Helped needed !! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 11-13-2013, 12:51 PM Thread Starter
Helped needed !!
I have a 2007 wrangler x, I'm currently running 35's , I have felt and rear 5.13 gears sitting in my garage. The reason I haven't gotten them installed is I simply don't fully understand the drivetrain, by upgrading the gears will I be adding stress to other key components? What other parts should I upgrade while doing this ? Also looking for input on lockers I have been doing some research and am starting to understand the function and the different kinda just still not sure on how to go about buying some in my case. Any help is appreciated ! Thanks !
Frecks10 is offline
post #2 of 5 Old 11-13-2013, 01:35 PM
Daniel_M's Avatar
Welcome. Installing gears isn't something you should tackle if you don't have the know how. I hope you didn't mean YOU were installing them.
It doesn't add any stress on other components. When I did my 5.13 I got a front locker, Teraflex diff covers for protection, and new gaskets (lube locker). I also got an AEV Procal to tell my auto tranny that my gear ratio changed and I am running 35's. I went with a lunchbox locker up front, Aussie, since I am in the desert and don't drive in snow it was perfect. The Aussie is undetectable in 2WD. Prior to selling my Jeep I was going to throw an air selectable in the rear, a Yukon Zip Locker.
-Dan
2008 JK X: Sold
Daniel_M is offline
post #3 of 5 Old 11-13-2013, 03:46 PM Thread Starter
-Dan
I also have aftermarket covers along with the lube locker gaskets, I'm just Wondering would it hurt to upgrade my axle? Would I need to look for a specific axle type I'm
Still in my research phase but am just really wanting to get it done before I put it in storage. As for the lockers I'm looking for something simple but will really help me on the trails or in the mud, any suggestions ?
Frecks10 is offline
post #4 of 5 Old 11-13-2013, 03:48 PM
FuLcRuM's Avatar
Gears won't add/remove much stress to the rest of the drive train.
The gears themselves do get a little weaker as you go higher since the pinion gets smaller, but it isn't much of an issue.
If your new to wheeling you will probably just want to get out there and ride as is with some other JK's, you'll learn first hand how various mods affect the overall performance and what limitations each type has.
If money is no object 35 spline ARB's front/rear is about the best setup you can get for a dual purpose rig IMO. That's what I'm running even though money is an object for me, I managed to get a good deal on a set someone was selling.
Jeepless
FuLcRuM is offline
post #5 of 5 Old 11-13-2013, 06:37 PM
Running the 5.13 gears will actually reduce the amount of stress on your entire driveline from the engine to the transmission, transfer case, and driveshafts.
Type of lockers you use will be up to what you drive in and where, if you use 4wd during slick snowy driving on the road then you will want to run a selectable due to safety concerns.
