Synergy Sector Brace Compatible with Both Axle AND Frame Brackets? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 11-22-2013, 04:54 PM Thread Starter
I am trying to see if the following setup is compatible:
PPM-8089 Axle Side Track Bar Relocation Bracket(With Cam Bolt Removal Washers)
PPM-8069-01 Frame Side Track Bar Brace
PPM-8069-02 Sector Shaft Brace
PPM-8075 (Don't have yet but know I need it)
I was just mocking up the above (Minus the track bar as I don't have it yet) and it looks like having an axle side Track Bar Bracket will interfere with this setup. It looks like having the TB raised the ~3 inches makes it so that the TB will hit the Sector Shaft nut more easily.
I am just looking for confirmation that this setup will indeed work!
Thanks!
Rick.
remborsky is offline
post #2 of 4 Old 11-22-2013, 05:27 PM
AllJumpStyle's Avatar
Check out the 8069 product page.
http://www.synergymfg.com/Synergy-Jeep-JK-Front-Track-Bar-Sector-Shaft-Brace-Kit-p-30220.html
The 8069 kit requires our 8075 Track Bar, especially since you have a raised Track Bar Bracket. The 8075 Track Bar gives you the clearance needed. The pieces will all work together.
Chris Steimle
Product Manager
AllJumpStyle is offline
post #3 of 4 Old 11-22-2013, 05:31 PM Thread Starter
Thanks! I knew it needed the to but never found any info regarding the axle side bracket. Thanks for confirming! I need to get the TV asap so I can get this setup installed!!
Rick
post #4 of 4 Old 11-22-2013, 05:35 PM
No problem Rick!
Chris Steimle
Product Manager
