Strange smell after recovery - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 12-18-2009, 10:26 PM Thread Starter
MadMyk's Avatar
Driving home in the snow, I found a Nissan truck in a ditch, so I decided to help her out. I hooked up to her tow point and, while in 4 hi, attempted to pull her out. I stalled out (come to find she had it in park during my first attempt), and put it into 4 lo. Second attempt worked out, and I pulled her out no problem. After stalling out, I had a smell that gradually got weaker over the hour afterwards, but still stuck around. I have a manual and wasn't riding the clutch (to my recollection at least). Any ideas?
Just when they think they have all the answers, I go and change the question.
MadMyk is offline
post #2 of 9 Old 12-18-2009, 10:36 PM
paramaniac's Avatar
you sure you didnt shit yourself?
paramaniac is offline
post #3 of 9 Old 12-18-2009, 10:41 PM Thread Starter
MadMyk's Avatar
Wow, as usual, constructive input from the meat wagon tender.
MadMyk is offline
post #4 of 9 Old 12-18-2009, 10:47 PM
AnkurGT's Avatar
Send a message via AIM to AnkurGT Send a message via Yahoo to AnkurGT
Awesome...
The Ramblin' Rubinator:
2009 Stone White Rubicon Unlimited
Rugged Ridge XHD Front Bumper w/ MileMarker 9500SEC Winch - Rancho Rear Bumper/Carrier - Rancho 4" Sport Lift - 37x12.50x17 BFG KM2s on 17" M/T Sidebiters - AirRaid Cold Air Intake and Throttle Body Spacer - Rugged Ridge Side Armor and Euroguards - IPF XSD900 Lights - Rancho Crawler Cat-back Exhaust - Poly Performance Gussets and Sleeves - ARB Competition Diff Covers
AnkurGT is offline
post #5 of 9 Old 12-18-2009, 10:50 PM
JK Inferno's Avatar
It could just be the clutch, I ride it sometimes without realizing it. Last time I did it I was pulling a broken Chevy up a hill. My .02 unless you can identify where it was coming from
I understand the Jeep thing
JK Inferno is offline
post #6 of 9 Old 12-18-2009, 10:59 PM
HAHA x2
08 2dr X, Rock Krawler Arms and front truss, C Gussets, FT 3" Springs, JKS Trackbars & Discos, AEV Snorkel, Warn Front Bumper, Rancho Rear Bumper, 35" BFG KM2, Recon 10500 Winch, Synthetic Line, Coast Rear Shaft 1350, KC Slimlites, Cobra 75 CB
SEPA JK08 is offline
post #7 of 9 Old 12-18-2009, 11:03 PM
MaloCS's Avatar
The smell is probably from your clutch. I would check the clutch fluid and make sure it's in good shape. If it looks the least bit dirty or has an odd odor then change it ASAP. You probably burned the fluid while attempting the recovery while engaged in 4HI.
When performing a recovery you should always be in 4LO because the gearing is providing the maximum amount of torque the engine can produce to assist in the act. 4HI should only be used in low torque, high speed situations like driving on wet/snowy pavement and graded dirt roads. If you find yourself in a situation where high torque and low speed are the norm then 4LO is the gearing you should choose. An easy way to remember it is: Torque gets you started from a dead stop while horsepower keeps you going and allows for acceleration. 4HI is great for maximum traction at high horsepower but sucks at low end torque. 4LO is great for low end torque but sucks a high horsepower.
Check those fluids.
Those that the beast is looking for...
Listen in awe and you will hear him...
BARK AT THE MOON!
MaloCS is offline
post #8 of 9 Old 12-18-2009, 11:08 PM Thread Starter
MadMyk's Avatar
Cool Malo, thanks, I'll check it out. Nick, keep on being an oxygen thief.
MadMyk is offline
post #9 of 9 Old 12-18-2009, 11:15 PM
MaloCS's Avatar
To be safe you probably want to check the fluid in the transmission as well. Better safe then sorry.
Good luck.
BARK AT THE MOON!
MaloCS is offline
