Loud chatter in Left Front in 4WD - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 11-28-2013, 05:35 PM Thread Starter
Converted's Avatar
Just went out to pull a friend out of a little mud hole. I had good footing so I tried first in 2WD. Couldn't get him out so I moved it to 4LO and pulled him out.
When I was pulling in 4LO I heard a very loud chatter that sounded like it was coming from the left front. When I moved it back to 2WD the chatter goes away..... mostly. When driving down the road you can hear a faint chatter like noise if you listen for it.
Axel U-joint has no noticeable play or movement.
Any ideas?
2009 JKU on a 4" Rancho Sport lift with 35" KM2 on stock 3.73 gears Dana 30 front
'09 JK Unlimited X. Yellar. Hard Top, S-Package Factory rear locker and front sway bar disconnect. 3.73's which will have to go someday. 4" rancho lift with 35" BFG KM2's, AEV Snorkle, FlashPak
Converted is offline
post #2 of 5 Old 11-28-2013, 07:01 PM
kjeeper10's Avatar
Drive shaft joints ?
Sent from AutoGuide.com App
kjeeper10 is offline
post #3 of 5 Old 11-29-2013, 03:50 PM Thread Starter
Converted's Avatar
Driveshaft U-joints don't have any play.
I'll pull the front differential plug and check the oil.
post #4 of 5 Old 11-29-2013, 04:50 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
I get a sound similar to yours under heavy load on incline. Only happens in 4wd lo. If I feather the throttle it goes away temporarily and comes back. Went through all of the checks and couldn't find anything to suggest a cause. To me it sounds like marbles in a coffee can.
2011 JK with 32's, 3.73's and an auto. Only 17K miles and light wheeling so far with someone very easy on the skinny pedal.
I have been kind of thinking my noise might be pinging because i've mostly encountered it during hill climbs at altitude above 5000 feet.
JKCTAZ is offline
post #5 of 5 Old 11-29-2013, 05:11 PM
kjeeper10's Avatar
Mine pinged like crazy. Only when cold now. Seems to quite with shell gas and a bottle of Techron every once in a while.
I read it again. Check the exhaust cross over pipe. The heat shield can pop its weld joints and chatter around.
