Bearing Numbers for ARB locker, Pinion, Axle Dana 44 - JKowners.com : Jeep Wrangler JK Forum
post #1 of 1 Old 11-18-2013, 08:44 PM Thread Starter
Sgo70's Avatar
I got my rear end all apart and priced out some bearings from the dealer, the inner pinion was $121 the outer was $88 and the axles were $86 each. The way he quoted it I think it included the cup. I phoned a bearing supply shop with the Timkin numbers and they were about $25 each so I thought I'd just post up the numbers in case someone needs to order a set.
ARB air locker Dana 44 non-Rubicon 3:73 and up (not sure it makes a difference with the new ones): bearing-LM104949, cup-LM104912
Inner pinion:bearing-M802048-N, cup-M802011
Outer pinion: bearing-M88048, cup-M88010
Axle: bearing U399, cup-U360L (can someone verify these, seems too short).
Sean
Sgo70 is offline
