Can a Rubi 44 Front-End work in an "X" model??? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 01-03-2010, 10:31 PM Thread Starter
cruzcode's Avatar
So I want 5.13s with lockers in my automatic "X", and I don't want to (and shouldn't) build-up my Dana30 in my Automatic Unlimited "X" model...
Does anyone know if I was able to get my hands on a Rubi 44 front-end with facoty electric locker, if this would work seamlessly into my "X" model? OR will I have front driveshaft length/compatibility issues due to the transfer case difference, and/or problems with the link connections, brakes, or anything else?
Also, does this seem to the easiest (and most cost-effective) way to swap a 44 with a locker into my Automatic X?
Thanks in advance!
RC
__________________
2008 Unlimited X - Black w/ Freedom Top
5" BDS Suspension Lift
35"/12.50"/17" Pro-Comp Extreme Mud Terrains
Hanson 66" Offroad Front Bumper
Smittybilt XRC Rear Bumper w/ Tire Carrier
Smittybilt XRC-10 Winch w/ Synthetic Rope
Smittybilt Polished Hawse Fairlead
AirAid CAI
aFe Billet Throttle Body Spacer
aFe Cat-Back Hi-Tuck Exhaust
Superchips Flashpaq
PIAA 540 Extreme White Driving Lights
KC Hi-Lites Windshield Mounts
more to come...
cruzcode is offline
post #2 of 12 Old 01-03-2010, 11:19 PM
venom's Avatar
check this out
https://www.jkowners.com/tech/axle/index.php
Originally Posted by My Wife
venom is offline
post #3 of 12 Old 01-04-2010, 04:21 AM
It is essentially a bolt in operation. You may need to have the dealer flash the computer if you want to use factory switches to operate the locker with the dash indicator, etc.
2007 Redrock X two door
Auto
Hardtop
D44 rear
17" Moab wheels
32" BFG M/Ts
Rubicon Rock Rails
Airaid intake
Infinity speakers
pearl-drum-man is offline
post #4 of 12 Old 01-04-2010, 06:12 AM
seer's Avatar
Other than the bolts it's just hooking up some wires, light and switch to make the locker operational.
seer is offline
post #5 of 12 Old 01-04-2010, 06:47 AM
Definitely works. I have done it. It will also give you the opportunity to wire the lockers the way you want.
smokey is offline
post #6 of 12 Old 01-04-2010, 07:04 AM
YES!!!!!!!!!!!!!!
BOSS is offline
post #7 of 12 Old 01-04-2010, 07:53 AM
FUN LS1's Avatar
You realize it's the same weak ass housing as found in a D30 right?
-Established April 1, 1983-
No dues, No rules, No President
ALL FUN!
FUN LS1 is offline
post #8 of 12 Old 01-04-2010, 08:22 AM
terrahawk's Avatar
If you'er stying wiht 35's, don't bother. Just use the Poly axle housing kit to beef it up and you'll be fine.
terrahawk is offline
post #9 of 12 Old 01-04-2010, 08:28 AM
FUN LS1's Avatar
That's what I did. Running 35's with the Poly complete kit and am very happy.
ALL FUN!
FUN LS1 is offline
post #10 of 12 Old 01-04-2010, 09:14 AM Thread Starter
cruzcode's Avatar
I want to go 5.13s and add 37's at some point. What is the Poly kit???
A lot of chit coming...
W9DRC
cruzcode is offline
post #11 of 12 Old 01-04-2010, 09:23 AM
usmcdoc14's Avatar
if you are going that big you may as well get the 44 and upgrade the shafts sooner or later as well. The tech I wrote (that is linked above) shows how retardedly simple it is to bolt in a rubi 44 AND make the locker fully functional without tieing it into anything factory.
Or you can save that cash, gusset/truss the 30, upgrade the shafts and drop in a lunchbox locker.
The Poly kit is similar to the RSE sleeve kit I put on mine and I used Poly Performance C gussets over the RSE C gusset. With the JK 44 (or 30 for that matter) You WANT to gusset the C's and seriously consider a truss of some kind.
usmcdoc14 is offline
post #12 of 12 Old 01-04-2010, 09:27 AM Thread Starter
cruzcode's Avatar
Wow, I just read that linked article, and not only was it very informative, but freaking hysterically written. Well done!
A lot to ingest there, but it appears that this is the way to go. Question: Does the rear Dana 44 require the same gusset/truss strengthening too???
Thanks -- RC
W9DRC
cruzcode is offline
