battery light....... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 20 Old 01-12-2010, 02:13 PM Thread Starter
ill make this short and sweet. The battery light comes on when i drive through deep snow even like 8 inches. ill drive, the snow kicks up some and it will turn on. when i turn it off and back on the light goes away. whats goin on here????
JKkeebler is offline
post #2 of 20 Old 01-12-2010, 02:18 PM
Ogie's Avatar
This is just a wild guess but possibly snow is getting on the belt causing some slippage and the alternator output drops enough to turn on the light. Either that or snow is getting into the alternator and it's not liking it.
Vidi, vici, veni
2008 Jeep JK Wrangler Rubicon Unlimited
Ogie is offline
post #3 of 20 Old 01-12-2010, 02:21 PM
ksjeep's Avatar
Mine did that too... I figured the alt got a little snow in it.
ksjeep is offline
post #4 of 20 Old 01-12-2010, 02:23 PM Thread Starter
thats what i thought but i wasnt sure...ill tell you what though its getting pretty damn annoying! anyone have an idea how to fix this problem
post #5 of 20 Old 01-12-2010, 02:33 PM
Ogie's Avatar
Do you have your splash shields still on? If you took them off like some people do, put them back on. An engine skid plate or a sway-bar skid might help, too. I'm just guessing and thinking out loud. Drive behind a PennDOT truck.
Vidi, vici, veni
Ogie is offline
post #6 of 20 Old 01-14-2010, 04:21 PM Thread Starter
lol screw penndot i rather them not plow at all! but yea i have all of the shields on still.
post #7 of 20 Old 01-14-2010, 05:15 PM
Id almost believe this to be related to the battery temp sensor if multiple people are having the same issue in the snow.
Id plug in a decent scan gauge & go find some snow. Check the parameters of all related components.
Thean Bellocchi
Poly Performance Inc.
Sales & Tech Support
805-783-2060 Ext. 200
crusty1007 is offline
post #8 of 20 Old 02-04-2010, 04:42 PM
jacktuttle's Avatar
Exclamation Battery Light
I'm having about the same issue. For the last month my Battery light randomly comes on and stays on until the next time I start the engine. Some days it comes on 2 or 3 times in the course of the day. I drove 3 hours home from Truckhaven to Fullerton with it on (Part way in the dark) and no hint of a low battery. I'm watching for a tester I can plug into the lighter outlet just to be sure, but after a month and the battery is not dead, I'm thinking the alternator is working......
jacktuttle is offline
post #9 of 20 Old 02-04-2010, 05:14 PM
sniper41's Avatar
Humm, Keebs I'm surprised, I've been out in the snow too, my skid was "ripped" off a year ago and I haven't had this happen. I'll let you know though if it does this weekend. It might be something else. What year is your rig and do you have extra stuff running off the battery?
Jersey
Crew
sniper41 is offline
post #10 of 20 Old 02-04-2010, 07:27 PM
jacktuttle's Avatar
Post Tester
I stopped at PepBoys and picked up a little tester that plugs into the lighter outlet. Sure enough when the Red Battery light comes on it is not charging.
post #11 of 20 Old 02-05-2010, 09:42 AM
HG07JKRubi's Avatar
computer throwing any codes
Is the computer throwing any codes ? You can check yourself if you don't have a scan tool by turning the key from OFF to ON 3 times in a row ending in ON position and any codes will show on the odometer. My battery light has been coming on this week as well and I'm getting codes:
P2503 Charging System Output Low
P2504 Charging System Output High
Had the Jeep in the shop yesterday to get looked at and everything checked out ok, battery, alternator. They recommended TSB 18-036-06 which is for a battery light issue. Having that flash done today at a local dealer we'll see what happens.
2013 Unlimited Rubicon - Billet Silver
2.5" Teraflex coil lift | 35" BFG AT KO2s | AEV Pintler Wheels - Onyx
HG07JKRubi is offline
post #12 of 20 Old 02-05-2010, 10:59 AM
jacktuttle's Avatar
Thumbs up Good Info!
I will try this as soon as I get off work! Thanks for the info.
post #13 of 20 Old 02-05-2010, 12:22 PM
HG07JKRubi's Avatar
Post up what you find. I just got back from the dealer after having the TSB 18-036-06 flash update at no charge !!! We'll see if the battery light comes on again
post #14 of 20 Old 02-05-2010, 12:56 PM
jacktuttle's Avatar
Post No Codes
I tried this at lunch. No codes, got fast food and the Battery Light came on. Checked again and no codes. I'll try and find a code reader.
post #15 of 20 Old 02-05-2010, 01:14 PM
jacktuttle's Avatar
Post 07 - 08
I called the Stealership, they said that the 07's will give the codes on the dash, but not the 08's... Guess I'll have to let them take a look at it....
post #16 of 20 Old 02-06-2010, 04:45 PM
jacktuttle's Avatar
Talking Fixed
I took it to the StealerShip on Friday afternoon. They told me it would be $110.00 to check it out and that my warranty had expired 4 days earlier when I went over 36000 miles. I asked about the $0 deductible 7 year 100,000 mile extended warranty that they had sold me. They had no record of it. (Of Course). I did not pay the $110.00 instead came home and had the wife dig up the warranty paperwork. I went back on Saturday with the paperwork. I talked with the Service manager and he agreed to cut the fee in half to $55.00 to check it out and if it was a covered repair under the extended warranty then no charge. As they were now meeting my half way I agreed. The mechanic found that the positive battery cable was loose at the post. He tightened it up and that seems to have solved the problem. Of course that is not a warranty issue because I have replaced the battery and added some accessories. I happily paid the $55.00 and gave the mechanic a 12 pack for tomorrows game.
post #17 of 20 Old 02-06-2010, 04:59 PM
paramaniac's Avatar
Thats bogus... i was getting a random "ding" with no warning light on the dash. i called the dealership to inquire. the instructed me to read the codes off the odometer, walking me through the steps with the key... i wouldnt trust them all too much... after reading your post about them not having the extended warranty... i wouldnt trust them at all!!
i see you have an "Easy Button"
have you seen the "Bullshit" buttons?
paramaniac is offline
post #18 of 20 Old 02-06-2010, 05:26 PM
jacktuttle's Avatar
Easy Button
Of course it has an easy button, it's a Rubicon!
No I don't trust the Stealership, What was the combo to get the codes?
post #19 of 20 Old 02-06-2010, 05:36 PM
Wow. 55$ to tighten a battery cable. I think they made out pretty good!
glad you got it fixed at least.
savage is offline
post #20 of 20 Old 02-06-2010, 05:44 PM
jacktuttle's Avatar
Post 55$ to tighten a battery cable
Yes I was thinking the same thing, but still better than the $110.00 they wanted...... On the plus side they said if the light cam back on there would be no additional charge. (Means they knew it was high to tighten one nut). . .
