Coil Spring Scoliois? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 35 Old 12-19-2009, 04:24 PM Thread Starter
Coil Spring Scoliosis?
Just finished wasting five hours today, installing and uninstalling, Currie 4" coils springs.
A fellow Jeeper who has installed coil springs on several vehicles, assisted. After installing the passenger front first we noticed the spring was bowing in and out and in and out all the way from the perch to the frame mount. Looked like a stack of dimes.
Anyway we commenced with the driver side hoping that having both in would alleviate the bowing on the passenger side...not so much.
FYI The axles is centered and all control arms are same length.
FYI these pics only capture one dimension, they are bowed both fore and aft.
We then noticed the Currie springs are not flat at the point were they sit in the frame mount. To demonstrate, I stood up both the Jeep's current aftermarket spring and the Currie spring on there frame mount side on our patio, (well tried in the case of the Currie spring). Here is a link to a short movie showing the demonstration. The movie takes a few moments to load.
http://gallery.me.com/fatratofacat#1...&bgcolor=black
As you can see the Currie spring is not flat on it's top. In addition, we found an OEM spring and laid it on it's top end and it also stood straight up.
Could this phenomenon explain why the Currie springs sit all akimbo when installed? These bow so much we could not connect the driver side swaybar link.
I am not a rocket scientist, for certain, but I feel as though I am not a simpleton either. What are we missing? Is there some technique I am not aware of when installing springs in a Jeep? I found no installation instructions with the springs.
HELP!
2007 Rubicon Unlimited (Auto)
37 x 12.5 x 17 MTR/Kevlar
JeepyJeep is offline
post #2 of 35 Old 12-19-2009, 04:36 PM
bodyguy's Avatar
I assume the springs are new? That is pretty bad for new springs, mine did that after a year but that's because I didn't cut, rotate and re-weld the lower spring pads. When you lift the jeep the angle changes on the spring pad due to suspension geometry, normally it take a while for the springs to bow.
bodyguy is offline
post #3 of 35 Old 12-19-2009, 04:49 PM Thread Starter
Ya and i have my caster set relatively low and the control arms are same length. Very frustrating. Calling retailer first thing Monday morning.
post #4 of 35 Old 12-19-2009, 10:00 PM
Broncojohn's Avatar
Did you have to compress the springs to get them in? The stand-up test isn't really a good one. I've seen some that will and some that wont.
Broncojohn is offline
post #5 of 35 Old 12-19-2009, 10:44 PM
I had the currie rock jock 4" lift installed a few weeks ago. The front springs bow forward slightly but not alot. I did notice theres a notch in the bottom spring pad to seat where the coil ends. I noticed a popping noise caused by the right spring rubbing the bump stop thats been to added the lower spring pad. A little lube and the popping is gone.
bondsy is offline
post #6 of 35 Old 12-20-2009, 04:41 AM Thread Starter
Yes we did compress them.
For clarification, are you saying you believe that the Currie spring's angled top (frame mount side) does not contribute to the bowing?
post #7 of 35 Old 12-20-2009, 09:13 AM
seer's Avatar
Is that the ACOS I see in there? It almost looks like that's angled too.
seer is offline
post #8 of 35 Old 12-20-2009, 09:52 AM Thread Starter
No, just rubber bumpstops.
post #9 of 35 Old 12-20-2009, 10:39 AM
Dr.Dirty's Avatar
Feedback: 21 reviews
ive seen this withe a couple sets of curries springs
www.jeepasylum.com
Dr.Dirty is offline
post #10 of 35 Old 12-20-2009, 10:55 AM Thread Starter
Thanks gonna call them tomorrow. I am unclear as to how these springs can sit straight between perch and frame mount when they cannot sit up straight freely on their own. But I may learn something after speaking with them.
post #11 of 35 Old 12-20-2009, 11:36 AM
seer's Avatar
Man, I'd expect this outta Rubucon Express, but Currie?
seer is offline
post #12 of 35 Old 12-20-2009, 11:55 AM Thread Starter
I won't say it's Currie's fault until I speak with them. I am relatively new to working on vehicles so it's possible I am missing something, but I can't put my finger on it.
post #13 of 35 Old 12-20-2009, 01:51 PM
BLK RUBI ON 40s's Avatar
Dang jan, Cameron told me they bowed a bit, but that I ridiculous. Definitely give currie a call and see what they have to say.
