White Smoke from Exahust, Please Help... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 42 Old 12-16-2009, 11:57 AM Thread Starter
Question White Smoke from Exahust, Please Help...
GRRRR
I think I had every possible problem with my JK but now is acting up again at the wrong time… “Am broke” Any way there is lots of white smoke coming out of the exhaust. About a month ago I went offroading and got stock for a long time deep in the muddy water. If this is related why would it go bad a month later? I have a few theories of what it could be but very unsure.
1. Something wrong with the gas mixture. (About 2 months ago I went Cat Less) Then again why act up two months later?
2. I ran low on oil this past week but right before it started smoking I did filled up with new oil.
3. Head Gasket blown. But there is no oil on the radiator or overheated.
4. God I need a Hemi
I do feel the engine is a bit weaker than normal but that just might be my imagination. Has anybody had the same problem? Please let me know. Any advices?
:b eer:
offroadpr is offline
post #2 of 42 Old 12-16-2009, 12:04 PM
TrailDuty.com
PhilD's Avatar
This sounds the most likely from what you've said.
Is there any water in the oil, usually milky brown.
How did you run low enough on oil to make it smoke? How much oil were you low, where did it smoke from, and where did the oil go?
PhilD is offline
post #3 of 42 Old 12-16-2009, 12:07 PM
CalmerThanYouAre
sin52's Avatar
GRRRR
:b eer:
Any backfiring when slowing down? No catalytic converter cut down on back pressure. could be a fuel/air ratio problem too. any pics would help. Also what does the smoke smell like?
I support the military, fiscal responsibility, Hemp, legalization of Marijuana over 21, smaller government and the Bill of Rights.
NSA: The only part of the government that actually listens.
sin52 is offline
post #4 of 42 Old 12-16-2009, 01:03 PM
riverzendz's Avatar
Does the white "smoke" give off a sweet smell? Coolant burning gives off a noticeable odor.
riverzendz is offline
post #5 of 42 Old 12-16-2009, 01:09 PM
owtdorz's Avatar
PCV valve?
'09 4dr Rubi Detonator Yellow
3.5 Mid arm Rock Krawler
Finally 5.13s
owtdorz is offline
post #6 of 42 Old 12-16-2009, 01:25 PM
TrailDuty.com
PhilD's Avatar
Originally Posted by owtdorz View Post
PCV valve?
If oil were somehow flowing back in to the intake through the PCV then it would be blue smoke.
White smoke is invariably water.
PhilD is offline
post #7 of 42 Old 12-16-2009, 05:49 PM
Send a message via AIM to RIPPMODS
GRRRR
:b eer:
This is a authorized supercharger dealer in PR, give them a call they know their stuff.
ESB PR Performance Corp (Jeep)
BO.SAN Anton RD 887km 2.5Q
Caralina PR 00987
787-752-2886
[email protected]
RIPPMODS is offline
post #8 of 42 Old 12-17-2009, 06:19 AM Thread Starter
When down to about 3qt. still unsure about what it is.. grrr
post #9 of 42 Old 12-17-2009, 06:21 AM Thread Starter
Some backfiring when slowing down yes, The smell is the typical exhaust smell but a bit stronger. If that is the problem, what can I do bro? The cats gone... Any temporary solutions until I get some $$$ ? Let me know man, Thanks!
post #10 of 42 Old 12-17-2009, 06:22 AM Thread Starter
True but that's not it I run on Pure water with water Weater..
post #11 of 42 Old 12-17-2009, 06:23 AM Thread Starter
PCV valve?
Could be... have to scan the damn thing...
A
post #12 of 42 Old 12-17-2009, 07:07 AM
TrailDuty.com
PhilD's Avatar
It's not unsual for mine to run through a quart or so every 3k miles, but 3 quarts is an awful lot to be losing. I changed the PCV valve on mine and it seemed to reduce oil usage for a short time, although it was still a pint low after 3k miles.
