Building on jk frame. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 12-13-2013, 04:57 PM Thread Starter
halo216's Avatar
Knowing I wanted to do an ls swap ive been researching what to buy and do in the process. Would it make sense to pick up a jk frame and perform the swap on there? Also can perform axle swap and lift at same time. Not sure how much more work it might cause doing it this way.
halo216 is offline
post #2 of 5 Old 12-13-2013, 05:02 PM
10jk's Avatar
Follow his channel
http://www.youtube.com/user/protecoffroad/videos
JK LS Swap Body Removal - YouTube
2010 JKUR, 4" Pro C., 3/4" f Daystar spacer, 5.38's, EVO sleeve/gusset/custom trussed, Rear Ten Factory axle shafts, 1.5" wheel spacers, Pro C. 17 x 9 wheels, 38 x 14.50 x 17 MTR's, SuperChip FP, no fenders, B&M Tranny cooler, Magnaflow, Fr./ Rr. frame hacked off, HD Balls
29,000 miles as of 12/13/14
10jk is offline
post #3 of 5 Old 12-13-2013, 06:32 PM
Sgo70's Avatar
I did a lot of extra while doing the LS swap, lockers, gearing, driveshafts, suspension etc and it does make sense since you have it all apart and will be waiting on parts from time to time but it also makes it ten times harder during final shakedown.
I had AFM vibrations, driveline vibrations, exhaust drone and it made it hard to pinpoint stuff. I did get it all figured out but probably a little harder in the long run. I'd probably do it the same way though.
Sean
Sgo70 is offline
post #4 of 5 Old 12-13-2013, 07:34 PM Thread Starter
halo216's Avatar
Yeah i know most swaps pull the body off. Thats why I was thinking of buying a frame and getting a head start. Then when im ready I will have another vehicle to drive
halo216 is offline
post #5 of 5 Old 12-14-2013, 07:19 AM
jss
jss's Avatar
LS/HEMI in a JK
On our swaps we do not need to pull the body off, but you will need to drop the gas tank to plug in the fuel pump.
["jeep speed shop The GuineaPig Build"]
VVT Truck Hemi Conversions
The ONLY CARB LEGAL JEEP ENGINE CONVERSION
7911 Redwood Dr, Cotati, Ca. 94931
707-338-3154
jss is offline
