Transmission Swap - JKowners.com : Jeep Wrangler JK Forum
post #1 of 15 Old 01-18-2010, 07:09 PM Thread Starter
Juanhinestrosa's Avatar
Transmission Swap
First I want to tell you all that I am new to the forum, and this is my first post.
Second I wanted to mention have a 2010 jk unlimited with 35" tires and an automatic transmission. After 2000 miles I am a bit tired of the automatic transmission. It is boring, and I've heard that the power difference between the manual 6-speed transmission and the automatic transmission is pretty big. I already tried to boost up my hp by installing an Airaid cold air intake, but all it did was increase the engine noise (which I like). Anyhow I wanted to see if a transmission swap is possible, and it would be too costly. I wonder if switching my automatic JK for another 2010 manual Jk is better than a transmission swap. I would like to see what you think.
thanks
Juanhinestrosa is offline
post #2 of 15 Old 01-18-2010, 07:20 PM
well first off is it a rubi or not? the rubi will get you 4.10 gears... and with 35's you need LOWER GEARS than what ever you have.
my CJ with a 4.2 and 4.10's and a 5 speed was ok. from what I remember the gearing for 35's and an auto is like 5.13 and for a manual is 4.88.
I have 4.88's in the CJ now and would NOT want less.
and the CAI is not gonna net you much... granted a programer to set the tire size and gearing would help but you need GEARS.
OR do you just NOT want an auto?
84jeepjohn is offline
post #3 of 15 Old 01-18-2010, 07:30 PM Thread Starter
well I don't have a rubi, its the 4dr unlimited sport 4x4.
On the CAI I knew I wasn't going to get any more power I just wanted it cause it provides better throttle response and a nice roar.
On the other hand, i've thought about gears, but I think I would be happy with a manual transmission. My concern is if its possible or not to do the swap, and the cost as well. If it costs too much I would definitely go for the change of gears.
2010 Jk Unlimited Sport
35" Mickey Thompson Tires
Magnaflow exhaust
Fortec suspension 2.5"
Airaid CAI
Hi-Lift
IPF 968s windshield mounted lights
HID lights
5.13 G2 gears
Poison Spyder Rear Diff Cover
post #4 of 15 Old 01-18-2010, 07:41 PM
I think that might be a doable project. But one thing you would need to check into is the computer. It would need to be reflashed to know that it no longer had an auto sine its tied into the auto shift points.
Welcome to the fourm
post #5 of 15 Old 01-18-2010, 08:02 PM Thread Starter
Well I thought about that, and I have no idea of how that would work. I think I might go to a Jeep dealership, and see if they would do it, and if they would take my auto transmission as a trade in.
Magnaflow exhaust
Airaid CAI
Hi-Lift
HID lights
5.13 G2 gears
post #6 of 15 Old 01-18-2010, 08:11 PM
Yeah that auto is worth some good $$. Also check to make sure that the wiring harness has the plugs for a manual (assuming that it plugs into the harness).
post #7 of 15 Old 01-18-2010, 08:58 PM
RODICON's Avatar
A Sprint booster will help you out.
2014 Rubicon on the build!
RODICON is offline
post #8 of 15 Old 01-18-2010, 10:04 PM
planman's Avatar
I'd first regear to 5.13s, then run a Superchips Flashpaq tuner.
5.38s is better with an automatic and 35s, but you can't do it with your Dana 30 front axle.
Anyway, wait to do the tranny until after you have spent $1k to regear and $309 on the Superchips tuner.
planman is offline
post #9 of 15 Old 01-18-2010, 10:08 PM
That's a good point. I've driven stock auto / manual and the performance isn't that different. The manual does have a bit more pop when taking off but no big deal.
I will say that, for me, the 6 speed is more fun to drive on the street. But I like the auto for wheeling.
post #10 of 15 Old 01-19-2010, 09:46 AM Thread Starter
Thank you guys, I would take your opinion into consideration.
Magnaflow exhaust
Airaid CAI
Hi-Lift
HID lights
5.13 G2 gears
post #11 of 15 Old 01-19-2010, 11:16 AM
GreenAmphibious's Avatar
sell the CAI and get a programmer.... made a huge difference, then gears
2015 JKU Sport Virgin
GreenAmphibious is offline
post #12 of 15 Old 01-19-2010, 12:48 PM Thread Starter
good idea
Magnaflow exhaust
Airaid CAI
Hi-Lift
HID lights
5.13 G2 gears
post #13 of 15 Old 01-19-2010, 01:08 PM
scottrock's Avatar
I would think that a tranny swap in a JK would be bookoo $$$$. On top of the following mentioned parts, you will have a bunch of labor to consider as well.
Areas of concern would be a clutch assembly, all associated electrical components, shifter, console and the computer re-flash (if that is even an option) oh and the transmission itself.
Major question here is did you re-gear yet or are you running the stock gears with 35's?
That alone could be the root cause of your "boring" JK.
IMO, before you drop several grand on a solution that may net you zero results, (how pissed would you be then?) re-gear and flashpaq.
scottrock is offline
post #14 of 15 Old 01-19-2010, 08:08 PM
You can come to my shop and swap my 6 spd for your auto , you will prob need to swap a lot of the engine harness. I hate that 6 spd and clutch. much rather have an auto off road.
GOAT1 is offline
post #15 of 15 Old 01-19-2010, 08:52 PM
tkob1060's Avatar
I believe the transfer case shaft would have to be changed also
tkob1060 is offline
