New TIPM - JKowners.com : Jeep Wrangler JK Forum
post #1 of 48 Old 01-15-2010, 08:15 PM Thread Starter
Dr.Dirty's Avatar
Feedback: 21 reviews
New TIPM
well got the new TIPM in and the jeep starts and runs fine now but now i have a code
U1412 IMPLAUSIBLE VEHICLE SPEED SIGNAL RECEIVED
The next issue is when the Jeep is running and you turn the Key back on click all the gauges turn off but the Jeep keeps running.
Any ideas
www.jeepasylum.com
Dr.Dirty is offline
post #2 of 48 Old 01-15-2010, 08:32 PM
andrelopez99's Avatar
Hey bro, that code I was getting with my procal, tire size change. I had to reset back to stock then re program... Bla, bla, bla... You know the drill. Might be the programer.
andrelopez99 is offline
post #3 of 48 Old 01-15-2010, 08:48 PM Thread Starter
Dr.Dirty's Avatar
i reset it back to factory settings and you are correct the code went away but im still having the running problem
it turns off fine if you turn the key all the way back
www.jeepasylum.com
Dr.Dirty is offline
post #4 of 48 Old 01-15-2010, 08:52 PM
paramaniac's Avatar
just out of curiosity, what did you pay for the TIPM?
paramaniac is offline
post #5 of 48 Old 01-15-2010, 08:59 PM
Would it be the dual battery kit, I saw your other thread and I John responded to it, you think it might have something to do with it?
post #6 of 48 Old 01-15-2010, 09:04 PM Thread Starter
Dr.Dirty's Avatar
All was dissconnected before the new TIPM went in and has not been hooked back up
All my electrical add ons are not hooked up as of now
www.jeepasylum.com
Dr.Dirty is offline
post #7 of 48 Old 01-15-2010, 09:06 PM
But was it connected when the problem started?
post #8 of 48 Old 01-15-2010, 09:07 PM Thread Starter
Dr.Dirty's Avatar
yes
But I installed the new TIPM tonight and none of it has been hooked up
www.jeepasylum.com
Dr.Dirty is offline
post #9 of 48 Old 01-15-2010, 09:20 PM
I'm asking hypotheticaly after installing the battery kit, somewhere down the line it messed something else up. By accident.
post #10 of 48 Old 01-15-2010, 09:25 PM Thread Starter
Dr.Dirty's Avatar
I guess its possible
www.jeepasylum.com
Dr.Dirty is offline
post #11 of 48 Old 01-15-2010, 09:29 PM
Just a question?
post #12 of 48 Old 01-15-2010, 09:30 PM Thread Starter
Dr.Dirty's Avatar
Just a question?
I know just giving you a hard time lol
www.jeepasylum.com
Dr.Dirty is offline
post #13 of 48 Old 01-15-2010, 09:32 PM
SFCCotton's Avatar
The camerman sabotaged him!
SFCCotton is offline
post #14 of 48 Old 01-15-2010, 09:33 PM
I know................DICK!
Note: thank for that recommendation on Aeroforce, I can't wait on it. Get it Wednesday.
post #15 of 48 Old 01-15-2010, 09:34 PM Thread Starter
Dr.Dirty's Avatar
Sweet youll love it
www.jeepasylum.com
Dr.Dirty is offline
post #16 of 48 Old 01-15-2010, 09:36 PM
Has there been anything else noted on swaybar disable.
post #17 of 48 Old 01-15-2010, 09:40 PM Thread Starter
Dr.Dirty's Avatar
He said he should hav a code for it by the end of feb for me to tryout
www.jeepasylum.com
Dr.Dirty is offline
post #18 of 48 Old 01-15-2010, 09:45 PM
Sweet! Just keep us posted....Need any one else to test... Let me know, going to put a antirock to replace my ele. swaybar. VERY VERY soon!
post #19 of 48 Old 01-15-2010, 09:46 PM Thread Starter
Dr.Dirty's Avatar
Ill keep you posted
I just dissconnected all power and ill let it sit over night to see if the Jeep Wizard will come fix it lol
www.jeepasylum.com
Dr.Dirty is offline
post #20 of 48 Old 01-15-2010, 10:35 PM
bodyguy's Avatar
Ill keep you posted
I just disconnected all power and ill let it sit over night to see if the Jeep Wizard will come fix it lol
Good grief I hope your problem isn't similar to mine. I blamed it on lightening, only thing I could come up with that was somewhat reasonable since the suburban had problems at the same time. Your new problem almost sounds like PCM related, definitely not saying it is. I have had my jeep stay on before after I removed the key, I ended up disconnecting the sway bar harness to fix that problem. I don't know but it worked.
bodyguy is offline
post #21 of 48 Old 01-16-2010, 06:35 AM Thread Starter
Dr.Dirty's Avatar
Yeah i remove the sway bar a few years ago lol im leaning towards the PCM as well wich luckily is coverd under the california emissons warranty for 8 years
it shuts off when you turn the key to off but like i said it will stay running acc mode
www.jeepasylum.com
Dr.Dirty is offline
post #22 of 48 Old 01-16-2010, 06:57 AM
owtdorz's Avatar
Sounds like a possible ignition switch.
BTW I know the TIPM comes with all relays and fuses.
Did you make sure they are all in the right places?
'09 4dr Rubi Detonator Yellow
3.5 Mid arm Rock Krawler
Finally 5.13s
owtdorz is offline
post #23 of 48 Old 01-16-2010, 08:02 AM
bodyguy's Avatar
Some of the fuses in the tipm I got had not been pushed all the way in and I had to swap over at least one that I can remember.
The ignition switch could very well be related, do you have any other problems. Next time try turning the switch back and forth and see if that effects anything
bodyguy is offline
post #24 of 48 Old 01-16-2010, 08:54 AM Thread Starter
Dr.Dirty's Avatar
yeah i double checked all them
nope no other problems no lights or codes
www.jeepasylum.com
Dr.Dirty is offline
post #25 of 48 Old 01-16-2010, 09:48 AM
bodyguy's Avatar
Do you have access to a good scan tool? That's how I figured out all the crap on mine that was actually damaged I think I had like 26 active codes including the radio.
bodyguy is offline