Oil burns blue, so your oil consumption is not directly related to the white smoke, although the issue causing one more be causing the other.
PhilD is offline
post #13 of 42 Old 12-17-2009, 07:13 AM
TrailDuty.com
PhilD's Avatar
That may not be such a great idea. I know you can run water and Water Wetter in race engines, but not so sure it is such a great idea for every day use, as the temp ranges will fluctuate much more.
Water Wetter is designed to get your engine to run cooler, so I'm presuming you had some issues with over heating to start with?
PhilD is offline
post #14 of 42 Old 12-17-2009, 07:47 AM
muddpuppy01's Avatar
My money is on a head gasket and hope you did not warp a head
muddpuppy01 is offline
post #15 of 42 Old 12-17-2009, 08:17 AM Thread Starter
I had issues with over heating but the problem turned out to be a Mudy Radiator, after going crazy trying to diagnose, The good people from JK Owners told me to look at the radiator a bit deeper so that was the problem. I did change the thermostat to 180. Here in Puerto Rico is always HOT so I wanted to lower the temps. Another thing is that it can get hotter when you are in the trails deep in the woods running at low speeds...
post #16 of 42 Old 12-17-2009, 08:18 AM Thread Starter
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO I dont want to be that. hahah So far the oil is clean and the radiator also...
post #17 of 42 Old 12-17-2009, 08:50 AM
TrailDuty.com
PhilD's Avatar
I can appreciate that, but it's not exactly cold here in the Summer and wheeling in 100+°F is not uncommon, and I never have overheating issues.
PhilD is offline
post #18 of 42 Old 12-17-2009, 08:51 AM
TrailDuty.com
PhilD's Avatar
White smoke means water, which invariably means head gasket. Run a compression test on the cylinders.
PhilD is offline
post #19 of 42 Old 12-17-2009, 08:56 AM
Timmy's Avatar
thats a head gasket[because you run pure water with water weeter.
that is not a good idea...coolent help lubricate and fight corosion. water weeter is not designed to be left in the engine for long periods of time. it is designed for race engines that get drained and rebuilt after every race. get a new motor cause you can get them cheaper than doing the head gasket, and put coolent in it.
Timmy is offline
post #20 of 42 Old 12-17-2009, 09:12 AM Thread Starter
Thanks all, but if it was a head gasket wouldn't I get water on my oil? or oil on my water? The water weeter claims to have a lubricant, Other than the lubricating purposes why use antifreeze on a place that never gets to freezing points?
post #21 of 42 Old 12-17-2009, 09:13 AM Thread Starter
Wait until your radiator gets totally filled with mud, am telling you the JK radiator is so thin I wouldn't use it on a 4 cylinder.
post #22 of 42 Old 12-17-2009, 09:30 AM
TrailDuty.com
PhilD's Avatar
You'll most probably find that antifreeze contains better rust prohibitors and lubricants than just water and Water Wetter.
PhilD is offline
post #23 of 42 Old 12-17-2009, 09:31 AM
TrailDuty.com
PhilD's Avatar
There's a reason I keep out of mud
PhilD is offline
post #24 of 42 Old 12-17-2009, 09:32 AM
TrailDuty.com
PhilD's Avatar
Not necessarily, if the gasket is just blown between the water jacket and cylinder, you'll just burn water.
Compression test.
PhilD is offline
post #25 of 42 Old 12-17-2009, 09:49 AM
CalmerThanYouAre
sin52's Avatar
Without a picture or smell-o-vision I can't say for sure. Do you have an aftermarket intake installed? If you do try disconnecting your battery and pump the brake pedal 3 or 4 times turn light column on off to discharge the computer. When you reconnect, take it out for a drive, accelerate pretty quick, a couple of times and drive at 45-65 for 10 mins. See if the computer can learn new Air/Fuel ratios with the less backpressure.
sin52 is offline
