Teraflex JK D44 - JKowners.com : Jeep Wrangler JK Forum
post #1 of 32 Old 11-23-2013, 01:36 PM Thread Starter
SoK66's Avatar
Teraflex JK D44
Anyone out there running TF's D44 housing in front? Wondering how they're holding up so far.
SoK66 is offline
post #2 of 32 Old 11-23-2013, 02:46 PM
JK Timmay's Avatar
Got one and after about 10 months, it's held up great!
JK Timmay is offline
post #3 of 32 Old 11-24-2013, 07:02 PM Thread Starter
SoK66's Avatar
How did the install go?
SoK66 is offline
post #4 of 32 Old 11-24-2013, 07:12 PM
Thisguyhasadd42's Avatar
I have one, havent had any problems with it. Although i havent wheeled with it yet, i can say that it is beefy. A shop installed mine because it was already there for other reasons. But I dont see installing it be difficult at all.
2010 Mango 2dr 6spd Rubicon
Thisguyhasadd42 is offline
post #5 of 32 Old 11-24-2013, 07:21 PM
JK Timmay's Avatar
Install was a piece of cake. I didn't have any issues.
Tim
post #6 of 32 Old 11-25-2013, 07:03 AM
Abadjeeper's Avatar
I've built a few now for guys and they are very nice housings and they are holding up great.
Abadjeeper is offline
post #7 of 32 Old 11-27-2013, 09:01 AM Thread Starter
SoK66's Avatar
I see Northridge has a 15% of deal going....May be time to pull the string!
SoK66 is offline
post #8 of 32 Old 11-27-2013, 09:14 AM
bgall's Avatar
One person in our group running one with 37s. No issues to far. 4 months on it, as I recall.
I have jeeps. I do shit to them.
bgall is offline
post #9 of 32 Old 11-27-2013, 09:30 PM Thread Starter
SoK66's Avatar
Ordered.
SoK66 is offline
post #10 of 32 Old 11-27-2013, 10:05 PM
I would not waste the money on it or the pro rock 44.
thedirtman is online now
post #11 of 32 Old 11-27-2013, 10:37 PM
V8 dreams
jvandy50's Avatar
That 15% off deal is tempting.
2010 Silver JKU
jvandy50 is offline
post #12 of 32 Old 11-28-2013, 08:25 AM
DynoGuy's Avatar
Any reason why?
RK 2.5MT w/ Fox remotes. Front Rubicon axle with Terraflex sleeves & upper C gussets & self made axle truss & skids. Rear Rubicon axles with self made skids. Stock 4:10 gears. 37x12.5x17 Nitto Trail Grapple on stock painted wheels. XRC8000Comp winch on stock stubby bumper. Smitty overhead console. Uniden CB w/ 105" whip. DiabloSport Trinity.
ΜΟΛΩΝ ΛΑΒΕ!
DynoGuy is offline
post #13 of 32 Old 11-28-2013, 09:12 AM
Because they use the same shitty unit bearing hubs as the factory axle. Most people don't think about getting them in an added width s you can run bigger wider tires without spacers. At minimum if running 37x12.5" tires you should be looking at a 68.5" wms axle with a 4.5" bs wheel. Factory width axles with a 3" bs wheel. A stronger lock out hub will also allow you to disconnect the front driveline for better fuel economy and would allow you to drive should something break up front. You can add the spyntec hubs to the pro rock or the rubicon axle but once you add that to a completely built pro rock 44 you will be at what a d60 will cost.
