Atlas gear whine w/ 6 speed - JKowners.com : Jeep Wrangler JK Forum
post #1 of 15 Old 12-07-2013, 05:41 PM Thread Starter
Red Rock's Avatar
I just put an Atlas 4.3:1 2 speed in my manual trans 2008. I am curious as to how much gear whine is normal. It gets louder when I'm not on the gas - no rattle, I can just hear the gear noise. I've checked and recheck the fluid level - it's been consistent since I put it in. I've been driving it daily (30 miles back and forth to work) for about 10 days now.
Thanks for any input.
JD
Originally Posted by guinness View Post
So someone thinks RDY4RKS' 6.1 hemi, solid axle, arb'd, atlas'd, long arm'd, 42'd jeep is cookie cutter? Fuck it. Im going outside and burning mine to dust. There is no hope.
Red Rock is offline
post #2 of 15 Old 12-07-2013, 06:03 PM
bluewave's Avatar
That's a lot of gear reduction I think you are okay if it's not making other noises
Texas Complete Truck Center
5670 S Interstate 35
New Braunfels, Texas
(210) 412-6379
bluewave is offline
post #3 of 15 Old 12-07-2013, 06:23 PM
Will Scarlet's Avatar
Have you contacted Advance Adaptes and asked them?
2011 Sahara Tan Rubicon 6 Speed
TR HD17 Beadlocks, BFGoodrich A/T KO2 34x10.50R17, Teraflex HD Tire Carrier, Clayton 2.5" Overland Plus Lift, and more to come...
Will Scarlet is offline
post #4 of 15 Old 12-07-2013, 06:44 PM
The Atlas in my TJ whined quite a bit. It did nothing else, so I considered it normal.
96zjlimited is offline
post #5 of 15 Old 12-08-2013, 10:53 AM
It is very noticeable if you don't lock out your front axle. I always can tell if my front is locked or not by the sound.
post #6 of 15 Old 12-08-2013, 11:46 AM
PIG
PIG's Avatar
JD
You'll get used to it... Remember, you are going from a chain driven t-case to a gear driven one.
PIG is offline
post #7 of 15 Old 12-08-2013, 04:08 PM Thread Starter
Red Rock's Avatar
Thanks for the replies guys! I figured it was normal - I've been in another JK with an Atlas, but it's an auto trans. I could hear it in that one also, but it's been a while since I drove it, so I can't remember exactly how loud it was. Mine's not screaming like something is busted or anything.
Red Rock is offline
post #8 of 15 Old 12-08-2013, 05:16 PM
SoK66's Avatar
I had one in my old YJ. It did make some gear whine, but it made so many other mechanical noises it was just part of the symphony.
It was an early one that had a bit of gear clatter as well, was never worth trying to repair.
SoK66 is offline
post #9 of 15 Old 12-08-2013, 07:02 PM
i'd understand it being normal when he's in anything other than 2w hi. but should it whine in 2hi? are the high gears straight cut?
MISHIMOTO IS JUNK
chknkatsu is offline
post #10 of 15 Old 12-08-2013, 07:04 PM
If the front ds is turning it makes noise.
post #11 of 15 Old 12-08-2013, 07:08 PM
Yes, an Atlas will always make more noise. A chain is quiet, gears are noisy but strong. Even in 2wd, the front is spinning, and it is gear on gear no matter what.
Ryan
post #12 of 15 Old 12-08-2013, 08:43 PM
i understand the front ds is always spinning since we dont have lockout hubs, but from what i understand on the Atlas, if you're in 2wd. the front output is spinning on the shaft only and there is no gear freespinning on the front output. if you look at videos of an open atlas2 you will notice that. more noise with the gear driven tcase i understand, but shouldnt really be affected by the front ds
MISHIMOTO IS JUNK
post #13 of 15 Old 12-08-2013, 08:49 PM
So are you saying that they don't make noise when in 2wd?
post #14 of 15 Old 12-08-2013, 09:14 PM
not saying they dont or do since i don't own one. but looking at the way it's built and operated the front driveshaft turning in theory shouldnt cause more noise
MISHIMOTO IS JUNK
post #15 of 15 Old 12-08-2013, 09:32 PM
Not sure what your theory is based on but in reality they make noise when the driveshaft is turning. It is quite a bit more quiet with the front ds disconnected.
