5.3 LS swap with NSG370 6MT - JKowners.com : Jeep Wrangler JK Forum
post #1 of 55 Old 07-16-2014, 01:05 AM Thread Starter
I am about to swap an Aluminum block LC9 5.3 into my 2010 JKUR. I am staying with the NSG370 by swapping to an '06 TJ trans and using the Novak adapter. The TJ NSG has a larger front housing that will fit an LS with the adapter. The swap will be done by my race car mechanic. He is a very talented mechanic, engine builder, fabricator, etc.
I decided to go with a Novak "kit" for this swap. The kit is not quite as complete as Motech or JSS as it does not include brackets for the Jeep accessories. But, with headers, clutch and related parts, total for Novak was ~$3700 or about $3k cheaper than the others when you factor in buying all the Novak specific stuff for the Manual trans with the cost of the other kits w/o the auto trans stuff . Fabbing our own brackets will cost under $500. That said, I searched and cant find anyone else that has used a Novak kit in a JK -lots TJ, YJ and CJ swaps... so breaking some new ground perhaps.
Anyway, the LC9 is getting pulled by the wrecker now and has 24k miles and was from a 2010 Silverado. I get the engine tomorrow and will ship the ECU and harness to Novak for modification. We are doing a AFM and DOD delete as those don't work well with a Manual Trans. Also will put in a mild cam that does not sacrifice much low end TQ.
The NSG was bought on Flee Bay and has 40k miles.
The NSG is only rated for 272TQ, so we are outside that with 335TQ from a stock 5.3. depending on the cam, peak TQ will increase 15-20TQ. I am not worried as it seems there are many boosted 3.8 and 3.6 that are pushing past 272TQ with out problems.
For Cruise Control, we are going to use an after market Rostra set up.
The swap hopefully start late next week with removal of the "turd". "You can polish a turd, but at the end of the day it is still a turd!"
I will update as things progress.
85258 is offline
post #2 of 55 Old 07-16-2014, 10:23 AM
Scooter Scott's Avatar
Subscribed!
2009 Deep Water Blue Wrangler Unlimited X
37x12.50x17 Pitbull Rockers on KMC Machetes
Synergy 3" Coils/Rancho 9000XL Shocks
Currie Antirock
Yukon 5.13's
Sleeves/Gussetts
JKS Rear Trackbar
ProRock 44
Front/Rear ARB Air lockers
Scooter Scott is offline
post #3 of 55 Old 07-16-2014, 12:18 PM
Sounds like a pretty nice swap to me. A V8 really makes the JK a great vehicle.
scubatech is offline
post #4 of 55 Old 07-16-2014, 02:09 PM
Ringer's Avatar
I have looked into this as well. I plan on doing my swap next year with the 5.3, and either the NSG370 or a built up AX15 with a R151 first gear installed. I am hoping to do the entire swap for around $5-6k.
What are your plans for electrical? I have debated completely requiring the whole vehicle with aftermarket gauges or getting MoTech or JSS to reflash the computer.
Ringer is offline
post #5 of 55 Old 07-19-2014, 07:00 AM
calhoub's Avatar
I'm just gonna go ahead and subscribe to this...
07 Unlimited Rubicon Rescue Green
37 IROKS, 5.38 Gears, 6Spd, 3.5" lift Poison Spyder front bumper, 8k XRC winch, Smittybilt Atlas rear bumper, Poison Spyder fender flares, Rigid Fog lights, Superchips tuner, Hydro assist, HID projector headlights, HD/custom tie rod & drag link, sound system, custom tree damage.
calhoub is offline
post #6 of 55 Old 07-19-2014, 07:14 AM Thread Starter
Ringer: all the gauges work with Novak's kit. I am sending them the LS ecu to tune it and the LS harness to modify it.
A couple things that don't integrate - the CEL will be on. They have an LED light in kit the works with LS ecu for CEL. We will try to tie the ls ecu to factory light if we can. The traction control won't work properly and will have warning light on as they can't tie into the Ls electronic throttle. Stability control will still work.
Call Novak as they will sell you any part individually. The kit was actually quoted to me as individual part numbers with prices.
85258 is offline
post #7 of 55 Old 07-19-2014, 09:04 AM
Sgo70's Avatar
Where in Alberta are you located? I'm in Calgary and did the Motech LS swap with a 2012 LC9 and 6L80. It would be nice to know a good mechanic to help out once in a while. I keep thinking I should drive down to Vegas and get Robbie to go over my work and fine tune it if needed but that's a 24 hour drive.
Sean
Sgo70 is offline
post #8 of 55 Old 07-20-2014, 05:24 AM
AOR
AOR's Avatar
I would not recommend using an NSG370 behind a 5.3
Talk to the guys at Bruiser conversions. They were telling me that the 4bt was breaking them at idle when turning the engine off. They were telling me that the NSG370 is weaker than both the AX-15 and 3550 transmissions. Also keep in mind the weight of the JKU. I would not recommend using an AX-15 or 3550 either.
AOR is offline
post #9 of 55 Old 07-20-2014, 05:33 AM
Ringer's Avatar
For other options, look at a "Terminator" AX-15. They are rated for 385hp.
