? NG 44 Gear Change - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 01-11-2010, 10:11 AM Thread Starter
Broncojohn's Avatar
? NG 44 Gear Change
I will start with, if you don't due your own gears please do not reply.
Did you reuse the oil hold back ring (shim that looks like a hat) when you replaced the inner pinion bearing race? I'm going to try and clean this one up but I'm curious how many people run without one.
This wasn't in the plan; I've been looking for a replacement but haven't been able to place my hands on one. I had no intention on replacing my bearings until I opened housing. I had the front axle serviced twice by the dealer due to oil leaks and when I drained the housing I got a cup of gear oil out. The service manager told me he fixed it and it wouldn't leak again I didn't think they would take it to the extreme. So now I'm replacing the bearings (easy to find local).
On the older HP 44's I usually junked it and place a shim there; but that was on a part-time unit with lock out hubs.
Any vendor that has the part can chime in too, but I'm suspecting it's only going to be supplied in a Kit which I don't want to buy.
Broncojohn is offline
post #2 of 6 Old 01-11-2010, 02:32 PM Thread Starter
Broncojohn's Avatar
OK, Idid some home work at the stealership. Apparently they do sell the part: 68004076AA. You have to rub the parts clerk the right way, and I guess they can look it up. $.60 MSPR.
I've been looking at the Overhaul kits from other Gear Vendors and this doesn't appear to be in it. I wonder if anyone is running one after a gear change? I don't see any way of removing the race without damaging it.
post #3 of 6 Old 01-12-2010, 06:49 AM
Stickdude's Avatar
I just got done putting my front diff back together last night. I did put a new 68004076AA (baffle as the parts manual calls it) in. I gave the dealer the part no. and they had no problem ordering it (next day delivery). My Yukon overhaul kit did not have one in it. I don't know of a good way to get that race out without damaging that baffle. Surely someone makes a special tool to do that. Maybe we could invent a tool. I don't know what the ramifications of not putting it in might be and I did not want to chance it.
Stickdude is offline
post #4 of 6 Old 01-12-2010, 03:00 PM Thread Starter
Broncojohn's Avatar
Thanks for the input. I removed mine with a big slot screwdriver and a deadblow. It took a few blows but the baffle has straightened out well. I figure most shops are trying ot reuse them or just putting a shim in place. The carrier shims are the same size but donít provide the baffle. I have my order in for a couple of baffles and they will be in tomorrow. The Yukon kit is the one I looked at in the local Jeep shop, my Superior install kit didn't have it and I'd bet the overhaul kit doesn't either, since the local Gear shop (They overhaul anything with gears) couldn't even find it in any Dana manual. Itís probably a Chrysler proprietary part and no other vendor has them. More money for Jeep.
I wonder what new experience the rear will provide? The dealer hasn't touched that one so it should be service full.
Have you broken into your rearend yet?
post #5 of 6 Old 01-12-2010, 08:49 PM
Stickdude's Avatar
Haven't got to the rear yet. As soon as I get the front back in I will start on the rear.
post #6 of 6 Old 01-12-2010, 09:09 PM
bodyguy's Avatar
The only surprise I can think of in the rear is watch the axle bearing race when you pull the shafts. The race fits loose in the housing and will hit the ground running.
bodyguy is offline
