Tie rod end question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 15 Old 11-28-2013, 05:27 PM Thread Starter
so_calif_rubi's Avatar
I've been looking around for a new tie rod set up, but most of the aftermarket one's say you need 17" wheels with 4.5" back spacing, but i have 16" with 4.5" b/s, so has anyone out there with 16's wheel's get any of the after market tie rod kits to work?
~Richard & The Goddess~
_______________________________________________
Current Mods: 2.5 BB Teraflex Lift, 35" Nittos, 16"X8" MB Wheels, On-Board Air, Flo Master Exhaust, Power Inverter (800w), Evap Canister Relocation, WOODS S. S. relocation bracket, WOODS Rear Axle, Mopar Hitch, CB, Happy Bunny mud flaps!
so_calif_rubi is offline
post #2 of 15 Old 11-28-2013, 05:58 PM
I have the same issue and maybe even worse with my 15" wheels. I think from all my research the best option is Poly Performance:
http://www.polyperformance.com/shop/...d-p-16403.html
This is where I'm going soon. There are other tie rods but it's the clearance issue you are trying to address and get something better than the stock crap. Also, this price includes the ends. :-)
4x4x4 is offline
post #3 of 15 Old 11-28-2013, 06:00 PM
iwaxmyjimmy's Avatar
I've been looking at the WFO or Ruffstuff tie rods. I feel like with a 1" wheel spacer on a 3.75" back spacing 15 it should work maybe even just a 3/4" spacer. Just haven't tried it yet. Will probably be after the first of the year.
iwaxmyjimmy is offline
post #4 of 15 Old 11-28-2013, 06:36 PM
jeeperjkjeeper's Avatar
the safe minimum is a 1.25" wheel adaptor......a narrow spacer is a no no
jeeperjkjeeper is offline
post #5 of 15 Old 11-28-2013, 06:59 PM
kjeeper10's Avatar
I run synergy with 16's
Sent from AutoGuide.com App
kjeeper10 is offline
post #6 of 15 Old 11-28-2013, 07:11 PM Thread Starter
Kjeeper10 do you know the back spacing on your wheels?
post #7 of 15 Old 11-28-2013, 08:00 PM
Why is a narrow spacer a no no? Just curious because that's actual less stress on the studs, and easier on other hub end parts? Now attaching to the hub is a little tricky but possible. Haven't seen anything that size yet
post #8 of 15 Old 11-28-2013, 08:21 PM
3/4"-1" adapters would require cutting the factory studs substantially and simply using a spacer would shorten the usable thread for the lug nuts
post #9 of 15 Old 11-28-2013, 08:29 PM
True, the only exception would be if the wheel has a recess [and enough recess] in the back between the studs; which a steelie won't of course.
But in general, a company won't even make them less than an inch with their own studs [like they should have]. So it's sort of a moot point.
post #10 of 15 Old 11-29-2013, 08:14 AM
kjeeper10's Avatar
3.75
I posted when I had my 15" Black Rock Vipers. These joints would not work.
Others were chiming in with no problems. a Moog joint like what RK is using currently works fine even though 17" is supposedly the minimum. So I don't think back space matters with 16's. They should all work.
Fwiw. RK is about to release a new tie rod with their own ends and adjustable on the jeep.
post #11 of 15 Old 11-29-2013, 08:23 PM Thread Starter
thank you guys very helpful!!!!!
post #12 of 15 Old 12-03-2013, 02:16 AM
Originally Posted by kjeeper10 View Post
3.75
This is great news for me!!!!! I was going to order the RK tie rod with the drag link rod ends which are stronger, but now I will wait just a little longer. I really need to look at getting bigger wheels to help with my clearance issues.
Bigger wheels: Dilemma
I could get bigger brake rotors
I would not have issues for the tie rod clearance
More choices for tires on say 17" wheels as opposed to my 15"
Downside the tires do cost more and I would need 5 new wheels and tires to add cost.
Last set of 35's cost only $190 ea - they are $241 in 15" (That price break is hard to get past for me)
Same tire in 35x12.5x17" is $349 ea or $432 dollars more for just 4 of the same height tire plus $349 for the spare tire =$781. Then add 5 wheels to the equation and you see why going from 15" to 17" is big bucks for the very same 35" tall tire.
I started on the cheap and now it will cost a lot to go up to a wheel size that makes sense functionally.
To make matters worse I really need 37's to clear my long wheel base...
4x4x4 is offline
post #13 of 15 Old 12-03-2013, 07:25 PM
Why gain only 1" buy going up to 37s or just relocate your fuel tank and gain 2.5+" for a lot cheaper than 37s
post #14 of 15 Old 12-03-2013, 07:30 PM
i run 15" with a poly performance tirerod. i think my BS is 3.75 or 4" i need to double check
MISHIMOTO IS JUNK
chknkatsu is offline
post #15 of 15 Old 12-03-2013, 07:32 PM
JKO Dickhead
Asmmns's Avatar
I run the rock krawler HD Aluminum tie rod, with Moog ends with 15's
It wil depend on your back spacing, but this setup fits fine
__________________
CURE SMA !
Asmmns is offline
