SPEC clutch installed - JKowners.com : Jeep Wrangler JK Forum
post #1 of 17 Old 12-15-2009, 07:39 PM Thread Starter
el_campede's Avatar
To all,
After reading a few of the clutch problem threads and talking with SPEC and Hitmoney, I decided to get a 2+ clutch. It went in yesterday with my dealership. I took it in previously concerned about the various sounds from the TOB, and my dealership said they could replace it with the stock one. OR I could get a better clutch than the POS stock one (his words), and they would install it under the TSB.
What a difference. I'm still getting use to lightness of the clutch. I haven't stalled it yet (but I was close). I'll try to keep this updated as time goes by.
Thanks to JKO and SPEC for all the information and to Polyperformance for running the Black Friday sale.
2007 Wrangler 2dr X
el_campede is offline
post #2 of 17 Old 12-15-2009, 09:03 PM
Moose512's Avatar
[QUOTE=el_campede;292290]To all,
QUOTE]
What do you mean by "lightness of the clutch"? I have driven Hitmoney's rig a few times with the 3+ clutch and the biggest difference I find compared to the stock clutch is the lack of a transition between it being engaged. You are in gear or you are not and that line is very fine/takes a little getting used to be smooth.
Reminds me of a race clutch. It is only a matter of time before I will replace mine and I will probably go with SPEC but I am not sure what number to get. I do more daily driving with mine then Hitmoney does. I would not want the 3+ feel for a daily driver.
Moose512 is offline
post #3 of 17 Old 12-15-2009, 09:09 PM
SONIC's Avatar
Yeah, in my experience aftermarket clutches are stiffer than stock, and have a very fine engagement line (just like moose said)
hmm.....
-Doc Holiday
SONIC is offline
post #4 of 17 Old 12-16-2009, 04:34 AM
Administrator
HITMONEY's Avatar
hmm.....
What he means by a light feel is that it takes much less effort with the SPEC to depress the pedal.. the pressure plate of the SPEC is far more efficient than the stock one.
°lllll°
Facebook Page
YouTube Channel
HITMONEY is offline
post #5 of 17 Old 12-16-2009, 04:37 AM
Administrator
HITMONEY's Avatar
[QUOTE=Moose512;292383]
Originally Posted by el_campede View Post
To all,
QUOTE]
I really don't recommend the 3+ on a daily driver... but then again once you are use to it it it is fine... but it does take some time to "re-learn" how to drive your junk.
°lllll°
Facebook Page
YouTube Channel
HITMONEY is offline
post #6 of 17 Old 12-16-2009, 10:51 AM
.:eMETAL:.'s Avatar
when speaking with SPEC they recommended a 3+ to me even after we talked about daily driving. ??weird??
.:eMETAL:. is offline
post #7 of 17 Old 12-16-2009, 11:04 AM
riverzendz's Avatar
Is it that rough or is it a matter of how much you mind being abused while daily driving?
riverzendz is offline
post #8 of 17 Old 12-16-2009, 11:21 AM Thread Starter
el_campede's Avatar
HITMONEY is correct in that the clutch arm depress is lighter than the stock.
Moose512 is correct in that the engagement timing is more institaneous. I've been chirping my tires a bit more starting out.
As far as my considerations, I did not feel I needed the 3+ (as suggested by SPEC as well). I did not want their base, and I was waffleing between the 2 and 2+. I went with the hybrid 2+ to get goodness of both worlds. If it gets wet the semi metalic would still hold. The kevlar will be good for DD.
2007 Wrangler 2dr X
post #9 of 17 Old 12-16-2009, 12:08 PM
Moose512's Avatar
They probably saw the pics of you under water and spinning your 37" Mud Grapplers!! You probably should get the stronger 3+, especially if you are going to add weight to your rig in the way of armor and stuff.
Moose512 is offline
post #10 of 17 Old 12-16-2009, 12:19 PM
.:eMETAL:.'s Avatar
LOL! true on the weight thing.
post #11 of 17 Old 12-17-2009, 06:26 AM
I have Center Force and is way lighter than stock... Light is good...
offroadpr is offline
post #12 of 17 Old 12-18-2009, 05:08 AM Thread Starter
el_campede's Avatar
First couple of days impression: I LIKE IT!
Very tame around town. Love the easy clutch movement at lights. I have one of those funny little hill starts (about a long as the Unlimited) that lips up at the top. From a dead stop, it popped right off without delay (the stock clutch would slip a little).
Took my freeway route in this morning. Had a big rig want my lane, so I backed off. When he went back, a quick down shift into 3rd and I was off. Nice quick engagement and no loss due to high speed slippage.
Did I say I like this SPEC clutch?
2007 Wrangler 2dr X
post #13 of 17 Old 02-18-2010, 11:28 PM
Guys
I have Spec stage 3+ same as HITMONEY. Everything was installed properly by the dealer fly wheel was surfaced etc
After few thousand miles and mud driving i have this squeeking sound come back again when depressing or pumping the clutch pedal
What is going on.
JK07 is offline
post #14 of 17 Old 02-19-2010, 07:56 AM
Administrator
HITMONEY's Avatar
Originally Posted by JK07 View Post
Guys
What is going on.
Mine doesn't make a squeak of any kind..
When you press on the clutch pedal you are hydraulically moving a fork which inturn engages the throw out bearing.
Is the noise only when you depress? how about when you let the pedal up?
°lllll°
Facebook Page
YouTube Channel
HITMONEY is offline
post #15 of 17 Old 02-19-2010, 05:23 PM
The squeeking is coming both ways when I am pressing the pedal or releasing it.
Especiall when its hot it makes quite a lot of noise.
JK07 is offline
post #16 of 17 Old 02-19-2010, 05:41 PM
Administrator
HITMONEY's Avatar
Only things I can think it could be..
1. Clutch Pedal assembly (especially if you are hearing the noise inside the cap more than out.)
2. The clutch fork (the lever that actually moves the TO bearing)
3. The throw out bearing itself or its movement on the front bearing collar.
°lllll°
Facebook Page
YouTube Channel
HITMONEY is offline
post #17 of 17 Old 02-19-2010, 09:29 PM
sounds like TO bearing. So the issue of clutch squeeking remains the same with OEM or Spec etc Bec Spec did provide a TO bearing and if it is tossed than there is no difference between them
JK07 is offline
