CO2 Tank Regulator - JKowners.com : Jeep Wrangler JK Forum
post #1 of 21 Old 11-15-2013, 07:01 PM Thread Starter
LeJerk's Avatar
CO2 Tank Regulator
Would this regulator work for the type of system everyone uses for airing up tires?
LeJerk is offline
post #2 of 21 Old 11-15-2013, 07:05 PM
Fittings don't appear like they'd mate up to the tank, but I'd expect it to be a low volume/welding type regulator. If it is, then it will frost up within a few seconds when trying to air up tires at that high of a flow-rate.
post #3 of 21 Old 11-15-2013, 08:06 PM
It looks like the back of the regulator says the max inlet pressure it is 300psi... A Co2 tank is going to have a 700-800psi so it would not work unfortunately.
I think this is the best deal I have seen for a regulator and is all you need for tires.
http://www.polyperformance.com/shop/...tor-p-297.html
skates04 is offline
post #4 of 21 Old 11-15-2013, 09:17 PM Thread Starter
LeJerk's Avatar
Dang, I thought I could start to get a tank setup for cheap.
LeJerk is offline
post #5 of 21 Old 11-23-2013, 07:39 PM
THECHAD's Avatar
$40 for a constant pressure regulator from poly
Sent from AutoGuide.com App
18 BRAVO
panama
kuwait
somalia
bosnia
cuba
now just kicking it as a civilian
I served so your lazy ass didnt have to
THECHAD is offline
post #6 of 21 Old 11-23-2013, 07:56 PM
usmcdoc14's Avatar
I was going to say the same thing
usmcdoc14 is offline
post #7 of 21 Old 11-23-2013, 08:57 PM
DeucesALLin's Avatar
there are others too...
...but I personally run the Poly too. I saw a Westin one for 100psi that I am thinking of using with my power tools to prolong the tank though...I dont have air at home.
Soon to be a vendor!!!
Looking for a good Rat Rod JK donor vehicle.
DeucesALLin is offline
post #8 of 21 Old 11-23-2013, 10:59 PM
Jonboy's Avatar
couldn't you just opt to fill your tank w/ Nitrogen and avoid the freeze up issue? You'd get a lot less tire fills per tank but it may work out for the OP
Jonboy is offline
post #9 of 21 Old 11-24-2013, 03:34 PM
This is a better regulator than Poly's in my opinion, regular air hose coupling, cheaper shipping:
http://wheelersoffroad.com/product/o...co2-regulator/
Jollydodger is offline
post #10 of 21 Old 11-26-2013, 02:50 PM
THECHAD's Avatar
But for a backup I had local hydraulic shop make me a 10ft hose 1000psi, I can connect straight to the bottle and fill a 41.5 tire in seconds :-)
18 BRAVO
panama
kuwait
somalia
bosnia
cuba
THECHAD is offline
post #11 of 21 Old 11-26-2013, 03:11 PM
With what valve at the tire?
post #12 of 21 Old 11-26-2013, 03:58 PM
That doesn't sound scary at all.
post #13 of 21 Old 11-26-2013, 04:25 PM
jeeperjkjeeper's Avatar
seconds?...not!....minutes yes!
jeeperjkjeeper is offline
post #14 of 21 Old 11-26-2013, 09:06 PM
THECHAD's Avatar
Lol yes seconds
18 BRAVO
panama
kuwait
somalia
bosnia
cuba
THECHAD is offline
post #15 of 21 Old 12-10-2013, 09:30 PM
I'm new to co2 air bottles - I have 35" tires and would be airing from trail 10lbs to road 28 lbs - about how many tires could be aired up with a 10lb bottle? Thanks!
road_king is offline
post #16 of 21 Old 12-10-2013, 09:45 PM
ChuckMRN's Avatar
I can air up 37's (all 4) 4 times with a 10lb tank. I weighed mine and its right around 2lbs give or take for a set. They won't put 10lbs in mine where I get it filled. Varies between 8-9lbs. They say it will blow the pops in the summer time. That would be a rush inside the rig..
16 JKU Sport
RK 3.5 X Factor, UD 60's, Atlas T Case 4.3:1,
TR Bead locks with Toyo Open Country MT's,
VKS Bumpers and Sliders. EVO Skins,
PSC Hydro on Synergy Steering,
Fox Shocks and Bumps
"40's Baby!"
2011 JKU RUBI "SOLD"
ChuckMRN is offline
post #17 of 21 Old 12-11-2013, 09:59 PM
Thanks!
post #18 of 21 Old 12-12-2013, 12:23 AM
CashMoney's Avatar
Thats what I was thinking too. I couldn't get mine to air up that fast until I went with monster valves.
CashMoney is offline
post #19 of 21 Old 12-12-2013, 07:24 AM
BRUT4CE's Avatar
Same here I get about 12 tires (37") ..I went to 20 lb this itime around.
BRUT4CE is offline
post #20 of 21 Old 12-12-2013, 08:15 AM
Poly's comes in cheaper...
...took 3 days to get to Houston. The above fitting though, I think is by Westin, and it can be had in 100psi too.
post #21 of 21 Old 12-12-2013, 08:58 PM
BRUT4CE's Avatar
Yeah that's westin, I run the #150....simple and works...
BRUT4CE is offline