BLK RUBI ON 40s is offline
post #14 of 35 Old 12-20-2009, 03:03 PM Thread Starter
Ya first thing tomorrow.
post #15 of 35 Old 12-20-2009, 04:02 PM
Dr.Dirty's Avatar
My RE springs are the only good thing about the lift lol
www.jeepasylum.com
Dr.Dirty is offline
post #16 of 35 Old 12-20-2009, 04:29 PM
seer's Avatar
Ha! My buddy's TJ has an RE lift and anymore I'm spendin' more time helping him out than I am on my own Jeep.
seer is offline
post #17 of 35 Old 12-21-2009, 03:10 AM
Broncojohn's Avatar
I don't believe the top would cause that much of a problem. I've seen springs with hoaky curls at the top and have them end up straight. I've only seen that when the spring perchs have alignment issues (control arms to short or long), Or the springs were loaded inplace. After the compression did you allow the springs to relax before you put them in place and set weight on them? I know the fronts were a bear to get around the bump stops.
post #18 of 35 Old 12-21-2009, 07:56 AM Thread Starter
I think the springs were unloaded, calling Currie soon. Thanks.
post #19 of 35 Old 12-27-2009, 10:33 AM Thread Starter
UPDATE
UPDATE
I spoke with a Currie rep on Monday 12-21-09, after the aborted Currie spring install the weekend before. He conferred with a Currie mechanic who told him that some bow was natural. When I mentioned to the Currie rep that the springs could not stand freely on their top or bottom when laid on level ground, he said that observation does not indicate that a spring is faulty.
I said I would try the install again.
So the plan was:
Remove: 3" coils (not bowing) and 1 & 3/4" coils spacers
Install: 4" Currie coils and 3/4" coil spacers.
So yesterday, I worked with someone else on the removal/install. He also has many years offroading and install experience.
We set CA's to the lengths Currie recommended. We did not use spring compressors and the springs were unloaded when installed. The springs were seated on the axles perches and frame mounts properly. They appeared straight when installed and the axle was at full droop. Once the install was complete we bolted everything back up, threw on the wheels, removed the jack. Centered the axles. Here are the results of another three hours work.
Again, the springs bow outward on either side.
So I ask you, is the amount of bow you see in these pics, a "natural" amount of bow? Is it proper for Currie springs to look like this?
I hope someone from Currie will chime in...I will be contacting them AGAIN, tomorrow.
post #20 of 35 Old 12-27-2009, 11:32 AM
bodyguy's Avatar
I say, absolutely not acceptable
bodyguy is offline
post #21 of 35 Old 12-27-2009, 11:48 AM
chromedome's Avatar
That is not right. You need a tech at Currie to see those pics! I'd call tomorrow and find out who you can emil them to while you keep them on the phone.
chromedome is offline
post #22 of 35 Old 12-27-2009, 12:19 PM Thread Starter
AGREED!
post #23 of 35 Old 12-27-2009, 12:49 PM
jerzeyjeep's Avatar
i have to say you have bad springs. the metal in the springs must be weak. i have installed many lifts and have never seen that. its as if the spring can not hold up the weght of the jeep.
just a thought you might want to pony up some coin for adjustable sway bar links. those rear links (you moved to the front) will limit your axle droop.
Lou
07 unlimited x, 4.5 lift with clayton arms poly springs
rock krawler frotn and rear trac bars and brackets
rock krawler high steer kit, jks quicker disco's
waiting on gobi rack
front axle about had it
jerzeyjeep is offline
post #24 of 35 Old 12-27-2009, 01:03 PM Thread Starter
Lou
Adjustable sway bar links on order...from Currie...hmmmm.
post #25 of 35 Old 12-27-2009, 01:16 PM
NxtGenCowboy's Avatar
Send a message via AIM to NxtGenCowboy
Send that picture to Currie... That is definitely not right!
The box said "Requires Windows 95, NT, or better", so I installed Linux
NxtGenCowboy is offline
