Does anybody make a plug-in for the rubi locker - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 12-05-2013, 09:03 PM Thread Starter
I'm doing a rubi axle swap and I wonder if anybody makes the plug-in on the diff looking for a quick connect other than the factory harness.
Can a guy just get a matching plug?
rattler_thesnake is offline
post #2 of 10 Old 12-05-2013, 09:19 PM
bnb2010's Avatar
Try this
https://www.jkowners.com/forum/showthread.php?t=9491
Search is your friend, introduce yourself sometime to it
bnb2010 is offline
post #3 of 10 Old 12-05-2013, 10:28 PM Thread Starter
Originally Posted by bnb2010 View Post
Try this
I've tried search... Only thing I have found was the entire harness not just the pig tails or clips. I will check the link. Thanks.
post #4 of 10 Old 12-05-2013, 11:23 PM
jrider's Avatar
I know that somebody in the last couple weeks posted that they had found the connectors aftermarket somewhere. I'll see if I can remember enough about the post to help find it.
2007 Rubi Unlimited. Teraflex 2.5 lift + Fox shocks, Nitto Trail Grappler 35s on XD Addicts, 5.38s, Ten Factory rear shafts, Riddler diff covers, Purejeep front axle truss and Teraflex gussets, Tatton front driveline, Rugged Ridge Modular front bumper with XRC8 Comp winch, Superchips programmer, Volant intake, MBRP exhaust, Hella H4 headlight conversion, Body Armor "not so Extreme" Rock Rails, in-cab winch control,Best Top Trek Top.-Sold
jrider is offline
post #5 of 10 Old 12-06-2013, 04:53 AM
Fklein6768's Avatar
There is a "repair" clip on ebay.
www.4x4s-pod.com
Fklein6768 is offline
post #6 of 10 Old 12-06-2013, 09:01 AM Thread Starter
post #7 of 10 Old 12-06-2013, 09:38 AM
BADDANDY's Avatar
I just did this install, you'll need to buy the Mopar harness and strip it down to the parts you'll need. The good think about it is you'll get extra wire and sheathing to run the wiring anyway you want.
BADDANDY is offline
post #8 of 10 Old 12-06-2013, 11:08 AM
You should be able to get the plugs at summit racing. Not sure on the part number but they have all kinds of oem plugs you can get.
All you need is 12v+- wires to the axles. You will not get the dash lights to work and there is no reason to buy the rest of the wire harness unless you are planning on adding the sway bar disconnect.
post #9 of 10 Old 12-26-2013, 03:13 PM
Rexacon's Avatar
Just did this in a jeep. It's takes about 5 hrs. Label ur wires. Yellow red r positive. Purple blue ground and black is ground.
07 JKU rubicon Built, Turbo , 14"king coil overs ect
Rexacon is offline
post #10 of 10 Old 12-26-2013, 08:07 PM
BADDANDY's Avatar
If anyone needs a harness, I have an extra still in the package for $95 shipped. A Chrysler vendor website will complete an order without your knowledge and will not return phone calls nor e-mails. I offer it here before filing my fraudulent claim.
The harness sure makes the wire-up easier even though it took 4 hours just rebuilding a new 4 plug one, but it sure looks professional. If you wire up all 4 plugs, you'll wind up using almost 50% of the wiring and all of the conduit which will save money over buying that stuff seperate.
Another tip, use all the yellow/red plug wire and label it before installing it. I didn't worry about the purple blue ground and black wires relation to which plug as they're grounds which no relation to my switch/indicator circuits.
BADDANDY is offline