Ringer is offline
post #10 of 55 Old 07-20-2014, 08:31 AM
Robbs2008JK's Avatar
Do the Nv4500. That thin will take a beating the you will have a 6:1granny gear or a nv5600 the jku has more than enough room to run those trannys
My build
Robbs2008JK is offline
post #11 of 55 Old 07-20-2014, 09:51 AM Thread Starter
I was concerned about the strength of the NSG370, but Novak said it works very well with a mild 5.3. I also looked at the TQ rating of Ripp supercharged 3.8 and 3.6s and I did not see any posts of guys failing NSG370s with these set ups. If I was building a hard core rock crawler I would go with something stronger...
85258 is offline
post #12 of 55 Old 07-20-2014, 10:54 AM
Ringer's Avatar
I looked at this option, but I am a two door with flat belly, and would prefer to keep my Rubi t case. I can build a 4.3 1st gear AX15 rated for 385 hp. I would think that it would fit much better, and should hold up just fine to a mild 5.3.
Ringer is offline
post #13 of 55 Old 07-20-2014, 03:01 PM
I will be using the NV4500 maybe NV5600 when I do my v8 swap. But I am a 4 door and will be running atlas or TWF transfercase
My build
post #14 of 55 Old 11-28-2014, 10:14 PM Thread Starter
Wow, long over due for an update. The swap started a couple months later than I hoped, but it is coming together. My mechanic has not been able to work on it full time. At this point all that is left is the wiring and plumbing. Once he is done he will provide a write up for me.
A few highlights. We deleted the DOD on the 5.3 and installed a pretty stout cam from comp cams. http://www.compcams.com/Company/CC/c...?csid=1620&sb=
Should provide around 80hp and 50tq gains in peak power with 100hp on the top end and a minimal loss in low end tq due to the VVT. TQ starts to gain around 2000rpm. Here are the cam specs:
http://www.compcams.com/Company/CC/c...csid=1620&sb=2
We did have a few issues with Novak kit. First they were slow to modify the wiring harness.
Then the parts for the manual Trans were not right as the input shaft was short of the pilot bushing.
The instructions were not very good
The kit does not come with PS or AC brackets. We tried to source from Motech, but after a few emails and no replies my mechanic fabbed some up.
Anyways, should be done this week. I have a few other mods getting done before I pick it up (rear axles, aux lights, camera, e locker switches, AEV CHMSL)
Name:  ImageUploadedByAG Free1417237911.392496.jpg
Size:  698.3 KBName:  ImageUploadedByAG Free1417237933.165933.jpg
Size:  681.8 KBName:  ImageUploadedByAG Free1417237947.171737.jpg
Size:  599.0 KBName:  ImageUploadedByAG Free1417237965.166001.jpg
Size:  596.3 KBName:  ImageUploadedByAG Free1417238015.111885.jpg
Size:  675.1 KBName:  ImageUploadedByAG Free1417238030.508375.jpg
85258 is offline
post #15 of 55 Old 11-28-2014, 10:15 PM Thread Starter
85258 is offline
post #16 of 55 Old 11-29-2014, 08:38 AM
jss
jss's Avatar
Why don't you just use the GM accessories? on the front of the engine.
["jeep speed shop The GuineaPig Build"]
VVT Truck Hemi Conversions
The ONLY CARB LEGAL JEEP ENGINE CONVERSION
7911 Redwood Dr, Cotati, Ca. 94931
707-338-3154
jss is offline
post #17 of 55 Old 12-03-2014, 09:04 PM Thread Starter
We did not use the GM accessories as we would have to fab hose and the potential for different pressures or volumes between the two systems.
Do you use the GM accessories, JSS? I think Motech uses jeep accessories.
85258 is offline
post #18 of 55 Old 12-05-2014, 08:15 AM
jss
jss's Avatar
Yes we use the GM Accessories, no adapting. Less chance for belt problems and easier for getting parts, because it is all GM. We have not seen any problems with the AC or the Alternator. I have been driving our GuineaPig for 2 years and have had no problems.
707-338-3154
jss is offline
post #19 of 55 Old 12-11-2014, 05:40 AM
calhoub's Avatar
Any progress? Come on..
calhoub is offline
post #20 of 55 Old 12-15-2014, 11:43 PM Thread Starter
Still not done. Went to wire up the throttle and Novak forgot the harness for that. Been waiting close to two weeks for it...
85258 is offline
post #21 of 55 Old 12-17-2014, 10:24 AM
kly5953's Avatar
subscribed....I got a new uncle that knows how to fab and from what i'm seeing, i might be able to swing this. I know i'd love to do this instead of regear the axles anyway.......plus i miss the sound of my old 5.3
kly5953 is offline
post #22 of 55 Old 12-25-2014, 07:34 PM Thread Starter
Update... The drive by wire harness finally arrived a week ago from Novak, but one of the plugs was wrong and there were two connectors with the same number.
That was sorted out this week and everything was plugged in, the engine was turned over to ensure proper belt fit, then the rad and grill installed. Then the keys were locked in the the Jeep...
Almost there.
It should be finished up in the first week of the new year.
85258 is offline
post #23 of 55 Old 12-26-2014, 07:25 AM
Ready to see this running... just like you!!!!
4x4x4 is offline
post #24 of 55 Old 12-26-2014, 07:37 AM
H8MUD's Avatar
Subscribed.
H8MUD is offline
post #25 of 55 Old 12-27-2014, 03:27 AM
calhoub's Avatar
I'm just wondering how well the trans is gonna take the engine. I know people have done the swap before on other vehicles, but.. it still always seems to be a questionable swap. Can't wait for you to have it running for a good 6 months & see how it holds up.
calhoub is offline
