front end noise - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 12-04-2013, 03:26 PM Thread Starter
knyland's Avatar
front end noise
Alright, I have a semi metallic noise coming from the front end while driving on level ground under normal driving conditions. Almost a thumping makes a similar noise as to when I had horribly cupped tires. While accelerating it does not do it. I have replaced the unibearings, brand new tires, alignment done, and I removed the frond DS to make sure it wasn't that. The U-joints on the shafts look to be intact. Going to pull diff cover this Saturday and check pinion and gear set. BTW this is on a 08 rubi with a 3 1/2 rock krawler X factor lift with coilovers in the front.
Any ideas before I pull out what hair I have left?
This is one reason I have a strict policy of not eating anything out of another dudes butt. Flick it with my tongue? Sure. Run my tongue around the rim? Depends. Dart my tongue in for a brief second? Maybe. Eat something out of it? No fuckin' way!
If you want to know whats on it check my
knyland is offline
post #2 of 2 Old 12-05-2013, 03:42 PM Thread Starter
knyland's Avatar
figured it out today. rear end is shot. Ring is missing atleast 6 teeth cant see the pinion but sure its all fucked up too.
knyland is offline
