Building Scrap yard axles - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 11-14-2013, 07:55 AM Thread Starter
curbsjeep's Avatar
I am thinking about building a couple of Junkyard axles for my JKU.
I am just starting to do the research and digging around. But am interested in hearing some opinions on what year / model donor to pull them from? What would be easiest to retro fit in?
Cutting off brackets / welding in new ones doesn't bother me, I can handle that easily.
My goal is to run 40's in the next year or two with coilovers.
Mango Tango Unlimited Mountain
curbsjeep is offline
post #2 of 12 Old 11-14-2013, 08:01 AM
try the search. there are several threads on here.
good luck
post #3 of 12 Old 11-14-2013, 09:43 AM Thread Starter
curbsjeep's Avatar
good luck
I did a search for "axle" and found some helpful and some non helpful threads.
https://www.jkowners.com/forum/search...archid=6441962
I did find this one which is from 2009, slightly out of date. Was wondering if there was anything more current.
https://www.jkowners.com/forum/showth...highlight=axle
More current and slightly off topic by page 13, some helpful stuff at the beginning though.
Searching through the library and write-ups I didn't find much of anything back to 2010.
Anyone want to contribute toward the discussion?
post #4 of 12 Old 11-14-2013, 09:46 AM
ALASHA's Avatar
These threads may be of some use:
https://www.jkowners.com/forum/showthread.php?t=42673
https://www.jkowners.com/forum/showthread.php?t=74258
ALASHA is offline
post #5 of 12 Old 11-14-2013, 09:47 AM
Try searching "tons"
You will find a lot of subjects on heavy duty axles.
post #6 of 12 Old 11-14-2013, 07:30 PM
I'm in the middle of a one-ton build myself...
I decided to go with a Ford Dana 60 out of a 99-03 F350 Superduty. Currie uses the same stuff on their axles, so retaining ESP/BAS is a bolt in affair. The only downside is that the driver's side tube only has about 1" of tube to work with. There is options for high-steer, and it's easily converted to whatever lug pattern you want to run. I chose 8x6.5
Everyone else seems to do the late 70's ford dana 60. Kingpin, longer drivers tube, good aftermarket.
zpike00eb is offline
post #7 of 12 Old 11-14-2013, 08:13 PM
try the search. there are several hundred threads on here.
good luck
fixed
MISHIMOTO IS JUNK
chknkatsu is offline
post #8 of 12 Old 11-14-2013, 09:29 PM
CashMoney's Avatar
what bolt pattern is the 99-03 stock?
CashMoney is offline
post #9 of 12 Old 11-14-2013, 10:03 PM
VKS Fab
JK Vick's Avatar
Here is ours
Operation 8lug - VKS Fab
Handmade One At A Time
GIVE US A CALL 559-392-3145
JK Vick is offline
post #10 of 12 Old 11-15-2013, 05:58 AM
spedly's Avatar
8x170mm
spedly is offline
post #11 of 12 Old 11-15-2013, 07:45 AM
ALASHA's Avatar
You plan on doing a build thread?
ALASHA is offline
post #12 of 12 Old 11-15-2013, 09:37 AM
frenchlayer's Avatar
check out this similar topic on asylum
http://www.jeepasylum.com/showthread...ana-60-in-a-JK
Dirty Minion for lifeô.:the finger:
frenchlayer is offline
