tie rod end inserts - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 01-16-2010, 05:50 AM Thread Starter
tie rod end inserts
does anyone make an insert to use a regular tie rod end on these knuckles? I have strait bore holes about 3/4" dia.
Knot Wright is offline
post #2 of 11 Old 01-16-2010, 07:14 AM
check Partsmike.com
Nomorbills is offline
post #3 of 11 Old 01-17-2010, 04:31 PM
PIG
PIG's Avatar
Define regular....
Something like this...?
PIG is offline
post #4 of 11 Old 01-17-2010, 06:20 PM Thread Starter
Originally Posted by PIG View Post
Define regular....
eggzactly that
post #5 of 11 Old 01-17-2010, 06:32 PM
RuBob's Avatar
i like this solution. i was just about to ream my knuckle for your drag link flip. if i wanted to go back to the stock drag link location, can i just pop out the insert and insert from under the knuckle?
RuBob is offline
post #6 of 11 Old 01-17-2010, 11:35 PM
PIG
PIG's Avatar
Yup.
PIG is offline
post #7 of 11 Old 01-17-2010, 11:40 PM
PIG
PIG's Avatar
eggzactly that
Cool, glad I was able to help out.
PIG is offline
post #8 of 11 Old 01-18-2010, 07:33 AM
RuBob's Avatar
Thanks, just ordered online.
RuBob is offline
post #9 of 11 Old 01-18-2010, 10:04 AM
PIG
PIG's Avatar
Got it... Shipping today.
PIG is offline
post #10 of 11 Old 01-26-2010, 08:13 AM
RuBob's Avatar
I installed the Poly Trackbar Relocate and Drag Link Flip yesterday. It was an easy install. I used a 7/8" Unibit with a drill bit extension to drill the hole for the insert above. It cut the hole easily.
This is a definite improvement (in driving) over the FT frame-side trackbar bracket with dropped pitman arm. I also have the Poly Tie Rod, so my steering is feeling pretty stout now.
I have 3" of front lift and the axle is pretty well centered with the stock trackbar and Poly kit.
In terms of driving comfort, I'd rate it this way (for ~3" of lift):
1) Poly Steering Correction Kit (trackbar axle bracket and drag link flip)
2) No trackbar bracket, adjustable trackbar
3) No trackbar bracket, stock trackbar
4) Frame-side trackbar bracket, dropped pitman arm
ps - the dropped pitman arm puts way too much stress on the steering shaft and box. You can really see the box moving back and forth under the hood with the dropped pitman arm installed.
'08 JK Unlimited Rubicon
RuBob is offline
post #11 of 11 Old 01-26-2010, 08:34 AM
PIG
PIG's Avatar
Cool, glad it worked out for you dude.
PIG is offline
