PSC Hydro Assist - JKowners.com : Jeep Wrangler JK Forum
post #1 of 83 Old 01-21-2010, 08:33 PM Thread Starter
NE Wrangling's Avatar
PSC Hydro Assist
Anyone rip out the stock equipment and modify with the PCS system? Wondering what is involved in doing this modification? What Parts, any writeups, etc...
jk-forum, jk forum, jkforum, jeep jk wrangler, jk-forum.com, jeepforum, jk-board.com, wayoflife, 2007 jk, 2008 jk, 2009 jk, 2010 jk, jk, jk wrangler
Never argue with an idiot, they will bring you down to their level then beat you with experience.[/SIZE][/B]
NE Wrangling is offline
post #2 of 83 Old 01-21-2010, 08:42 PM
FHMan1905's Avatar
Send a message via AIM to FHMan1905
check this out....Bodyguy used this on his JK
Redneck Ram
2007 Sahara Unlimited
4" Lift, 35" KM2's, Soft 8's, 4" HIDx windshield mounted, Finishlinewest rocksliders and 4.0 bumper, Bestop Trektop!
FHMan1905 is offline
post #3 of 83 Old 01-21-2010, 09:09 PM
bodyguy's Avatar
Yeah Phil has been running the same setup for over a year now and has no complaints. I had WTO rebuild my gear box and then mail it back with the ram, hoses and mounts. The PSC kit is overpriced
bodyguy is offline
post #4 of 83 Old 01-21-2010, 09:14 PM
Slow and Low
Co4Lo's Avatar
Word.
I too am running the Redneck Ram. It's slick and I have no complaints. Matt is a cool maing, and provides great customer service!
Co4Lo is offline
post #5 of 83 Old 01-22-2010, 04:00 AM
GreenAmphibious's Avatar
Too funny. The whole way to work I was thinking about PSC steering assist.... and viola. For $499!
2015 JKU Sport Virgin
GreenAmphibious is offline
post #6 of 83 Old 01-22-2010, 05:12 AM Thread Starter
looks like a option. Need to figure that out more and whether I can have the jeep out of order for a few weeks while its in route to and from. So they take the stock equipment and add the hydro functions to it? Since this is new to me I was wondering if the stock equipment is sufficent enough to be modified.
Any pics of the stock setup modified?
post #7 of 83 Old 01-22-2010, 05:36 AM
FHMan1905's Avatar
They have a complete kit, no downtime. Still half the cost of PSC's kit!!
post #8 of 83 Old 01-22-2010, 06:52 AM
Slow and Low
Co4Lo's Avatar
$399 if you buy at EJS, or get a coupon there from Matt and buy later...
Co4Lo is offline
post #9 of 83 Old 01-22-2010, 06:53 AM
booya! thanks.... no the question... is this over kill with only running 37s or does it really matter
post #10 of 83 Old 01-22-2010, 07:23 AM Thread Starter
I would do it with 37" tires. I know Phil run 38's with it.
A full setup brand new is 699 is this discounted at EJS too? They also state this is the starting price not the final. Be intersted to understand a full setup and if it is really 699.00. That is a relly good deal.
post #11 of 83 Old 01-22-2010, 08:05 AM
maverick's Avatar
REDNECK RAM
Stage I... $
modify existing steering box
Stage II... $
mounting hardware (tabs weld on)
cylinder
(IF send steering pump internals, will modify for FREE http://westtexasoffroad.homestead.co...rsteering.html main fitting, flow piston, piston spring)
hoses
rod ends
Stage III... (Stage II plus refundable core $ )
$ typical CJ/TJ with no core exchange
$ plus refundable core $ for JK
cylinder
IF new pump ($ ) (not really needed UNLESS your pump is problematic)
hoses
rod ends
**NONE include larger reservoir
WEST TEXAS OFF ROAD (Matt)
1811 W. Beauregard
San Angelo, TX
1-877-833-7464
325-653-7001
Bottom line...
REDNECK RAM $ ... modified box, hoses, cylinders, WELDED tabs, modified pump (New pump Add $ )
Note: REDNECK indicates larger reservoir not required with their system.
