends, so IMO if you are blowing Synergy's every year you wont get as long of life out of the GM 1 ton stuff, although it would be cheaper to replace.
rjacobs is offline
post #10 of 10 Old 05-27-2015, 09:22 AM
parts mike and ruff stuff are very similar