At minimum I would look at the hybrid 44/60 if I were going to do a 44 up front.
post #14 of 32 Old 11-28-2013, 09:15 AM
x2 on those reasons, I'd really like a Hybrid under the front of mine. I really would like a wider axle up there more than anything else. Lockouts are just icing on the cake.
post #15 of 32 Old 11-28-2013, 10:25 AM Thread Starter
SoK66's Avatar
I'm staying with D44 because I want to keep weight down. I have Spyntecs so I have the manual hub issue covered. I'm sure they're not as robust as Dynatracs 60 stuff, but they do ditch the unit bearings. The Spyntecs required chromolys and CTMs, so we're in good shape for the time being axle shaft & u-joint wise. If this works I'll swap in slugs in place of the Warn hubs for serious trails. First step will be to swap everything (diff assy, shafts, Reids, Spyntecs) over to the new housing and dial in the caster/pinion angle. Phase two will be as needed, RCVs and if the stock locker takes a dump, starting the swapover to ARBs.
SoK66 is offline
post #16 of 32 Old 11-28-2013, 11:00 AM
e-jeep's Avatar
Feedback: 12 reviews
I like mine. I went with the R44 housing. The install was about 15 hours, but it was very straight forward. I did everything except the gears, which I had a guy at Adrenaline Offroad do. I agree with what dirtman and goody are saying, but if you can get a good price you can't beat it for an overall stronger housing.
My Build Thread ~
NE Trail Ride Thread ~
Adrenaline Offroad
e-jeep is offline
post #17 of 32 Old 11-28-2013, 03:52 PM
kjeeper10's Avatar
And caster
Sent from AutoGuide.com App
kjeeper10 is offline
post #18 of 32 Old 11-28-2013, 05:41 PM
e-jeep's Avatar
Originally Posted by kjeeper10 View Post
And caster
3 degrees w/no drive line vibes.
My Build Thread ~
Adrenaline Offroad
e-jeep is offline
post #19 of 32 Old 11-30-2013, 04:30 PM
Impulse Off Road's Avatar
I have run a TeraFlex HD44 in my JK throughout this year. I have the standard .250 wall 3.25" diameter housing. My axle is 3.5" wider per side for a total width increase of 7" I raced the KOH EMC Challenge, full week of beating it up in Moab for Easter Jeep Safari, and raced a full season of Lucas Regional Short Course. I have swapped the ring and pinion 3 times trying to find the best gear ratio for me. My housing is still in perfect condition, no bending, and the original inner axle shaft seals are still good with no leaking. I am going to put a Spyntec Conversion in the axle in the next month in preparation for the upcoming 2014 EMC Race. I don't think that you can go wrong with this axle. (reasonable tire size and vehicle weight considering). My Jeep was so much faster through the whoops losing the weight of the Dana 60 when I swapped to the Tera HD 44. Just throw in some TeraFlex or Poly HD Ball Joints, RCV Shafts, Sierra Gears and your choice of locker and let it rip!
Impulse Off Road is offline
post #20 of 32 Old 12-03-2013, 06:38 PM Thread Starter
SoK66's Avatar
Thanks, THAT is what I needed to hear! Housing is ordered and I hope on its way from Teraflex. Wish I could do the install myself but I'm recovering from rotator cuff surgery and can't swing any heavy wrenches until March at the earliest. Will farm it out to a local shop.
SoK66 is offline
post #21 of 32 Old 12-05-2013, 06:00 PM Thread Starter
SoK66's Avatar
HAHAHAHAHAHA!!!! Look what showed up about an hour ago!! If I didn't have an injured wing on the mend this would be going in tomorrow!
SoK66 is offline
post #22 of 32 Old 12-05-2013, 06:10 PM
e-jeep's Avatar
Purdy, ain't it!
My Build Thread ~
Adrenaline Offroad
e-jeep is offline
post #23 of 32 Old 12-05-2013, 06:35 PM Thread Starter
SoK66's Avatar
If it was a girl I'd.....
SoK66 is offline
post #24 of 32 Old 12-05-2013, 06:56 PM
kjeeper10's Avatar
Oooh nice !!!!
post #25 of 32 Old 12-06-2013, 10:20 AM
scasorla's Avatar
Looks pretty nice Jerry!!
Seth
scasorla is offline
