ESP - JKowners.com : Jeep Wrangler JK Forum
post #1 of 17 Old 01-10-2010, 06:07 PM Thread Starter
ESP
i have the 4" teraflex suspension kit installed today.. still have the 32" tires on my 2010 rubi unlimited... and esp is going crazy, its undrivable.....
ill be putting 37's on this week, and i have the aev cal deal in route, but should it be this bad with stock tires??
2010 Trail Rated Convertible MiniVan
DeepWater Blue
4" Teraflex, 37" BFG's on Spyderlocks.
Chrispy is offline
post #2 of 17 Old 01-10-2010, 06:11 PM
wiredawg_mg's Avatar
Damn you are everywhere
Have you recentered your steering wheel yet.
Even Stang knows a mall crawler needs to have the wheel centered.
If it isn't the ESP will lose its mind
Jeep Green-08-Rubicon Unlimited
4" Teraflex lift with Flex arms and forged Track Bar
37" IROKS
Rock Hard Oil/tranny/transfer case/gas tank skids
LOD Front Stubby/IPF 900XS Driving Lights
Warn Powerplant HP
Shrockworks Rear Bumper
5.13s and Superior Rear Shafts
RCVs
Solid Diff Covers
Cobra 75 WX ST/3' Firestick II
Wood SS Braket/Evap Relo kit
TF SS
Driveshafts Unlimited front Driveshaft
Tom Woods Read Driveshaft
Homemade swingaway
wiredawg_mg is offline
post #3 of 17 Old 01-10-2010, 06:13 PM
s10x1000's Avatar
Yea make sure you re center the wheel. You may have to do it a few times to get it right.
s10x1000 is offline
post #4 of 17 Old 01-10-2010, 06:45 PM
if your wheel is centered make sure they didn't strech out one of your lines and have it come loose. down by the brakes is the most common spot for it to happen. i bet it is your steering wheel tho. just 2 15 or 16 mm (can't remember the size for sure) bolts and twist and re tighten in small increments. helps to have a friend at the wheel to yell at you when you go the wrong way lol. good luck
2010 Rubicon unlimited / rock krawler long arm
ome +40 long travel lift / 17 spyderlocks / 38 bfg km2's/ 5.38 gears/ sleeves
poison spyder customs crusher flares/ body armor/ diff covers/rocker knockers
lod stubby ftont and rear/ evap skid/ coast driveshaft 1310/ rcv & superior axle shafts
warn powerplant / aev drag link flip/ currie tie rod/ reid knuckles, prosteer ball joints
c2 gussets and lca skids/ rock stars/ speed bumps/ rk tranny pan/ redneck ram hydro assist
codysanders is offline
post #5 of 17 Old 01-10-2010, 09:42 PM Thread Starter
I was going to take it down to denver to get it alligned tommorrow...is this wise (after installing a lift kit, ive had all my vehicles alligned in the past..).. my assumption was they would fix the steering wheel...
thats probably it. will know tommorrow night i guess.
DeepWater Blue
Chrispy is offline
post #6 of 17 Old 01-10-2010, 10:06 PM
jeeperjkj's Avatar
DO NOT pay someone to center your wheel!
Anyone can do it. Heck, I do it with my 8 year old sitting in the driver's seat to tell me if I'm going the wrong way and to tell me when it's centered.
jeeperjkj is offline
post #7 of 17 Old 01-10-2010, 10:10 PM Thread Starter
wasnt going to pay them to center my wheel.. but to do an alignment... yea, i can recenter the wheel easy enough..
DeepWater Blue
Chrispy is offline
post #8 of 17 Old 01-10-2010, 10:11 PM
jeeperjkj's Avatar
Heck, you can do the whole alignment. Just takes a little bit of time and a few wrenches.
post #9 of 17 Old 01-10-2010, 10:23 PM
Aligned is a great idea. They may or may not center your steering wheel. I'm really anel about my SW being centered so I do that myself. Its easy since the drag link can be adjusted. Usually takes me 3 or 4 trys to get it just right.
post #10 of 17 Old 01-10-2010, 10:58 PM
MarcusRTJ's Avatar
If it helps you in the meantime you can take your owners manual out for reference and disable ESP completely.
Working from memory but:
Get your wheels straight first...(now that I'm thinking about it this might not work if the SW isn't centered)
Turn your key to "ON" position (DON'T START) and wait approximately 5 seconds for all of your dummy lights on the dash to quit. Then shift T-Case into 4HI.
Turn wheel from center to 1/2 turn to the right and hold it. Hold down ESP for 7 Seconds.
Turn wheel back to straight and hold ESP down for 7 seconds.
Turn wheel 1/2 turn to left and hold ESP down for 7 seconds.
Turn key off.
Turn key back to on position.
Jeep with squiggly lines under it should be on in center dash and you should get a read out saying "ESP disabled" for approximately 12 seconds each time you start the Jeep.
I believe you get a ding when you do it right. Usually takes a couple of run throughs.
Good luck!
MarcusRTJ is offline
post #11 of 17 Old 01-11-2010, 01:25 PM
STANGJEEPER's Avatar
Recenter your wheel before ya try to drive it. Yes the alignment will do the same, but if you do it now, Your drive into town and off the side of the mountain may be more enjoyable.
08 Rescue Green Rubi - SOLD
O5 - LJ Rubicon RK Xfactor long arm
STANGJEEPER is offline
post #12 of 17 Old 01-11-2010, 02:16 PM Thread Starter
did the steering wheel correction last nite, helped.
alignment is finished, all is well except castor
factory spec is according to thier computer, 4.7, and after the LCAs dialed in best i could get was 6.2... the alignment tech says this wont effect anything other than returning to center 'harder' than stock. upper front and lower rear control arms are on my short list of future upgrades.
DeepWater Blue
Chrispy is offline
post #13 of 17 Old 01-11-2010, 04:41 PM
Once you get the 37s on you may like the Castor at 6.2. A little extra with the bigger tires is a good thing. Should help it run down the road a bit straighter.
So were the PICS? You have posted on MWJT yet
37" IROKS
Warn Powerplant HP
RCVs
Solid Diff Covers
TF SS
Homemade swingaway
post #14 of 17 Old 01-11-2010, 11:51 PM
I agree with the more castor thing here and 37's. Mine is set at 5.5 with the 37's and seems to track nicely going down the road at 65-70 mph. when it was down lower 3.5 it was very flightly and wanted to follow the grooves.
Now pics or DIAF
post #15 of 17 Old 06-19-2010, 11:34 AM
Mike's Avatar
Turn key off.
Good luck!
Hi thanks for the info. I just did this and it seems to work. right after I did this I put it back it 2WD and spun the tires and the squiggly came on on the dash , does that mean it doesn't work in 2WD? I know this is an old post but I am seriously thinking about putting a switch in to disable the esp if this doesnt work in 2WD. Thanks
Mike is offline
post #16 of 17 Old 06-19-2010, 11:51 AM
StubEXrube's Avatar
You might want to try it again- not sure if the disable is year-specific, or if the attempt was unsuccessful. Mine does it in 2wd around tight corners when one wheel loses traction, but I haven't disabled mine.
StubEXrube is offline
post #17 of 17 Old 06-21-2010, 06:21 PM
Mike's Avatar
Put in switch
I went ahead and put in a switch. I couldn't get the steering wheel dance to work on my 07.
the dash picture is with the switch on. The engine lite goes off when I start the motor.
Mike is offline
