drive shaft question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 17 Old 12-09-2013, 09:59 AM Thread Starter
Hey all, ordered the RK 2.5 stock mod kit the other day, installing it over the weekend.
I know a lot of people say that they end up getting a good deal more lift than 2.5 in the front. Do you all think I'll have any problems with the stock drive shaft? I don't plan on doing any offroading for at least another season or two, waiting on the stock rubber to wear out before I put better tires on.
cody8417 is offline
post #2 of 17 Old 12-09-2013, 10:24 AM
iwaxmyjimmy's Avatar
My driveshaft will touch my crossover pipe when flexed out but as far as the joints go. I've had my lift on for about 9 months and no cracks in the boots or vibration issues. I wheel mine pretty hard with the stock rubi tires.
Sent from AutoGuide.com App
iwaxmyjimmy is offline
post #3 of 17 Old 12-09-2013, 10:34 AM
If you are not wheeling you should be fine with the stock drive shaft. You could also add a limiting strap at the differential to keep the driveshaft from making contact with the exhaust.
post #4 of 17 Old 12-09-2013, 05:53 PM
floridajpr's Avatar
It really varies from Jeep to Jeep. I have a JKU with a RK 2.5" Max Travel Pro lift and my front stock driveshaft has vibration between 55-68 MPH. My mechanic tried to adjust the camber from 6 to 5 degrees to fix it but it's still there. I am now saving up for aftermarket driveshaft's. Some Jeep's never have a problem and some Jeep's do. It's just a roll of the dice. I hope you have no problem's with yours.
floridajpr is offline
post #5 of 17 Old 12-09-2013, 05:54 PM
..Still stock driveshafts here, 72k miles and pretty good amount of flex. I did repack the grease in them however.
post #6 of 17 Old 12-09-2013, 05:56 PM
He should be setting your Jeep's Caster to whatever the pinion angle will allow for. With the CV joint in the stock driveshaft, vibes aren't very common...
post #7 of 17 Old 12-09-2013, 05:57 PM
JKO Dickhead
Asmmns's Avatar
Not sure what year. But running the RK 2.5 on my JKU. I did have an issue with the clamp on the boot hitting the trans pan with the stock driveshaft.
Swapped it out with a coast and clears the trans but will still rest on the skid at pull droop.. But I had no vibration or join issues with the stock one after a few years
__________________
CURE SMA !
Asmmns is offline
post #8 of 17 Old 12-09-2013, 06:38 PM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
You'll be fine with the stock shafts. I've run stock shafts on an 08, 12 2 door, and 12 4 door with the stock shafts in tact. All on RK 2.5 and 3.5" systems.
Marcus
RiverCityOffroad is offline
post #9 of 17 Old 12-09-2013, 08:05 PM
kjeeper10's Avatar
Front shaft started spitting grease soon after installing my RK 2.5's. Replaced with a Adams shaft.
Rear is still holding strong at 10k. I picked one up from this forum for a spare.
kjeeper10 is offline
post #10 of 17 Old 12-11-2013, 03:46 PM
51%
I'm running the stock shaft with 4-1/2" lift (over 5 inches actual measurement). So far so good and I have tested it to full droop and the CV still has a couple of inches more drop left beyond what the shocks will extend to. You might have an exhaust clearance issue, but at 2-1/2 not likely. If you do, you can gain a little clearance with spacers, or get the aFe cross over pipe that eliminates the problem entirely. I'm running 2-1/2 degrees of caster and 3-1/2 degrees up angle on the pinion with no vibes. So with your lift I don't think you have any driveshaft worries.
14 JKU 4-1/2 AEV Dualsport RS, 37" KM2 on Pintlers, PR44, 4.88, ARBs .... under construction
51% is offline
post #11 of 17 Old 12-11-2013, 05:08 PM
kjeeper10's Avatar
I tried the 3* caster and my 2 door was too sloppy.
I don't know if a 4 door will be different.
All I know is it did not work for me.
post #12 of 17 Old 12-11-2013, 05:09 PM
floridajpr's Avatar
Mechanic had the driveshaft set to what the pinion angle would allow for and it had the vibration, he changed it from 6 deg to 5 deg to see if it would help but it didn't. He said 6 deg is the norm for the RK 2.5 lift. It drove like stock at 6 degree castor but would slightly vibrate around 50-65 MPH. When he changed it to 5 degree castor, it's a little squirrely and I still get the vibration around 55-68 MPH. I am just going to get a new driveshaft's when funds allow. Like I said before some Jeep's have no problem's with vibrations and others will.
post #13 of 17 Old 12-11-2013, 05:11 PM
floridajpr's Avatar
Marcus
2007-2011 are completely different than 2012-up.
post #14 of 17 Old 12-11-2013, 05:15 PM
The length is a bit different and the exhaust routes a little differently around them, but they are the same idea.
What were you told makes them so different?
Marcus
post #15 of 17 Old 12-11-2013, 05:19 PM Thread Starter
I did pick up a set of exhaust spacers to install while the lift is going in. Hoping things work ok. I have a jcr dagger up front which should help keep it a little lower. Depending on how it rides I can throw the lca's in down the road but hoping is not necessary along with the drive shaft
cody8417 is offline
post #16 of 17 Old 12-11-2013, 07:18 PM
kjeeper10's Avatar
Squirrelly at 5* ?
RK actually recommends 4.5*, most 2 door guys have to run less. If you are still getting vibes I'm guessing something else is wrong. From what I see on the forums, the stock shafts won't vibrate unless missing a weight or damaged.
post #17 of 17 Old 12-12-2013, 07:56 AM
tribal636's Avatar
I have the stock shafts on my '13 Rubicon with a RK 2.5 X factor on 37's and I have no issues at all. At full flex the shaft is still 1-2" away from the crossover pipe (I have the Teraflex exhaust spacers) and the joint doesn't look bound up at all. I get a decent amount of travel out of my lift too. I have right at 2k miles on the lift with some light-moderate wheeling.
tribal636 is offline
