For those running Crown Balljoints.. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 19 Old 01-14-2010, 09:19 AM Thread Starter
The ball joints came with this threaded sleeve (see right of the castle nuts in the picture) do I need to install this or can I leave it out?
Hellbound13 is offline
post #2 of 19 Old 01-14-2010, 09:23 AM
GreenAmphibious's Avatar
what do the instructions say?
aren't crown the makers of the OEM BJs?
2015 JKU Sport Virgin
GreenAmphibious is offline
post #3 of 19 Old 01-14-2010, 09:38 AM
Dr.Dirty's Avatar
Feedback: 21 reviews
you dont need that part
im running the crowns
www.jeepasylum.com
Dr.Dirty is offline
post #4 of 19 Old 01-14-2010, 09:43 AM Thread Starter
Did not come with instructions.
post #5 of 19 Old 01-14-2010, 09:58 AM
enigmaverse's Avatar
yeah they dont come with instructions... I didnt use it, mainly because I couldnt find any information for what it was.
Joe -
enigmaverse is offline
post #6 of 19 Old 01-14-2010, 10:08 AM Thread Starter
Did everything fit and work ok without it? How is the Jeep driving?
post #7 of 19 Old 01-14-2010, 10:10 AM
It looks like the sleeve for wheel alignment on certain vehicles (My 78 Bronco solid D44 had them). You could get them with differernt angles in them to adjust caster and or camber from alignment shops
It might of came with the balljoint incase the old one was all rusted out or damaged
Chris85xlt is offline
post #8 of 19 Old 01-14-2010, 10:11 AM
Dr.Dirty's Avatar
you dont need them
you onlt need to replace what you take out
TJ ball joints come wit it as well
www.jeepasylum.com
Dr.Dirty is offline
post #9 of 19 Old 01-14-2010, 02:41 PM
TrailDuty.com
PhilD's Avatar
The factory ball joints also come with it.
PhilD is offline
post #10 of 19 Old 01-14-2010, 02:55 PM Thread Starter
So no need to install this one then?
post #11 of 19 Old 01-14-2010, 02:58 PM
Dr.Dirty's Avatar
you cant install it there is no need for it in this application
take apart your rig and look at what you are removing and replace with the new parts
take your threaded insert and you now have a fancy key chain for your jeep
www.jeepasylum.com
Dr.Dirty is offline
post #12 of 19 Old 01-14-2010, 02:59 PM Thread Starter
Thanks guys. Gunna slap these on Monday. Hopefully they last longer than the Mopars.
post #13 of 19 Old 01-14-2010, 03:11 PM
TrailDuty.com
PhilD's Avatar
X2 I should have been clearer. Not needed.
PhilD is offline
post #14 of 19 Old 01-14-2010, 03:15 PM Thread Starter
One other thing.. I should not need an alignment after swapping ball joints, correct?
post #15 of 19 Old 01-14-2010, 03:16 PM
Dr.Dirty's Avatar
nope
www.jeepasylum.com
Dr.Dirty is offline
post #16 of 19 Old 12-19-2010, 06:46 PM
I wouldn't get your hopes up on those BJ's lasting very long...not unless you are going to grease them through the boot with a needle fitting. I'm at 64K miles and have been through the original factory BJ's and 3 sets of Crown. I'm about to do the fourth set....but only because I'm swapping my D30 out for a D44 and re-using my outters. Figure I might as well put new ones in while I have it apart. I'm really starting to think the Pro Steers are worth it. At first I didn't....I'm getting tired of changing BJ's though.
Doug
Valparaiso, IN
2007 Steel Blue X Unlimited
Rubi D44 up front with chromo shafts, riddler cover, and CTM u-joints
4" Frankenlift
black steel wheels
35" AT's
Rock Hard bumper and tire carrier
Nate's 4x4 frnt winch bumper
(custom chopped into a stubby)
Rubi rails
Rock Hard skids
KC 8" driving lights
KC 6" driving lights on KC windshield mounts
Tuffy console insert
mr_natural78 is offline
post #17 of 19 Old 12-19-2010, 06:50 PM Thread Starter
They didn't last long, I have since switched to Prosteers.
post #18 of 19 Old 12-19-2010, 10:42 PM
I went with Moog, they have a zerk fitting so you can lube them.
post #19 of 19 Old 12-20-2010, 07:07 AM
SoK66's Avatar
Pro Steer: Expensive but work
SoK66 is offline