I personally modified the steering box on my '93 YJ adding fittings, SS lines, larger reservoir (which I believe is needed for the cylinder flow), welded hardware, and a fluid cooler. I didn't modify the pump which was apparent as idling into a grocery parking lot the steering was worse than not having power steering.
maverick is offline
post #12 of 83 Old 01-22-2010, 08:08 AM
07Rubi2dr's Avatar
so we have to send in our box? that means downtime? what is the refundable core thing about? is there no complete kit to put in?
2007 2dr Rubi: lifted, 37's, custom fab work, lots of other stuff
07Rubi2dr is offline
post #13 of 83 Old 01-22-2010, 08:19 AM
07Rubi2dr's Avatar
Originally Posted by maverick View Post
Either provide your box or pay the refundable core charge. Once you have their kit installed which means you removed your old box, you send in your old box for a refund of the core charge. Core charge varies as steering boxes vary between Jeep models. The JK currently has a high core charge as there are not many available in the salvage yards.
gotcha, i think. so I pay the 499+400 core charge, then install it, and send them my old box back, and then they credit me back the 400$?
is this a recommended upgrade for running 37's?
post #14 of 83 Old 01-22-2010, 08:45 AM
maverick's Avatar
I've been running 37s for two years and manage, BUT... majority of the time I'm on dirt or rocks with dirt which allows some slippage. Even under conditions suggested, I often wished I had it and... I have order my assist, but not yet installed. If I were in MOAB I believe on solid rock I would had acquired immediately.
maverick is offline
post #15 of 83 Old 01-22-2010, 08:51 AM Thread Starter
Nice info guys, now I have enough to makea decision. I have a little time before getting and installing because I need to purchase several items first so there is a true need.
post #16 of 83 Old 01-22-2010, 09:21 AM
Ipe
Ipe's Avatar
NE, let me know if you want to look at a WTOR system installed. Thats what I'm running.
Ipe is offline
post #17 of 83 Old 01-22-2010, 09:26 AM
07Rubi2dr's Avatar
any thoughts on it? how do you like it?
post #18 of 83 Old 01-22-2010, 12:48 PM
Ipe
Ipe's Avatar
I like having the hydro assist a lot. For the most part its seamless and invisible to the driver. On the trail you never have to fight the wheel, and on the street it seems to relax things a tiny bit. My only gripe is the OEM pump doesn't like low (idle or lower) engine speeds. This may be an issue for my system only, I donno.
Ipe is offline
post #19 of 83 Old 01-22-2010, 04:37 PM
TrailDuty.com
PhilD's Avatar
No problem with mine, there is a slight amount "slowness' at idle, but barely noticeable.
FWIW I've been very happy with the redneck system, no complaints at all and it works great, both on and off road.
PhilD is offline
post #20 of 83 Old 01-22-2010, 06:31 PM
Slow and Low
Co4Lo's Avatar
I'm also running mine with the stock pump and 40's. No problems at all!
Co4Lo is offline
post #21 of 83 Old 01-22-2010, 06:38 PM
seer's Avatar
If you don't like the weld on tabs idea, Poly Performance makes a handy bolt on bracket for it. I've been running the PSC for quite some time. When I went for it, Redneck was only just getting into the JK thing and was talking a four week turn around. Just couldn't have the Jeep down for that long. Plus I needed to replace my PS pump anyway. Bump steer is just a distant memory and that assist sure takes the sweat out of a 40 point turn. Some of those cliff side roads are pretty narrow...
seer is offline
post #22 of 83 Old 01-22-2010, 06:46 PM
The Joker's Avatar
dod you have a link to the bracket? I cant seem to find it.
EDIT: found it.
http://www.polyperformance.com/shop/...t-p-20450.html
The Joker is offline
post #23 of 83 Old 01-22-2010, 07:41 PM
EDIT: found it.
I purchased the bracket, never installed it, and am going to wait on the hydro assist. Anyone wanting one, I will work a deal for. It is in brand new condition.
FJ80fornow is offline
post #24 of 83 Old 01-22-2010, 07:42 PM
PhilD,
When using hydro assist on the road, does the wheel return to center if you let go like a regular power steering setup? I want it for the wheeling, but don't want bad road manners.
post #25 of 83 Old 01-22-2010, 08:25 PM
GREAT STUFF! I will be calling and ordering one this week!
Currie RJIII ARB D60's, 5.13's | Trailready beadlocks on 41" Super Swampers | 6" Teraflex LCG | Custom cage | body armor | WARN HD Powerplant!
Ryanclimbs is offline
