Air tank location/install - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 12-14-2013, 11:45 AM Thread Starter
rbuckenmeyer's Avatar
Doing a bit of research on air tank location and/or installation. The information and pics of current setups seems to be fairly scattered throughout threads.
Post up your install. Right now I'm leaning towards the Viair 2 or 2.5 gallon tank and mounting my compressor somewhere in the back or under the drivers seat, but I'll be putting it in some type of enclosure b/c I don't want the interior noise when I flip that baby on.
Let's see 'em...
So I guess you're calling him a dick for pointing out something dangerous, which kinda makes you a dick for calling him out and well holy fuck, it makes me a dick for calling you a dick.
rbuckenmeyer is offline
post #2 of 11 Old 12-14-2013, 12:42 PM
Mine is where the stock muffler was. But if i was going to do it again i would run without a tank. It is only useful for the 1st tire.
post #3 of 11 Old 12-14-2013, 01:21 PM
Tight_wad's Avatar
^^ What he says is right, and mine is in same location. You would be better served buying a compressor with the highest cfm that you can afford.
Tight_wad is offline
post #4 of 11 Old 12-14-2013, 03:12 PM
Reapercrew's Avatar
Reapercrew is offline
post #5 of 11 Old 12-14-2013, 04:52 PM
CashMoney's Avatar
I've got the tuffy rear security hatch kit thing in the back of my unlimited and mounted a 2.5-3 gallon one to the right inside wall.
CashMoney is offline
post #6 of 11 Old 12-14-2013, 05:25 PM
I mounted a 1 gallon tank to the crossmember below the radiator. You can see it in the lower part of this picture.
Name:  ImageUploadedByAG Free1387067113.654382.jpg
holaCG is offline
post #7 of 11 Old 12-14-2013, 07:16 PM
jeeperjkj's Avatar
Good info there.
FWIW, I've got the RROR evap/air tank skid with a 2gal tank in it. For compressors, I've got two ViAir 400c compressors mounted to the bottom of the tub over the rear axle.
jeeperjkj is offline
post #8 of 11 Old 12-15-2013, 12:37 PM
HAFICON's Avatar
Im not really crazy about my location however it has been in for 6ish months maybe more and have not had an issue with space. It is rather entertaining when the relief valve pops off and scares the heck out of my passenger's.
My Viair 450c compressor, Brake booster mounted.
The air distribution block.
I have changed thins on the block since this photo, going to a digital gauge that is operated by sensor over air line.
Twin 2.5 gallon tanks.
HAFICON is offline
post #9 of 11 Old 12-16-2013, 08:22 AM
ALASHA's Avatar
Got mine mounted in the stock muffler location:
Full thread here:
https://www.jkowners.com/forum/showthread.php?t=84518
ALASHA is offline
post #10 of 11 Old 12-16-2013, 08:23 AM
ALASHA's Avatar
I disagree. My York can just about top off the tank while I put the cap back on the finished tire, move over to the next and unscrew the cap.
ALASHA is offline
post #11 of 11 Old 12-18-2013, 12:38 PM
Tank
Running the VIAR constant duty and a 2 gallon tank. The 2 gallon tanks fit nicely behind the radiator. I used Poly's cross member mount for the tank and their compressor mount that bolts up to the master cylinder. Ran air coupler to a hole in the frame, behind front bumper.
My system is kinda slow. Have been considering adding another compressor. But may just go power tank.
GARUBICON is offline
