Swapping in some Rubi axels - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 01-18-2010, 10:23 PM Thread Starter
Justin Gray's Avatar
Swapping in some Rubi axels (Don't tell the Wife)
Thanks to JKCurt I'll be picking up a set of really well built Rubi 44's for my wifes unlimited x tomarrow. She doesnt know and can't know!! About the swap so i was planning on splitting it up over two days while she's at work. Any pointers or stuff i should be aware of before i tear in to her daily driver.
Visit
We are a fun, family oriented group of responsible ohv users!
Justin Gray is offline
post #2 of 7 Old 01-18-2010, 11:28 PM
.:eMETAL:.'s Avatar
Hehehe I like this thread it's fun.
is this something she's been wanting and you're surprising her? A little back story...
.:eMETAL:. is offline
post #3 of 7 Old 01-18-2010, 11:39 PM Thread Starter
She would consider new axels a waste of money. I on the other hand consider them priceless. Its much easier not telling her than explaining how chity the dana 30 is! One problem though, I just havent figured out how to tell her she can turn the overdrive back on!!!!! HEHEHE
Visit
post #4 of 7 Old 01-19-2010, 06:32 AM
This should be entertaining.
2007 Redrock X two door
Auto
Hardtop
D44 rear
17" Moab wheels
32" BFG M/Ts
Rubicon Rock Rails
Airaid intake
Infinity speakers
pearl-drum-man is offline
post #5 of 7 Old 01-19-2010, 06:40 AM
jeeperjkj's Avatar
Assuming you're running 3.73's in the Unlimited now, if you're splittin' the swap up over 2 days, I don't think you'll be able to drive it with different gears in the front/rear axles after the first day (without disconnecting the front drive shaft between days).
I could be wrong, but I think that's how it works.
Good luck.
jeeperjkj is offline
post #6 of 7 Old 01-19-2010, 06:58 AM
biggb53's Avatar
You can drive with different gears in the front and rear, as long as you stay in 2wd and not in 4wd.
biggb53 is offline
post #7 of 7 Old 01-19-2010, 08:54 AM
usmcdoc14's Avatar
Things to do BEFORE swapping:
New wear items.
Shit like brakes, ball joints and stuff like that are a LOT easier to do with the axle just sitting there. Its cheap insurance.
Gusset the front?
You plan on using factory switches for the lockers? if not see my tech write-up for making them a "normal" switched item.
New lube and diff cover seals.
Otherwise you should be able to do the swap complete in a weekend at most.
usmcdoc14 is offline
