help with engine noise - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 01-09-2010, 12:46 PM Thread Starter
SONIC's Avatar
Got jeep back from dealer and they replaced the starter. Now I'm noticing a pronounced whirring sound. Sounds like an rc car almost. It increases with rpms and gets louder. I first noticed it at idle.
Also herculined the tub so maybe I'm hearing normal noise? Doubt it though.
So any ideas?
-Doc Holiday
SONIC is offline
post #2 of 12 Old 01-09-2010, 01:28 PM
could it be a belt??
Jpaye is offline
post #3 of 12 Old 01-09-2010, 05:45 PM
My guess would be a belt and/or pulley
Yosh_Lopez is offline
post #4 of 12 Old 01-10-2010, 04:53 PM
tkob1060's Avatar
might be idler, but sounds more like its the tensioner pulley
tkob1060 is offline
post #5 of 12 Old 01-10-2010, 05:04 PM
NE Wrangling's Avatar
Hope they accidentally installed a supercharger for you. Ha Ha
serious note, check the belts and tension.
jk-forum, jk forum, jkforum, jeep jk wrangler, jk-forum.com, jeepforum, jk-board.com, wayoflife, 2007 jk, 2008 jk, 2009 jk, 2010 jk, jk, jk wrangler
Never argue with an idiot, they will bring you down to their level then beat you with experience.[/SIZE][/B]
NE Wrangling is offline
post #6 of 12 Old 01-10-2010, 05:25 PM
tkob1060's Avatar
u do mean belt not belts right? and the tension isn't adjustable, but the tensioner pulley has same pulley as the idler bolted to it. It likes muddy water as much as the idler.
Justin didnt I tell ya to replace both of them already
tkob1060 is offline
post #7 of 12 Old 01-11-2010, 02:18 PM Thread Starter
SONIC's Avatar
Replaced both idler and tensioner already. Turns out its the ac compressor.
So another three fifty plus three hundred labor
-Doc Holiday
SONIC is offline
post #8 of 12 Old 01-11-2010, 05:22 PM
tkob1060's Avatar
$650? damn thats a good price, but you sure? that noise shouldnt really change with rpm, does it pretty much stop when you turn the a/c on? thats when the inner pulley magnetically locks to the outer pulley you can actually watch it. I paid $770 for mine, dealer originally wanted 925
I guess your "friend" is paying for it right?
tkob1060 is offline
post #9 of 12 Old 01-11-2010, 07:37 PM Thread Starter
SONIC's Avatar
I can get just the compressor for 330 from mopardiscountparts, and they want 290 to install and charge it.
But i dont think thats what it is, im going to try and find somewhere to get a second opinion.
I can definitely hear it change with clutch usage, so im going to go somewhere else ans have them take a listen.
The gy at the dealer pulled the belt though and spun the ac compressor and said that it was making the noise and got another guy to verify too, but i never personally heard it.
-Doc Holiday
SONIC is offline
post #10 of 12 Old 01-11-2010, 07:44 PM
scottrock's Avatar
By "It changes with clutch usage" you mean turning the AC on and off? Or do you mean the clutch clutch? A whirring sound with the clutch out that goes away when you engage it is typically throwout bearing.
Either way, your battin a thousand today.
scottrock is offline
post #11 of 12 Old 01-11-2010, 08:09 PM
tkob1060's Avatar
I
I can say with certainty if the noise stops or gets a LOT quieter once the a/c comp clutch is engaged thats what the problem is. The mud or dirt is trapped between the two pulleys while the inner is not spinning the outer rotating around it grinds that dirt making the noise, soon as they lock together when engaged its almost gone. If its changing at idle with it off and on its definitely that. Have someone sit in Jeep and turn a/c on and off, you can see it lock up and the noise change/stop.
tkob1060 is offline
post #12 of 12 Old 01-11-2010, 08:22 PM Thread Starter
SONIC's Avatar
I meant the clutch clutch, transmission clutch.
And ill check it out in the morning if it changed with AC usage
-Doc Holiday
SONIC is offline
